Is it possible to connect a single-phase inverter so that the current is divided
Auto System Polan 22344 35
Can I connect a single-phase inverter so its output is split across three phases to meet the grid limit?
No, you cannot split a single-phase inverter into three phases for a normal grid connection; one reply says it may be technically possible in theory, but not in your case, and the utility would likely require extra certification for any 1F→3F solution anyway [#18401494][#18401501] If you want to keep the existing equipment, the only realistic path mentioned is that the DSO accepts the installation based on panel power rather than inverter rating [#18406224][#18406389] In that interpretation, the discussed limit is 3.68 kW of panels per phase, while the inverter itself may still be 4 kW or similar as long as the panel sum stays under the threshold [#18406224][#18406389] If you need more than that, the thread recommends replacing it with a 3-phase inverter or using three single-phase inverters, each with panels not exceeding 3.68 kW [#18406224]
  • Oversizing panels without increasing grid export
    #31 20014061
    marekm1972
    Rate: 43
    But I just want to add a little more than 3.68 kW of panels, and the 3 kW inverter stays the same. The power of the panels counts to the coefficient of 0.7 (over 10 kW) instead of 0.8 and for fire protection consultation (over 6.5 kW), but also to the requirement that the inverter must be 3-phase (which would force the change of 1-phase connection to 3-phase).
    Don't worry and don't report at all? The meter will never register more power actually fed into the grid, because once the inverter will limit it to 3 kW, and auto-consumption will be subtracted from this. Mainly, I'm afraid that more panels will be visible in Google Maps in a while...
  • 3.68 kW per-phase limit requires 3-phase inverter
    #32 20014100
    msr99
    Help: 27
    Rate: 77
    marekm1972 wrote:
    more panels will be available in Google Maps soon...
    You underestimate this institution
    3.68kw is the limit per phase. It used to be bigger.
    Anyway, if you want to add two panels (plus some 700w) you will overload the inverter to 146%.. (3.68 kW + 0.7 kW) A bit much..
    Add panels to 9.9kw change the inverter to 3phase. And nothing will change for you (you will still be at 80% acceptance) if you have received the installation before March 31
  • Separate 1-phase and 3-phase installations discussed
    #33 20014121
    marekm1972
    Rate: 43
    I understand this limit for a 3-phase installation so as not to introduce excessive asymmetry, but can I also be forced to switch to 3-phase if I have a 1-phase? I'm running this mostly on a 1-phase UPS anyway that powers some computer and mains equipment, so I won't be spreading the load evenly across the 3 phases.
    I have such and no other amount of space on the roof of the garage, I can't physically squeeze more. I do not overload the inverter heavily, because there will never be maximum power from both east-west strings connected in parallel at the same time.
    I also have a second installation at home (same address, separate building, separate 3-phase meter) and here I want to expand it to almost 10 kW - realistically, this is enough for a fairly complicated roof without partial shading (optimizers or micro inverters, which a few companies willingly provide wanted to sell, but these are additional costs and over 10 kW I fall into 0.7).
    Both installations (small 1-phase on the garage and larger 3-phase on the house) reported earlier, there are 2 2-way meters. Energa, when changing the meter, checked whether there is actually an installation, and the meter itself is of the "smart" type (it communicates via GSM, statistics updated once a day can be viewed later on every day, even broken down every hour - full surveillance).
  • #34 20014160
  • #35 20014173
    rokbok
    Level 40  
    Help: 652
    Rate: 1035
    Nothing will change except one thing ;) .
  • Tauron allows three single-phase inverters above 3.68 kW
    #36 21247775
    cdtdsilva
    Rate: 15
    My experience with Tauron (as of 2024)
    If it is more than 3.68 kW of panels, they will not let you register a single phase inverter, only a 3 phase equivalent.
    What they let you do above 3.68KW is install 3 single phase inverters and you can have one up to 3.68KW and 2 microinverters of 330W, for example. This might be a better way for people adding a couple more panels and keeping the existing system unchanged. Note that above 3.68KW total it must be 3 single phase inverters each under 3.68KW, not two.
    One problem is that while they let you add storage or panels, there is a tick box asking if you made any changes to the inverter, If so you will need an installer form to document the changes. It can't be done online.
