IP 20 Lamp: Suitability for Bathroom Use Above Geberite - Safety & Installation Guidelines
Dzionek95 29655 7
  • #1 18522745
    Dzionek95
    Good morning,
    I have a quick question regarding whether the IP20 lamp can be used in the bathroom. Place above geberite:
  • #3 18522862
    Dzionek95
    Yes, I have read and many others. However, I am placed against the wall, because it is not available with IP 44 and it is only available with IP 20, hence the question is whether there can be any problems with the fact that such a lamp will hang over the geberite. Droplets rather impossible to reach the lamp as it is higher and to the right of the sink.
  • #4 18523748
    Lab75
    Electrician specialist
    Help: 184
    Rate: 543
    jerry1960 wrote:
    Read this article ...
    ... which is worthless because it contains outdated information. The current standard defines a smaller number of zones and modifies the requirements for them.
    @ Dzionek95 - What does "over Geberit" mean to you? On the ceiling, on the wall? It would be good to know something more. Any plan of this room (top view, place of mounting the luminaire)?
    The topics on this forum that I propose to read:
    1. https://www.elektroda.pl/rtvforum/topic3663827.html
    2. https://www.elektroda.pl/rtvforum/topic3656360.html
  • #5 18528819
    retrofood
    Help: 1140
    Rate: 4798
    Dzionek95 wrote:
    Strictly droplets rather impossible to reach the lamp
    Of course, you do not count the ones created from water vapor. This is not water according to you? And I even saw it flowing on surfaces such as mirrors, lamps ...
  • #6 18535120
    rafael99
    Help: 9
    Really, no seller should offer lamps below IP44 for the bathroom, because it always carries some danger. But it is known that even before the LEDs in the bathrooms, we had ordinary light bulbs and that was the gun. Certainly the subject to consider whether we want to do everything according to patterns or not. I generally think that nothing should happen with such a lamp.
  • Questioning whether an IP20 lamp can be upgraded to IP44
    #7 19432183
    MorsikOWA
    Level 4  
    Hello, there will be a layman's question. Can the IP20 lamp be converted to IP44? (add some protections / fillings / cover tightly with the preparation for impregnation). For the bathroom, I need a living room lamp. Salon lamps are not available in the IP44 class, so I have to organize it on my own. The lamp will be several dozen cm above the sink faucet (vertically) and 150 cm (horizontally) from the bathtub faucet. I am asking for comments.
  • IP20 fixture cannot be safely converted to IP44
    #8 19432424
    Lab75
    Help: 184
    Rate: 543
    Can not. Lighting fixtures are designed and constructed to meet the expected / required degree of tightness (in accordance with the design assumptions). It is practically unrealistic to change the structure of the luminaire in a house-based manner in a way that ensures a higher degree of resistance to dust or water penetration (e.g. from IP20 to IP44). What's more, by making such a modification, you become the manufacturer of this product and you are responsible for the safety of its use. Have you ever wondered how, after such a modification, you will verify if the luminaire is really resistant to water penetration?
    Ps. The PN-HD 60364-7-701: 2010 + A11: 2012 + A12: 2017-10 standard does not prohibit the installation of a lighting fixture with IP20 tightness in a room equipped with a shower / bath, provided that the requirement to fix it outside the designated zones is met. Please see the links I have provided above.
The discussion centers on the suitability of using an IP20 lamp in a bathroom setting, specifically above a Geberit installation. Users express concerns about the safety of using an IP20-rated lamp in areas prone to moisture, as the standard recommendation for bathroom lighting is IP44 or higher. Some participants argue that while IP20 lamps can technically be installed outside designated wet zones, they pose risks due to potential water vapor and splashes. Others inquire about modifying an IP20 lamp to achieve IP44 standards, but it is clarified that such modifications are impractical and could compromise safety. The consensus leans towards caution, emphasizing adherence to safety standards and the importance of proper installation away from moisture-prone areas.
