Which Bluetooth module should I choose?
piotr3332 765 3
  • #1 18523452
    piotr3332
    Welcome,
    I need to select a Bluetooth module(4.2 or 5.0) for use with direct skin-to-skin contact. The device will connect to the phone.
    I am mainly concerned with the best possible signal stability.
    Price is also important. I was wondering about the MDBT42Q. Can you recommend something better?
    TvWidget
    Help: 472
    Rate: 699
    What does "for use with direct skin contact" mean in this case ?
    The mode when "the device will connect to the phone" requires more power consumption. Have you thought this through correctly ?
  • #3 18523763
    piotr3332
    This means that the device will be mounted on an arm, for example.
    I am just now at the stage of choosing a module where signal stability is most important. I am aware of the higher power consumption.
    TvWidget
    Help: 472
    Rate: 699
    What amounts of data and how often do you want to transmit?
    All conductive materials such as the human body in the vicinity of the antenna can significantly affect its performance. The antenna should therefore be as far away from the skin as possible.
