[Solved] No access to edit files on Wemos D1 mini as AVR ISP
lisulisu6 2634 20
How can I make the esProg editor at 192.168.4.1/edit show the file upload, edit, and delete controls on a Wemos D1 mini?
Connect the laptop to the internet by cable while staying connected by Wi‑Fi to the esProg access point; the /edit page needs network access to load correctly [#18540999] The web editor is opened with http://192.168.4.1/edit, and browser/security issues such as HTTPS certificate blocking can also stop the page from displaying properly [#18471457][#18472095] After doing that, the original poster confirmed that the editor page worked [#18557552]
  • #1 18465822
    lisulisu6
    Help: 5
    Rate: 13
    Hello everyone. I recently found on the internet a portable avr programmer built on a Wermos D1 mini module (display a couple of components) I decided to build it and ran into an insurmountable problem. The hex, fuses, eeprom files for avr programming are uploaded via a web browser to the module memory. And here is the problem in the author's case after entering in the browser under the address 192.168.4.1/edit you can add files, edit, delete in my case there is no such possibility and I do not know what is wrong. I programmed the module as the author stated. There are two bin files which have to be uploaded to given addresses (SSD1306 0.96 esProg_0.96.bin Address:0x00000 EspFlasher/ESP8266Flasher.exe first and second esProg.spiffs.bin Address:0x100000 EspFlasherTool/ESPFlashDownloadTool_v3.4.4.exe)
    Link to project, software and youtube video.
    https://espprog.blogspot.com
    https://github.com/ArduinoGelistirmePlatformu/esProg
    https://www.youtube.com/watch?v=lhsaVAEl87k&t=31s
    And here is a picture of the problem
    No access to edit files on Wemos D1 mini as AVR ISP .
  • #2 18467672
    kaczakat
    Help: 317
    Rate: 231
    When you start this module, a new AP for WIFI should appear, you connect to it with your laptop over WIFI and only then is it possible to enter the address 192.168.4.1 (the default AP address on the network with the ESP8266).
  • #3 18467897
    lisulisu6
    Help: 5
    Rate: 13
    This is what I have been doing. That is, I enter the wifi network selection, select esProg, connect, and then select 192.168.4.1/edit on the browser, the page loads as shown in the image, but there is no possibility of adding files, deleting. If I go to 192.168.4.1/update there I can select and carry out a software update. And here is the problem, because what is this programmer if you can not add flash files
  • #4 18468011
    Slawek K.
    Help: 259
    Rate: 1303
    Try it on different browsers, Edge, Firefox etc.
    Greetings
  • #5 18468162
    lisulisu6
    Help: 5
    Rate: 13
    I have already tried and even on different systems ie windows linux and android and still the same. I don't know if it is the module's fault. Although every time I upload the soft it uploads normally. If someone uploaded the soft to their module it would be possible to tell if it is the wins of the soft or the module. My module looks like this
    I do the soft upload like this
    No access to edit files on Wemos D1 mini as AVR ISP No access to edit files on Wemos D1 mini as AVR ISP No access to edit files on Wemos D1 mini as AVR ISP No access to edit files on Wemos D1 mini as AVR ISP No access to edit files on Wemos D1 mini as AVR ISP No access to edit files on Wemos D1 mini as AVR ISP No access to edit files on Wemos D1 mini as AVR ISP No access to edit files on Wemos D1 mini as AVR ISP No access to edit files on Wemos D1 mini as AVR ISP No access to edit files on Wemos D1 mini as AVR ISP No access to edit files on Wemos D1 mini as AVR ISP .
    And finally in the browser linden
  • #6 18468224
    Slawek K.
    Help: 259
    Rate: 1303
    In my opinion, you must initialise the flash with SPIFFS, because then you can upload files to the flash esp8266.
