Vorwerk Thermomix TM5: Addressing Cook-Key Functionality Issues - User Experiences
jubiler 48351 14
How can I fix a Thermomix TM5 Cook-Key that is not being recognized or does not work correctly?
Yes—the most concrete workaround in the thread is to disconnect the Cook-Key, open "Recently cooked," select a recipe so the TM5 asks for the key, then reconnect the dongle and resync; after that, the network search and recipe opening worked again [#18680262] If that does not help, another user fixed the Cook-Key read/boot problem by removing the front panel (12 T15 screws) and cleaning the screen and motherboard connectors with electrical contact cleaner (WD40 Specialist Contact Cleaner) [#19624116] Factory reset did not solve the issue for the original poster, and if the key still fails after these steps the advice was to use service/warranty because the Cook-Key itself may be faulty [#18582611][#18627059]
  • #1 18582596
    jubiler
    Rate: 28
    I have the following problem with my Thermomix TM5:
    Has anyone encountered something similar?
    Does anyone know a solution to this Cook-Key problem?
  • #2 18582611
    humbel
    Help: 84
    Rate: 198
    Have you tried restoring the thermomix to factory settings?
    Before purchasing Cook-Key, did you have any additional book "buttons"?
    If so, check if they cause the same problem.
    If not, the problem is with the Cook-Key.
    It`s best to return it under warranty if you still have one, there`s probably nothing you can do about it.
    Well, unless factory reset helps.
  • #3 18582667
    jubiler
    Rate: 28
    I did a factory reset but it did nothing.
    I had the Cook-Key right away and I didn't hear about any "buttons" unfortunately.
  • #4 18627059
    admax71
    I have exactly the same problem with cook-key. Restarting TM5 did not help.
    I have two regular recipe tablets and they work fine, so the cook-key is definitely to blame.
    Have you found out what causes this behavior?
  • #5 18627190
    jubiler
    Rate: 28
    Not yet. I`ll take it to the service center, but I won`t be able to do it myself.
  • #6 18670955
    manjek1
    I have the same problem today, what could be the reason? It`s no coincidence that something like this happens to multiple users at the same time.
  • #7 18670997
    jubiler
    Rate: 28
    I`m 99% sure this problem occurs after enabling updates.
    I`ve had such a problem before and the service said it was either "cleaning" the jug or the motherboard was damaged. Fortunately, they cleaned it for PLN 100 and it worked... until the next update, I guess.
  • #8 18671061
    manjek1
    Well, after updating the software, but now it doesn`t read the key at all, the device rejects it, so it can`t clean it yourself.
  • #9 18671067
    jubiler
    Rate: 28
    Either way, it probably won`t be possible without the service.
    I have now spoken to the service center in Krakow and the nice lady insists that the power supply or motherboard is to blame. It`s a bit strange, because you can cook normally, but without using this crap (COOK-KEY).
  • #10 18678995
    Bombelek2020
    Rate: 68
    Two days ago, there was an update in this video from above, and I see that there is a solution.
  • #11 18680262
    Bombelek2020
    Rate: 68
    Well, I found a solution to this problem that does not require disassembling the equipment, I hope it is universal. After disconnecting the key, I went to the recently cooked menu. I clicked on the name of one of the recipes. Then the device displayed the command to connect the key. After connecting the dongle, everything works fine: the network search was successful. Then, when I click on the sync symbol, it takes a little longer than normal, but successfully. The newly added recipe and others open correctly.
  • #12 19312139
    marekjak
    Rate: 36
    Has anyone had a problem with the NETWORK CONFIGURATION icon missing?
    For me it doesn`t display, it doesn`t read the cook-key, it doesn`t read the ABC media. I can`t connect to Wi-Fi.
  • #13 19618886
    TomitO
    Rate: 9
    It's the same for me, error C513.
    Has anyone managed to do anything about it?
  • #14 19619069
    suhotnik
    Rate: 18
    I managed it myself. I updated and reset several times. Finally, I took the Thermomix next to the router and it worked straight away. I think the Wi-Fi signal was too weak before.
    It`s been working ever since :)
  • #15 19624116
    FilippoPittarello
    Rate: 10
    I solved the problem with the Cook-Key that was preventing boot-up.
    It was only necessary to disassemble the front panel (12 screws with T15 head) and clean with a spray for electrical contacts (WD40 Specialist Contact Cleaner) the connectors that connect the screen and the one attached to the motherboard.
    Harder said than done.
