Sofar Inverter Wi-Fi Module Connectivity Issue: Successful Connection but No Internet Access
Skipel 43716 20
Why does my Sofar inverter Wi‑Fi module show connected with no internet, and how do I finish connecting it to the mobile app?
To connect it, join the logger’s AP, open 10.10.100.254, log in with admin/admin, use the Wizard to enter your home Wi‑Fi password, and set the inverter address to 01; if needed, power-cycle DC first and then AC [#18627198][#18628680][#18628499] The “connected, no internet” message is not necessarily a fault, because the AP is only for configuration and may not provide internet access itself [#18626952] If the logger still does not see the inverter or the AP is missing, the Wi‑Fi module may need a reset or reseating; one user fixed it by opening the inverter and pressing the tiny RESET point on the internal Wi‑Fi board, after which the AP appeared and setup completed in the Wizard/Solarman page [#19424317] Another practical tip was to try a different phone and temporarily relax Wi‑Fi security or router restrictions such as DHCP/firewall limits during setup [#18627159]
  • #1 18616939
    Skipel
    I am trying to connect the inverter to the mobile application, but the attempts fail. It seems to me that the problem may lie on the Wi-Fi side of the inverter, because connecting to it normally connects but there is a message: "connected, no internet". I should add that the router itself is in the same room as the inverter, and this would not be a problem with insufficient Wi-Fi signal. I had "professionals" from the company installing the entire installation and they themselves do not know where the problem is, maybe you guys can help me, because the company has been pissing me off since February and are not willing to make further attempts to connect this inverter....
    Thank you in advance!
    • Sofar Inverter Wi-Fi Module Connectivity Issue: Successful Connection but No Internet Access Screenshot_20200414-132952~2.png (44.2 KB) You must be logged in to download this attachment.
  • #2 18626952
    Janek1506
    Rate: 14
    I have the same problem,but there is no one wise for this .In the picture you show that there is no Internet and that's good because it seems to me that the AP 123...is not a hot spot is just something that connects to the Internet.I have already done everything I can tell you that you can try to set on the folowing in Sitings under the number 9 Address - number 01 because supposedly it helped some people -- me not. Supposedly then the Wi-Fi icon is supposed to appear on the screen. I try to contact the distributor and he of course washes his hands and although it is a wholesaler they suggest that it may be a problem of the ISP .I will add that it is a poor byte. I will visit them again soon, because of course they no longer answer the phone.Simply married me with the wrong goods about which they know .I would also like to add that these companies which have recently started trading and installing PV do it very often and I know it for sure. Simply one customer realized that it works badly so they pack and install it at another. and then they go on a delay.
  • #3 18627159
    Akitigra
    Try from another phone. In my case it helped as I did from an Iphone and not from an android.
    Lose Wi-Fi security for a while (encryption, password, maybe there is a limit on DHCP, router firewall, etc) and see if it won't pass Wi-Fi configuration.
  • #4 18627198
    Janek1506
    Rate: 14
    You should in this case connect to the AP .1234 then enter the address 10.10.100.254 then enter admin admin and I am already in Dataloger although without internet ! Next we browse Wriles if it sees our home network it is good . Then we press Wizzard and do what it says there we enter the password for our home Wi-Fi we press next -further -further and further and it logs us out and connects to our home Wi-Fi .Then we enter our Wi-Fi by entering 192.168.1.1 and admin admin we find the assigned IP address of the dataloger e.g. 192.168.1.2 we open the next page of the browser and type this address in the bar .If we enter through our home router to the datalogger we will see the same thing as we saw something there we press and watch and if to watch it means that it connects correctly, but it does not mean that the datalogger connects correctly to the Inverter in which it is embedded.
  • #5 18628499
    AT PRO
    Help: 63
    Rate: 189
    Janek1506 wrote:
    I've already done everything I'll tell you that you can try to set on the folio in Sitings under the number 9 Address - number 01 because supposedly it helped some people --I didn't. Supposedly then the Wi-Fi icon is supposed to appear on the screen.
