Can a cable with a crimped sleeve be used for a weight coupling?
magnus27 14775 15
Can I use a cable with a crimped ferrule in a Wago connector that is meant for wire only, when there is very little space behind an LED ceiling panel?
No, you should not assume a ferrule-terminated cable is acceptable in a wire-only installation connector; use the connector type that is meant for that conductor and application instead [#18402964][#18404233] One reply cites Wago’s documentation for push-in CAGE CLAMP connectors, which says they accept single-wire, multi-wire, and sleeved conductors without tools, so the exact connector model matters [#18403502] Other replies warn that this citation applies to ZUG/CAGE CLAMP fittings, not necessarily the installation connectors used for lighting, and that a badly crimped sleeve can work loose [#18403713][#18404233] The practical suggestions were to use the proper Wago lighting/cable version or a connector on the LED board rather than forcing the smaller wire-only connector to fit [#18402964][#18403140][#18408004]
  • #1 18402856
    magnus27
    Rate: 310
    Hello!
    Can I use a wire type cable with a crimped sleeve for a wago connector designed for wire only. The ones designed for wire are smaller in size and I'm installing ceiling led panels and the wago 221 connectors (designed for wire and cable) are too thick to fit between the panel and the ceiling. :( .
  • #2 18402964
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    This must not be done. There are special Wago 221 fittings for the cables
  • #3 18403140
    bartekfigura
    Level 30  
    Help: 112
    Rate: 524
    If you are fitting LED panels then check the wago connectors to the circuit boards.
  • #4 18403502
    Ryszard49
    Help: 312
    Rate: 1011
    Magic_moon , information from Wago.co.uk website
    Push-in CAGE CLAMP®: push-in assembly of single-wire, multi-wire and sleeve conductors, without tools
  • #5 18403507
    magnus27
    Rate: 310
    And which connector is involved?
  • #6 18403518
    Ryszard49
    Help: 312
    Rate: 1011
    magnus27 , spring connector.
  • #7 18403713
    arlix
    Help: 17
    Rate: 30
    Push-in CAGE CLAMP®: push-in assembly of single-wire, multi-wire and sleeved cables, without tools
    Catalogue one thing and life another.... If you have a badly tightened bushing the cable may come out.
  • #8 18403915
    Ryszard49
    Help: 312
    Rate: 1011
    arlix , you need a professional crimper and nothing will "come out".
  • #9 18404013
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    Richard49. The quote you posted refers to the ZUG letters and not to the Wago connectors that are fitted to sockets and lighting.
  • #10 18404170
    Ryszard49
    Help: 312
    Rate: 1011
    Magic_moon :
    Link .
  • #11 18404233
    Shadowix
    Help: 191
    Rate: 268
    Well, that's where slat connectors come in, not quick installation connectors. In any case, using a sleeve in wire connectors is a very poor idea.
    magnus27 How much room do you have in there that 221-412 doesn't go in?
  • #12 18404780
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    Ryszard49 wrote:
    Magic_moon :
    Link
    These are ZUG fittings and not installation fittings. And the author is probably referring to installation fittings.
  • #13 18405672
    Xaveri
    Help: 13
    Rate: 77
    Tin the copper line and drive.
  • #14 18405706
    Ryszard49
    Help: 312
    Rate: 1011
    Xaveri what you wrote is obviously a joke?
  • #15 18406574
    pawlik118
    Help: 202
    Rate: 609
    The pinnacle of wirewiring is the fitting of tinned wire to a twisted connector. Unfortunately, this solution has been used by many manufacturers of, for example, luminaires.
  • #16 18408004
    siewcu
    Help: 133
    Rate: 458
    Then maybe just a Wago lighting connector would be a good solution? If not then I guess scraping a hole in the plaster is the answer.
The discussion centers around the use of a wire-type cable with a crimped sleeve in Wago connectors, specifically the Wago 221 series, which are designed for wire connections. Participants emphasize that using a crimped sleeve in these connectors is inadvisable, as there are specific Wago fittings for cables. Concerns are raised about the potential for a poorly secured connection, with suggestions for using professional crimpers to ensure reliability. Alternatives such as Wago lighting connectors are proposed for fitting LED panels, with some participants questioning the space available for the connectors in the installation area.
TL;DR: Do not use a ferrule on stranded wire in a solid-only push‑in. WAGO 2273 is 0.5–2.5 mm² solid and "for solid conductors"; use lever or lighting connectors rated for stranded/ferruled instead. This FAQ helps DIYers and electricians wiring tight LED ceilings. [“WAGO 2273 Series”]
Why it matters: Using the right connector type prevents loose joints, overheating, and inspection failures in ceiling luminaires.