    Best regards
  • #8 18468469
    lisulisu6
    Help: 5
    Rate: 13
    I have cleaned the flesh, reloaded the soft and still the same thing
  • #9 18468495
    kaczakat
    Help: 317
    Rate: 231
    There are lots of topics here about uploading flash, updating firmware - read up. Surely 4Mbit is not 4MB, on the right in the box you have that it detected 32Mbit (4MB=32Mb), QIO may not be the best choice either, slower modes may improve the stability of operation in some cases, here exactly you can choose lower ones (but of course it is best to choose the fastest working one).
  • #10 18468527
    lisulisu6
    Help: 5
    Rate: 13
    I've read, uploaded at different speeds and still the same thing I've been rolling it out for a week now and no results.
  • #11 18468553
    kaczakat
    Help: 317
    Rate: 231
    But you keep posting a screenshot with a flash size setting of 4Mb, this is 512kB, this program may just not fit. You are supposed to select 32Mbit. Other than that, download the standard firmware, choose to upload at the appropriate blank, init data and boot addresses, your binary where "user" is.
    I uploaded this in the setup:
    As you can see I only added the spiffs file.
    After the AP appeared, I connected and entered the address "192.168.4.1/update", logged in using "admin" and "espprog", you can select the file to upload and press UPDATE.
  • #12 18468653
    lisulisu6
    Help: 5
    Rate: 13
    I uploaded the same as you. Only under 192.168.4.1/update it comes in now and it came in before. The problem is to enter under 192.168.4.1/edit because this is where you add batches edit delete. And update is just updating the software esProg_0.96.bin. Under 19.168.4.1/edit there should be fields upload create and on the left flash files
  • #13 18468747
    kaczakat
    Help: 317
    Rate: 231
    Unfortunately the design looks like you upload and it works, or it doesn't work and you don't do anything else - no sources. It actually doesn't work on me either, maybe the lack of oled doesn't trigger something in the program, I just uploaded it to a clean ESP. If you care about an ISP programmer over WIFI then have a look at the project ESP-link with built-in STK500 programmer.
    You upload the firmware according to the instructions, the AP appears, you log in from your phone, connect it to your local network, save the IP address, install the virtual COM with TIBBO https://tibbo.com/soi/software.html on your PC, enter the ESP parameters - IP, TCP/UDP,port, the virtual COM port appears on the PC via WIFI. In the ESPlink web interface you configure to which pins you connect what (without conversion it is 3.3V logic) and that's it - you use it like a programmer connected to a PC.
  • #14 18469627
    lisulisu6
    Help: 5
    Rate: 13
    So yes applying voltage from the battery pack to a voltage divider built with resistors R3 R4 R9 on the divider we get 2.4V after changing resistor R3 100K to 33k we get 3.3V. The programmer does not start. Even applying 3.3V from the power supply does not start it (pin according to the schematic A0). Only supplying power to the micro usb or to the 3.3v pins (of course to this 3.3v pin, because supplying 5v to this pin could end the life of the module) starts the programmer, you can navigate through the menu and select various options, there are also files which are on the video. Programmer started on contact board, after entering the browser the problem remained, you can not add, edit or delete batches. It's a pity it doesn't work as it should always be able to upload soft to atmega without a computer in the field. I also have a question when you enter 192.168.4.1/update in the browser you can select the update file, when I put the esProg.spiffs.bin file there it grinds a bit and throws an error that there is no space. Is it possible that the author has selected a module with more memory
  • #15 18471457
  • #16 18471771
    lisulisu6
    Help: 5
    Rate: 13
    Same as before
  • #17 18472095
  • #18 18472118
    lisulisu6
    Help: 5
    Rate: 13
    then what settings should I use ???
    jack7
    the problem is simple to solve :) connect your laptop via cable to the internet and via wifi to the modulus - it works :) this website must have access to the network for it to work
  • #20 18557552
    lisulisu6
    Help: 5
    Rate: 13
    Thanks jack7 it worked. Seemingly simple and only you helped Thanks
  • #21 18557559
    lisulisu6
    Help: 5
    Rate: 13
    Added after 1 [minute]: .