    This I confirm set you need 01.
    The rest of the steps I described here: https://www.elektroda.pl/rtvforum/topic3682979.html#18628489
  • #6 18628626
    Janek1506
    Rate: 14
    In my case everything is done as you wrote .Of course I connect to the datalogger already from the home router and I go in and can poke around in the datalogger menu , but the datalogger does not see the inverter and in the address on the inverter I enter 01 and still nothing .The Wi-Fi icon should show up on the inverter display but it does not appear and here is the problem.
  • #7 18628680
    AT PRO
    Help: 63
    Rate: 189
    In the inverter you need to enter 01, turn off AC and DC power and then turn on DC, then you can and AC.
    From the router, do not enter the datalogger. In my case, it also did not see. It only sees on the direct connection of the laptop to the datlogger.
    Do a reset and start from the beginning. And I only made an account on solarmanpv.com when I added the router to the datlogger.
  • #8 18628697
    Janek1506
    Rate: 14
    So tomorrow I will do as you write and what about solarman the account is already set up and the datalogger entered correctly We will see tomorrow for now thanks .
  • #9 18629794
    Skipel
    Janek1506 try to connect the inverter to the internet provided by the phone and set it to 10.10.100.254
    If it surprises you it means that you have blocked ports in the roueter and therefore can not connect. You will have to call your provider and tell them to unblock all of them for you preferably.
    Here you have a link to my other topic where together we found the cause:
    https://www.elektroda.pl/rtvforum/posting.php?mode=solution&t=3682979
    I think you will have the same problem as me. Greetings
  • #10 18634126
    Janek1506
    Rate: 14
    Understands .I will turn on the so-called hotspot on the phone then turn off the Wi-Fi on the phone and go to the laptop there I will connect to Sofar and have him connect to the phone of course if he sees it But that's tomorrow when I get back from work Thanks for now, until tomorrow.
    You know this link does not work. It says that I have to be the author to use this link.It is probably attributed to you.
  • #11 19138119
    Messigol
    Hello and how was the problem solved ? I have the same thing that they connected without internet :/.
  • Wired module and fixed IP solved access issue
    #12 19148767
    zbysob
    This may not be very helpful but I replaced the Wi-Fi module with a wired module (for bhp I have a net installation in my house "on cable" because with Wi-Fi there were problems ) the company installing the inverter replaced the module without any problem at no extra charge and after setting a fixed IP for the inverter I have no problem with access both through the application and directly through the browser.
  • #13 19150883
    Skipel
    Hello, so far the problem has not been solved.
    Added after 19 [minutes]:
    Janek1506 wrote:
    I understand .I will turn on the so called hotspot on the phone then turn off the Wi-Fi on the phone and go to the laptop there I will connect to Sofar and have it connect to the phone of course if it sees it But that's tomorrow when I get back from work Thanks for now, see you tomorrow.
    You know this link doesn't work. It says that I have to be the author to use this link.It is probably assigned to you.
    How is it with your inverter mate? Did you solve the problem?
  • #14 19163593
    buli117
    Tell what letter 4 you have on the serial number of the sofar nameplate.
  • #15 19164686
    theo33
    Help: 78
    Rate: 321
    " E" in seven inverters
  • #16 19164953
    buli117
    If you have Plug-Pro3 on your qr then you will have trouble logging in but you Should not have any problems connecting but try on SmartClient
  • #17 19164959
    theo33
    Help: 78
    Rate: 321
    Then I see that you are referring to the SN of the wi-fi module and not the SN of the inverter
  • Service replaced the Wi-Fi module, but SSID is no longer visible
    #19 19423591
    Janek1506
    Rate: 14
    I will write a few words. Today we have 08.05.2021 inverter returned from Warsaw from service. Because at some point it hung up and the green light was flashing. A very nice lady sent a courier. I of course prepared the package the day before because the courier appeared like lightning just out of the blue. The inverter was quickly repaired and after just 3 days it was in Rzeszow at my home. Now it works tz. produces, but now I can not see wi fi on my laptop and the address set to 01 in the inverter. Before it saw under the name AP ......something there now the laptop can't see this wi fi. Before this wi fi couldn't see the inverter (datalogger) now the laptop can't even see wi fi in the datalogger. How to solve this I don't know. Supposedly in the service (warranty) they put a new wi fi module on me.