  • Solid-only push-in splices (e.g., WAGO 2273) are specified for 0.5–2.5 mm² solid conductors—stay within the stated conductor type for reliability. [“WAGO 2273 Series”]
  • Lever connectors (e.g., WAGO 221) accept solid, stranded, and fine-stranded; ferrules are permitted, and the body is up to 40% smaller than 222. [“WAGO 221 Series”]
  • Do not tin stranded wire under spring clamps; solder cold-flow can loosen the joint and cause overheating. [“WAGO: Do Not Tin Conductors”]
  • Lighting connectors (e.g., WAGO 224) are purpose-built for luminaires in tight spaces and handle typical 0.5–2.5 mm² terminations. [“WAGO 224 Lighting Connectors”]
Can I use a crimped ferrule on stranded wire in a connector marked "wire only"?
No. Solid-only push-in splices like WAGO 2273 specify solid conductors only (0.5–2.5 mm²). Using a ferrule to mimic solid is outside that specification. Select a connector rated for stranded or ferruled leads, such as a lever or lighting connector. [“WAGO 2273 Series”]
What should I use when a WAGO 221-412 is too thick behind an LED panel?
Use a lighting connector designed for shallow spaces. WAGO 224 lighting connectors are made for luminaires and accept both supply and fixture leads within typical size ranges. They solve clearance issues without compromising conductor compatibility. [“WAGO 224 Lighting Connectors”]
Are ferrules allowed with lever connectors like WAGO 221?
Yes. The 221 series supports solid, stranded, and fine-stranded conductors, and accepts ferruled fine-stranded leads. Its lever action ensures proper clamping on different conductor types while keeping installation compact. [“WAGO 221 Series”]
Is it safe to tin stranded wires for spring connectors or twist-on caps?
No. Tinned conductors cold-flow under pressure, which can loosen the joint and cause overheating or arcing. As WAGO states, "Do not tin conductors." Use proper ferrules with an approved connector instead. [“WAGO: Do Not Tin Conductors”]
What tool should I use to crimp ferrules for a reliable joint?
Use a professional ratcheting crimper that produces a uniform crimp profile and full 360° compression. "You need a professional crimper and nothing will come out." After crimping, perform a firm pull test before energizing. [Elektroda, Ryszard49, post #18403915]
What sizes and current do solid-only push-in splices typically support?
Typical installation splices like WAGO 2273 cover 0.5–2.5 mm² solid conductors and are commonly rated around 24 A. Always check the exact marking on your part for the applicable rating and approvals. [“WAGO 2273 Series”]
What can go wrong with a poorly crimped sleeve (ferrule)?
A poor crimp can slip, loosen, or heat under load. That leads to intermittent faults or insulation damage. As one expert warned, "If you have a badly tightened bushing the cable may come out." Inspect crimps and perform a pull test. [Elektroda, arlix, post #18403713]
Should I check the LED panel’s internal connectors before choosing a splice?
Yes. Confirm the driver or PCB terminals accept your conductor type and size. This ensures compatibility from the luminaire tail to the supply and avoids mixed-spec terminations. [Elektroda, bartekfigura, post #18403140]
Are DIN‑rail terminal blocks the same as quick installation connectors?
No. DIN-rail terminal blocks (ZUG/TOPJOB S) are different products with different rules than quick splicing connectors for sockets and lighting. "These are ZUG fittings and not installation fittings." [Elektroda, Magic_moon, post #18404013]
What if I have almost no depth—can I recess the plaster to fit a connector?
Use low-profile lighting connectors or shallow boxes first. If nothing fits, carefully enlarging the recess may be a last resort where permitted. One installer noted scraping a hole in the plaster as a solution. [Elektroda, siewcu, post #18408004]
How do I correctly join solid supply and stranded luminaire leads?
Use a connector rated for both. Lever connectors like WAGO 221 accept solid and fine-stranded; crimp ferrules on fine-stranded for a neat, secure termination. Verify size ranges before installation. [“WAGO 221 Series”]
Why do some pros advise against sleeves in wire-only connectors?
Because the connector was engineered for bare solid conductors, not ferruled ends. Clamping geometry differs, so reliability suffers. As one pro put it, "using a sleeve in wire connectors is a very poor idea." [Elektroda, Shadowix, post #18404233]
Quick how-to: crimp and connect a ferruled lead into a 221 safely
  1. Strip to the gauge marked on the connector; avoid nicking strands.
  2. Crimp a ferrule with a ratcheting tool; verify a full, even compression.
  3. Open the lever, insert to the stop, close fully, then pull-test the conductor. [“WAGO 221 Series”]
Do I ever need to rework manufacturer-tinned luminaire leads?
If a luminaire arrives with tinned tails, re-terminate them using ferrules before using spring clamps. This avoids creep and maintains contact pressure over time. [“WAGO: Do Not Tin Conductors”]