    Similarly the online form only lets you use one on the Current list of approved devices. For those that have a pre G98/G99 Inverter I don't know how changes to the instalation are conducted as they always ask you for everything you have, not just the aditions, so you will need an installer form and probably details of the original submission.
The discussion revolves around the challenges of connecting a Kaco 9600 single-phase inverter to the grid, particularly regarding the maximum allowable power of 3.68 kW per phase. Users express concerns about the inverter's excess capacity and explore potential solutions, such as reporting the inverter's output as 3.6 kW while connecting panels that do not exceed this limit. Responses indicate that while technically possible, energy companies (ZE) may not accept configurations that exceed the power threshold, emphasizing that the power of the panels, not the inverter, is what matters for grid connection. Suggestions include selling the inverter for a three-phase model or using multiple single-phase inverters to comply with regulations. The conversation highlights the importance of adhering to local energy regulations and the implications of inverter certification.
TL;DR: Poland’s single-phase PV export is capped at 3.68 kW (≈230 V × 16 A)[Elektroda, retrofood, post #18406884]; “There is no chance of converting 1 F to 3 F by the inverter”[Elektroda, Spajder_PL, post #18401501] Utilities reject bigger 1-phase inverters unless panel power stays below the cap. Why it matters: Oversizing blocks grid connection and wastes hardware investment.
• Single-phase limit: 3.68 kW panel rating per phase[Elektroda, marek_gm, post #18406224] • Formula: 230 V × 16 A = 3.68 kW[Elektroda, retrofood, post #18406884] • Typical 3.6 kW inverter peak: 4 kW[Elektroda, ACCel, post #18406264] • NC RfG certificate required for new inverters since 2022[Tauron Req., 2019] • 3-phase 6 kW inverter price: approx. 3500–5500 PLNCeneo price list
Why do DSOs cap single-phase PV at 3.68 kW?
The 3.68 kW cap matches 16 A fuse ratings and keeps phase-to-phase voltage asymmetry below tolerance. Rural feeders see voltage rise when a lone phase exports more than 3.68 kW, causing inverters to trip[Elektroda, marek_gm, post #18406389]
Will the utility assess panel power or inverter power?
They look at total panel STC power. If panels exceed 3.68 kW on one phase, the application fails—even if the inverter is limited[Elektroda, prose, #20013174; Elektorda, Anonymous, #20014160].
What happens if I connect a 4 kW single-phase inverter without permission?
The DSO can refuse bi-directional meter installation or later disconnect the plant. Field audits compare panel count with the declaration and satellite images[Elektroda, msr99, post #20014100]
Is off-grid operation a legal workaround?
Off-grid avoids DSO rules but needs batteries and transfer switching. Cost rises ~40 % and payback doubles, so forum experts say it “usually makes no sense”[Elektroda, Spajder_PL, post #18401471]
How do I upgrade to a compliant three-phase system?
  1. Apply for 3-phase service if your supply is 1-phase. 2. Install a 3-phase inverter (5–10 kW typical). 3. Submit new micro-installation form with NC RfG certificate and electrician sign-off. DSOs accept up to 10 kW without remote-curtailment port[Tauron Req., 2019].
Can I add extra panels to my 3 kW inverter?
Yes if the added panels keep total below 3.68 kW; otherwise switch to 3-phase or split across three single-phase inverters each ≤3.68 kW[Elektroda, cdtdsilva, post #21247775] Overloading an inverter above 125 % shortens life and voids warranty[Huawei Manual, 2023].
What if my inverter lacks the RS485 control port now required?
Install an external gateway that offers RS485 or Ethernet interface. Without a controllable port, DSOs may reject or request retro-fit during inspection[Elektroda, marek_gm, post #18561189]
How much voltage rise is acceptable on a weak feeder?
European low-voltage codes limit 10 % rise; exceeding 253 V forces the inverter to disconnect. Each extra exported kW can add ~1.5 V on a long 4 mm² line[IEA PVPS, 2021].
Edge case: What if I already have 6 kW three-phase and want a 3.6 kW single-phase add-on?
Permitted if you use three single-phase inverters (one per phase) so no phase exceeds 3.68 kW, and total stays ≤10 kW[Elektroda, marek_gm, post #18557594]
