Acquiring Device Password for Wireless DVS Camera in HQ CONNECT Application
Aniaaaa123456 16287 7
  • #1 18441914
    Aniaaaa123456
    Hello. I bought a wireless DVS camera. I would like to be able to preview it in the HQ CONNECT application. When adding a camera in this application, the device password is required. Could someone help me where to get the password for this camera?
    • Acquiring Device Password for Wireless DVS Camera in HQ CONNECT Application 20200201_115942.jpg (669.23 KB) You must be logged in to download this attachment.
  • #2 18441917
    adamjur1
    Help: 772
    Rate: 1003
    Factory reset and manual. (uncle google) ...,
    Greetings J.
  • #3 18441947
    Aniaaaa123456
    The camera reset does nothing, and the manual does not contain any information about the login or password.
  • #4 18441970
    adamjur1
    Help: 772
    Rate: 1003
    The manual says that during the first installation (probably also after the reset), the camera will ask you to set a password (this is the case in dahua consumer)
    Try to enter some (just remember them)
    Greetings J.
  • #5 18854152
    wojcza
    Rate: 8
    Good morning,
    I have the same problem. Did you get the device password?
  • #6 18854193
    nikiel
    Rate: 16
    I stick to the question. I also have a problem with the password
    I wrote an email to the producer. You probably need to generate a * .XML file
    send it by e-mail to the manufacturer and they will send back a file that will allow you to reset the password.
    I am only surprised that they supposedly write that devices are unused and unconfigured.
  • #7 18854806
    wojcza
    Rate: 8
    Good morning, topic settled.
    At the first start-up, you need to connect the camera to the router using a lan cable. Then, when adding the device, a message about assigning a new password will appear.
  • #8 18854996
    nikiel
    Rate: 16
    I'm glad that something was moved.
    I have the second option that works
    When we connect to the camera via wifi and it crashes a message to enter the password (not to be confused with sending a password)
    enter: "admin + verification code" (located on the camera sticker)
    for example: adminWSTSRC (note that the letters are case sensitive)
    In the next step, we enter the verification code in the encryption password, also paying attention to the case of letters.
    The proven method works
The discussion revolves around acquiring the device password for a wireless DVS camera to use with the HQ CONNECT application. Initial suggestions included performing a factory reset and consulting the manual, but these did not yield results. Users noted that during the first installation or after a reset, the camera prompts for a password setup. One user found success by connecting the camera to a router via LAN cable, which allowed for password assignment during device addition. Another method involved connecting to the camera via Wi-Fi and entering a password format of "admin + verification code" found on the camera's sticker, emphasizing case sensitivity. Additionally, contacting the manufacturer for a password reset via an XML file was suggested.