  • #20 19423639
    slawo12311
    Level 19  
    Help: 35
    Rate: 87
    Make sure your laptop is close enough to the logger. If it is then perhaps this logger has a setting that it does not broadcast its network name. You can try resetting it to factory settings by holding the RESET button for at least 10 seconds.
    Here are the instructions: https://viteco.pl/wp-content/uploads/2020/02/INSTRUKCJA_DATALOGER_WI_FI.-SOFAR_SOLAR_.pdf
  • Resetting the internal Wi-Fi module restored connectivity
    #21 19424317
    Janek1506
    Rate: 14
    Hello Here are the findings - It worked! This morning I disassembled the inverter. The first time with the cables disconnected. There in the middle is a socket and in this socket a board with the inscription Wi Fi CE No SN 4242.......69 etc dimension 1.5 cm *2 cm. I pressed it well into the pins I took a photo and screwed it up. I turn it on and nothing I enlarge the photo on my smartphone and there is a micro plate with the signature reset and another upload. I unscrew the inverter again because this Wi Fi is in this form inside the inverter, only a micro plate with a cable as an antenna. I unscrew this time under voltage I tilt the front panel and touch the reset spot with a small screwdriver and at this point the Wi Fi icon appears on the front. Next laptop search in networks AP 4242......itd Wizard OK Next the inverter appears further Solarman page and it works! In a word I had to disassemble although it is under warranty. I screwed everything together and it is OK Regards.
Users are experiencing connectivity issues with the Sofar inverter's Wi-Fi module, successfully connecting to the inverter but receiving a "connected, no internet" message. Various troubleshooting steps have been suggested, including adjusting settings on the inverter, connecting through different devices, and checking router configurations. Some users recommend resetting the inverter and ensuring proper connections to the datalogger. Others have resolved issues by switching to a wired connection or replacing the Wi-Fi module. A few users have successfully connected by disassembling the inverter and resetting the Wi-Fi module directly. The discussion highlights the frustration with professional installation services and the need for effective communication with internet service providers regarding potential port blocking.
TL;DR: A 10‑second reset often revives Sofar Wi‑Fi modules—"hold the RESET button for at least 10 seconds." Then reconnect and reconfigure the logger’s Wi‑Fi to restore monitoring. [Elektroda, slawo12311, post #19423639]
Why it matters: For Sofar inverter owners seeing “connected, no internet,” this FAQ shows how to configure, reset, or replace the module so monitoring works again.
How do I fix “connected, no internet” on a Sofar inverter?
Connect to the Sofar AP_xxxx, open 10.10.100.254, and log in with admin/admin. Run Wizard, pick your home SSID, and enter its password. After it switches to your router, reconnect your phone to home Wi‑Fi and use the app. This completes internet setup through your router. [Elektroda, Janek1506, post #18627198]
How do I access the datalogger setup page?
Use this quick setup: 1) Connect to the inverter’s AP_xxxx, browse to 10.10.100.254, and log in as admin/admin. 2) In Wireless, run Wizard, select your home SSID, and enter the password to join. 3) In your router (e.g., 192.168.1.1), find the logger’s assigned IP and open it to manage settings. [Elektroda, Janek1506, post #18627198]
The inverter shows no Wi‑Fi icon after joining my Wi‑Fi—what setting fixes it?