    While I was at it, I also sprayed the potentiometer.
    Cook-Key problem solved and the potentiometer runs without skipping any more numbers.
    I've read that this procedure (10 minutes and 10€ for the spray) often solves also the problems of the scale (in this case you must also spray the contacts that receive those of the mug).
✨ The discussion revolves around issues with the Cook-Key functionality on the Vorwerk Thermomix TM5. Users report problems such as the device not recognizing the Cook-Key, missing network configuration icons, and error codes like C513. Suggested solutions include performing a factory reset, checking for software updates, and ensuring a strong Wi-Fi signal. Some users have successfully resolved issues by cleaning internal connectors or taking the device to a service center. A workaround was also shared, where disconnecting the Cook-Key and accessing the recently cooked menu allowed for successful reconnection. Overall, the consensus indicates that the Cook-Key may be the source of the problems, with various troubleshooting steps discussed.
TL;DR: A 10-minute, 12-screw contact-clean fixed TM5 Cook-Key failures for one user; "Cook-Key problem solved." This FAQ explains practical ways to restore TM5 Cook-Key detection and syncing. [Elektroda, FilippoPittarello, post #19624116]
Why it matters: TM5 owners losing guided cooking after Cook‑Key errors need fast fixes to restore recipes and sync.
Is the TM5 Cook‑Key not being read a known issue?
Yes. Another TM5 owner reported the same Cook‑Key detection failure. Their two recipe tablets still worked, pointing to the Cook‑Key. [Elektroda, admax71, post #18627059]
Does a factory reset fix TM5 Cook‑Key problems?
A factory reset did not help in the original case. Try it first to rule out software glitches, then move to the steps below if nothing changes. [Elektroda, jubiler, post #18582667]
How can I trigger a Cook‑Key sync if it won’t connect?
Use the Recently Cooked method. 1. Disconnect Cook‑Key. 2. Open Recently Cooked and tap a recipe; connect when prompted. 3. Plug in Cook‑Key and wait for network search, then Sync. The sync may take longer but completes. “After connecting the dongle, everything works fine.” [Elektroda, Bombelek2020, post #18680262]
Can weak Wi‑Fi cause error C513 or failed updates?
A weak Wi‑Fi link blocked updates in one case. Moving the TM5 next to the router restored updates immediately. “I took the Thermomix next to the router and it worked straight away.” [Elektroda, suhotnik, post #19619069]
Why is my Network Configuration icon missing and nothing reads?
One user saw the Network Configuration icon disappear, with no Wi‑Fi and no media detected. Treat this as a system edge‑case. Work through connectivity checks and try the connector‑clean approach described elsewhere in this FAQ. [Elektroda, marekjak, post #19312139]
How do I clean the TM5 connectors safely to fix Cook‑Key?
Power off and unplug. Remove the front panel (12 T15 screws). Unplug and clean the display and mainboard connectors with a contact cleaner, then reassemble. The report notes ~10 minutes and ~10€ for spray. “It was only necessary to disassemble the front panel and clean … the connectors.” [Elektroda, FilippoPittarello, post #19624116]
My TM5 rejects the Cook‑Key completely — any options?
If the TM5 rejects the key, the device will not read it. On‑device cleaning or syncing is unavailable. Use the connector‑clean method in this FAQ or contact service for inspection. [Elektroda, manjek1, post #18671061]
How do I tell if the fault is the Cook‑Key or the TM5?
Test other media. One user’s two recipe tablets worked while Cook‑Key failed. That points to a faulty Cook‑Key, not the base unit. [Elektroda, admax71, post #18627059]
Can I still cook on TM5 without Cook‑Key?
Yes. You can cook normally without Cook‑Key attached. Guided recipes and Wi‑Fi syncing remain unavailable until connectivity is restored. [Elektroda, jubiler, post #18671067]
Did a software update break my Cook‑Key?
In one case, the TM5 stopped reading Cook‑Key right after a software update. The device then rejected the key, preventing on‑device cleaning. [Elektroda, manjek1, post #18671061]
What will Thermomix service say if Cook‑Key fails?
A service center suggested a power supply or motherboard issue, even though the unit still cooked normally. That complicates diagnosing a Cook‑Key‑specific fault. [Elektroda, jubiler, post #18671067]
How much might a service cleaning cost?
One user paid about PLN 100 for a service cleaning. It restored operation, but the issue recurred after the next update. [Elektroda, jubiler, post #18670997]
