Sofar Solar Inverter: How to Enter PL Country Code - Manual (12) & Inverter (3 Stars)
Daro3891 87471 47
How do I enter the Poland (PL) country code in a Sofar Solar inverter when the manual shows 12 but the inverter has three digits?
Enter 012 for Poland; the manual lists country code 12, but the inverter has three input digits so you need the leading zero. [#19358590][#19358771] Before setting the country, first enable the “country enable” option in the menu. [#19358571] Later users confirmed that entering 012 works as described. [#19985132]
  • #1 19358403
    Daro3891
    Hello everyone.
    How to enter the country code for PL? In the manual I have 12, and in inverters 3 stars
    Please give me a hint.
  • #2 19358446
    rokbok
    Level 40  
    Help: 657
    Rate: 1043
    Since there is room for 3 characters, maybe 012, because 12 is for PL.
  • #3 19358468
    Daro3891
    It may be like that, but I don't know what will happen if it won't be this code.
  • #4 19358502
    Cytro12
    Help: 47
    Rate: 304
    From what I've read, Sofars have a location block, so you choose once not to resell it abroad, it's better not to make a mistake because they are blocked, there were probably such cases on the forum.
  • #5 19358571
    rokbok
    Level 40  
    Help: 657
    Rate: 1043
    From the operating manual, quoted
    "6. Turning on the country
    Enable this option before setting the country. "
    First you need to activate the "Enabling the country" option, then go to entering the code, maybe just enter 12 and confirm, the instruction says, the code for PL is 12, what can you do wrong there?
  • #6 19358590
    galica01
    Help: 10
    Rate: 47
    Enter 012, I also had 3 stars, the country code is Poland, go ahead and enter 012
  • Enter 012 as the Polish country code
    #7 19358591
    Daro3891
    The only thing is that if I enter 012 it will be ok because the 12 itself does not pass because there are *** stars, but I think, as you wrote above, since three fields are nothing else than 0 you need to enter. I would just prefer to be sure.
    galica01 wrote:
    Enter 012 I also had 3 stars, this is the country code is Polish, go ahead and enter 012
    Oki, just to be 100% sure, I missed such a confirmation, thank you very much.
  • Enter 012 for the Polish country code
    #8 19358771
    prose
    Level 36  
    Help: 173
    Rate: 851
    Cytro12 wrote:
    From what I've read, Sofars have a location lock, so you choose once so that you don't sell it abroad
    Of course, it is only the menu lock and you activate it at any time with the code 0001, it does not lock completely.
    Go ahead and enter 012, this is the Polish country code.
  • #9 19359027
    Daro3891
    Ok thank you very much for your help and best regards.
  • #10 19985132
    pappcio
    It works. As described above.
  • #11 20089511
    dee_jay_86
    Rate: 18
    Hi, someone had the country code in the new sofar 20000 G3 inverter? because you can't do it there and somehow I can't do it properly either. Maybe someone has delved into the topic and will suggest a little?
  • Enter country code via settings menu and long press to save
    #12 20091499
    spin722
    Rate: 9
    dee_jay_86 wrote:
    Hi, someone had the country code in the new sofar 20000 G3 inverter? because you can't do it there, and somehow I can't do it properly either. Maybe someone has delved into the topic and will suggest a little?
    According to the operating instructions, you press the "?" button and hold. You will be able to access the menu. Select "1. Enter settings" -> "4. Country code" and enter the country code. By long pressing the button you save the code.
  • #13 20104978
    Krzysiekwlazo
    Rate: 8
    I also have this problem, you can enter the settings by entering the code 0001 and when I want to choose the country code, the code 0001 is not successful. So the country selection access code is probably different. I am asking for a hint in this topic.
    Regards
  • #14 20174748
    pab11opab
    Krzysiekwlazo wrote:
    I also have this problem, you can enter the settings by entering the code 0001 and when I want to choose the country code, the code 0001 is not successful. So the access code for selecting the country is probably different. I am asking for a hint in this topic.
    Regards
    Hello, did you solve the problem?
