How do I send a message from the ESP32 to a specific IP over WiFi?
madiz08 1524 7
  • #1 18544511
    madiz08
    Rate: 172
    Code: C / C++
    I can, using the above commands, send a reply back to the sender. In the above case, that message would be " return text1 ".
    What I don't know is how to initiate sending a message via wifi to a specific IP address.
    Let's say I want to send "perform_task_1" to a device with address 192.168.0.99, something like:
    192.168.0.99/wykonaj_zadanie_1
    Normally I do this in reverse order by sending something like this to the ESP32 and in response I use client.println(); ( WiFiClient), but now I'd like to do it the other way around, on the principle that the ESP32 sends a message and receives an acknowledgement
    ekrzychoooo
    Help: 24
    Rate: 73
    madiz08 wrote:
    to the device with address 192.168.0.99
    This device should be the server. This can be done in a number of ways see Link .
  • #3 18544629
    madiz08
    Rate: 172
    I don't think so, after all it is a wifi client in this link. i.e. when something comes into the ESP32 and the ESP32 responds, and I would like it to be the ESP32 that initialises the sending of the data
    Added after 18 [minutes]:
    But anyway my phone with address 192.168.0.99 must be the server? In that case, I think it would be more convenient to do it on the basis of continuous polling of the ESP32, and when the feedback is as expected, further actions will be performed.
    In general, I have several modules at home for suppli, light, blinds, etc., which can be activated via appropriate links. I also have a voice recognition module. I wanted the phone to be voice activated (via esp32 which has this voice module). The phone then activates voice listening and already accepts a specific command
    ekrzychoooo
    Help: 24
    Rate: 73
    For the sake of this discussion, I think it is necessary to name these devices, because there will be a lot of misunderstandings
    - ESP_A device receives an http request and, based on that, performs an action - server
    - ESP_B device sends an http request - client
    and now: on device A there should be a server-type soft
  • #6 18545594
    madiz08
    Rate: 172
    Well, yes, Bluetooth! I'm going to sit down to this topic right away!
  • #7 18545629
    TvWidget
    Help: 472
    Rate: 694
    madiz08 wrote:
    Well, Bluetooth! I'm going to sit down to this topic right away!
    The main problem you'll encounter is forcing the app to work when the smartphone goes to sleep. Newer versions of the Android system have more restrictions in this respect.
    LED5W
    Help: 264
    Rate: 162
    If this has to be handled by the browser then the simplest solution is long polling. Another way is to use WebSocket. There is also Push API , but still in experimental version.
    In any case, you have to send something every now and then to check if the connection is broken. You have to send from the browser, because only the browser can make the connection, it cannot be the server.
✨ The discussion revolves around sending messages from an ESP32 device to a specific IP address over WiFi. The user seeks to initiate communication from the ESP32 to a smartphone at IP 192.168.0.99, sending a command like "perform_task_1". Responses clarify that the ESP32 can act as a client, sending HTTP requests to a server (the smartphone), which must be set up to listen for incoming requests. Suggestions include using long polling, WebSocket, or Bluetooth Low Energy (BLE) for communication. Concerns about smartphone security and app functionality during sleep mode are also raised, emphasizing the need for a reliable connection method.