On the inverter, set Address to 01 in Settings. Then power‑cycle: turn off AC and DC, turn on DC first, then AC. The Wi‑Fi icon should appear once the link forms. "enter 01, turn off AC and DC power" is the key guidance here. [Elektroda, AT PRO, post #18628680]
I can’t see the logger’s AP_xxxx network. How do I bring it back?
Stand close to the logger. The SSID may be hidden. Perform a factory reset: "hold the RESET button for at least 10 seconds." After the reset, the AP_xxxx should broadcast again so you can reconfigure Wi‑Fi. [Elektroda, slawo12311, post #19423639]
After service, the AP still doesn’t show—what hardware check helped others?
One user reseated the tiny internal Wi‑Fi board and tapped the marked reset pad. The Wi‑Fi icon appeared on the inverter, the AP_xxxx reappeared, and setup completed successfully. This resolved an AP visibility issue after module replacement. [Elektroda, Janek1506, post #19424317]
How can I tell if my ISP or router is blocking the logger?
Join the logger to a phone hotspot and test the app/portal. If it works on mobile data but not your home router, the ISP/router is blocking required ports. Ask your provider to unblock the ports for the logger. [Elektroda, Skipel, post #18629794]
Does the phone I use for setup matter?
Yes. Try a different phone. One user succeeded with an iPhone after Android failed. Temporarily relax router protections during setup if needed. Reduce Wi‑Fi security, check DHCP limits, and review firewall rules to allow the logger to join. [Elektroda, Akitigra, post #18627159]
Can I manage the logger from my home network after it joins Wi‑Fi?
Yes. Open your router admin, find the logger’s assigned IP (e.g., 192.168.1.2), and browse to that address. You’ll see the same admin panel you used on the AP. This helps verify ongoing connectivity. [Elektroda, Janek1506, post #18627198]
The datalogger page loads, but it doesn’t see the inverter. Is that normal?
It can happen. One user could browse the logger from the router, yet the logger didn’t detect the inverter and no Wi‑Fi icon appeared. This indicates the inverter‑to‑logger link is still not established. [Elektroda, Janek1506, post #18628626]
How do I reliably link the inverter and logger after that?
On the inverter, set Address to 01. Power down AC and DC, then power up DC first, followed by AC. This sequence initializes communication and brings up the Wi‑Fi icon. "enter 01" and power‑cycling solved the link for others. [Elektroda, AT PRO, post #18628680]
Is switching to a wired module worth it if Wi‑Fi keeps failing?
Yes, it can improve stability. One installer swapped the Wi‑Fi module for a wired Ethernet module at no extra charge. After assigning a fixed IP, access via app and browser worked reliably. Consider this if wireless remains unstable. [Elektroda, zbysob, post #19148767]
Do I need a SolarmanPV account before configuring the logger?
No. You can configure the logger’s Wi‑Fi first. One user created the Solarman account only when adding the router to the logger. The account is for monitoring after connectivity is set. [Elektroda, AT PRO, post #18628680]
Which app should I use if Plug‑Pro3 login fails?
If your QR mentions Plug‑Pro3 and login gives trouble, try SmartClient. Users reported connection works, but login can be finicky with Plug‑Pro3. Switching apps can complete setup. [Elektroda, buli117, post #19164953]
The app asks for a serial number—logger or inverter?
It refers to the Wi‑Fi module’s serial number, not the inverter’s SN. Check the module label or QR on the Wi‑Fi dongle/board. Use that when the app requests SN. [Elektroda, theo33, post #19164959]
Who can I contact for official Sofar support in Eastern Europe?
Use Sofar Solar Poland’s contact page for regional distribution support and ticketing. They handle devices from the Eastern Europe channel. [Elektroda, buli117, post #19164971]
How fast can service resolve a faulty module?
A real‑world report showed a rapid turnaround. The inverter went to Warsaw service and was back in Rzeszów in three days after repair. If connectivity still fails afterward, repeat setup or a module reset. [Elektroda, Janek1506, post #19423591]