    Works thank you all for your help
A user encountered issues accessing the file editing features on a Wemos D1 mini module configured as an AVR ISP programmer. Despite following the setup instructions and successfully uploading firmware, the user could not add, edit, or delete files at the address 192.168.4.1/edit. Various troubleshooting steps were suggested, including trying different web browsers, ensuring proper flash initialization with SPIFFS, and clearing the flash memory before re-uploading the firmware. Ultimately, the solution involved connecting the laptop to the internet via cable while also connecting to the Wemos D1 mini's Wi-Fi, which resolved the access issue.
TL;DR: On a Wemos D1 mini esProg, use 4 MB (32 Mbit) and log into http://192.168.4.1/edit as admin/esprog; "I logged into the account admin with the password esprog." Flash SPIFFS at 0x100000 using DIO mode. [Elektroda, khoam, post #18471457]
Why it matters: This helps makers who can’t get /edit to show upload controls on an esProg-based AVR ISP.
How do I fix 192.168.4.1/edit showing no upload buttons on esProg?
Keep your computer connected to the Internet via Ethernet while Wi‑Fi stays connected to the esProg AP. Then reload /edit. The UI needs network access to load its assets. As one user put it, "this website must have access to the network for it to work." After reconnecting, the Upload and Create controls appear. [Elektroda, jack7, post #18540999]
How do I flash esProg on a Wemos D1 mini (step-by-step)?
  1. Erase flash: esptool.py --port erase_flash.
  2. App: esptool.py --port write_flash -fs 4MB -fm dio 0x0 esProg_1.3.bin.
  3. SPIFFS: esptool.py --port write_flash -fs 4MB -fm dio 0x100000 esProg.spiffs.bin. Then join the esProg AP and open http://192.168.4.1/edit. [Elektroda, khoam, post #18471457]
What does 192.168.4.1/update do on esProg?
It opens the firmware update page. You can choose an update file and perform a software update from that interface. [Elektroda, lisulisu6, post #18467897]
I get "no space" when uploading esProg.spiffs.bin via /update. What now?
Skip OTA for SPIFFS. Write the SPIFFS image over serial at 0x100000 with -fs 4MB and -fm dio. This layout worked reliably with esProg_1.3. [Elektroda, khoam, post #18471457]
Do I need to erase the ESP8266 flash before re‑flashing?
Yes. Erasing removes old partitions and avoids conflicts. Run esptool.py --port erase_flash, then write the app and SPIFFS again. [Elektroda, khoam, post #18468336]
What flash size and mode should I choose in the flasher?
Select 32 Mbit (4 MB), not 4 Mb (which is 512 kB). Use DIO if QIO seems unstable. Incorrect size causes broken SPIFFS and missing UI elements. [Elektroda, kaczakat, post #18468495]
Are HTTPS warnings or browser settings blocking the editor?
Check for HTTPS warnings and untrusted certificates. A contributor noted the page uses HTTPS without a certificate, which browsers can block. "The certificate is not there," so allow it or use a browser that permits it. [Elektroda, khoam, post #18472095]
Can I power the programmer from a battery via A0?
No. A0 is an analog input. Powering there will not start the module. Use the micro‑USB 5 V input or the 3.3 V pin. Never feed 5 V into the 3.3 V pin. [Elektroda, lisulisu6, post #18469627]
Will switching browsers or OS fix missing buttons on /edit?
Users tested Edge and Firefox on Windows, Linux, and Android without success. The root cause was not the browser; address connectivity and flashing instead. [Elektroda, lisulisu6, post #18468162]
What’s an alternative Wi‑Fi AVR ISP if esProg doesn’t fit my needs?
Try ESP‑Link by JeeLabs with built‑in STK500 support. Flash ESP‑Link, connect it to your LAN, install a TIBBO virtual COM on PC, map IP and port, and use it like a serial programmer. [Elektroda, kaczakat, post #18468747]