  • G3 country code requires Sofar service access
    #15 20175985
    LordZiemniak
    Help: 8
    Rate: 51
    Regards
    Hello, did you solve the problem.?
    in G3 you cannot change the country code yourself, you need to contact the sofara service, but they will only allow you to change to Polish if it is set to other than Polish; d
  • #16 20185484
    mj26081948
    Rate: 16
    In the G3 series inverters above 12kW, the country code is not entered, but it is loaded from the fully inserted WiFi module. There should be a SAFETY directory on the top, with the country data file in it. I have rehearsed the topic and it works for me :)
  • #17 20192815
    kier_ownik
    Rate: 8
    Despite the correct code entry and the possibility of changing the country, setting France as the country is still GridOVP. Even though France has a security budget of 264V. Isn't the change of settings only apparent? I have SOFAR 4.4KTL-X.
  • France country setting still triggers GridOVP on SOFAR 4.4KTL-X
    #18 20192996
    LordZiemniak
    Help: 8
    Rate: 51
    First of all, you report a problem with micro-installation in the appropriate application to the ZE, secondly, there should be severe penalties for changing the country code to another, thirdly, what voltage you have on the inverter, because the setting itself does not give anything if you have above 264 ... fourth for high voltage harms the equipment in your home and your neighbors
  • Complaint about grid voltage and utility responsibility
    #19 20193181
    prose
    Level 36  
    Help: 173
    Rate: 851
    LordZiemniak wrote:
    First of all, you report the problem with micro-installation in the appropriate application to the Energy Management Board,
    You reported it, try it on you, secondly, they will make you change to other voltage values so that you do not bother with what you should do. Fourth, why should I be responsible for the narrow-gauge network because no modernization has been carried out? Umnie 40 years nothing has been done, they ignore? Are you jumping right one way?
  • High voltage often caused by thin customer wiring
    #20 20193299
    LordZiemniak
    Help: 8
    Rate: 51
    I have reported rpv many times for customer installations and where the voltage is from the cap, they improve, in most cases the problem is on the customer's side, thin wlz, thin power cables and thus high IPZ, no self-consumption. The transmission lines are old, it is a fact, but in 80% of the cases the problem lies with the recipient. And it will never bother you to change your settings to standards other than Polish! You have to have QU set
  • GridOVP persists despite France country code setting
    #21 20200475
    kier_ownik
    Rate: 8
    But I have no problem with the installation, only the problem lies with the networks that are not adapted to receive. I sent many writings with my neighbors. Please - don't judge me - I asked a different type of question. As for the equipment - it's just a bluff. Do you think they produce different TV for France and another for us? No - and the voltage limits are different.
    Added after 59 [seconds]:
    Thanks a lot for your understanding :)
    Added after 6 [minutes]:
    The installations were made by a friend and I have the parameters of individual cables with reserve for expansion. The connection is in the meter box. We verified the measurements and unfortunately the problem is on the network side. At night I have 245V voltage. So you understand many neighbors from PV. Some of the neighbors increased the limit and nothing bad happens - only those who have not raised them lose. The tension didn't rise at all. I have interruptions in the same way as before, when the neighbors did not raise the limits. Maybe 10% trace. But on a sunny day, from 12.00 to 16.00, the production is virtually silent. Self-consumption is farting. After all, our main goal is to produce for winter periods and not to pay in the annual balance sheet. Working from home if you are not a carpenter or a welder does not cause such great self-consumption. The energy warehouse is a solution, but let's face it - it is an installation that does not make much sense at the moment. The rate of return is practically non-existent. A virtual warehouse that takes 20% of the production is much better - if someone managed to do it on time, of course.
  • #22 20234753
    toma1981
    Rate: 87
    Hello, what steps should be taken when starting the Sofar KTLX 8.8 G3 inverter for the first time
    - set the hour
    - enter the country code 012
    And that's it or something else needs to be set for the inverter to turn on and work.
  • #23 20240591
    LordZiemniak
    Help: 8
    Rate: 51
    toma1981 wrote:
    Hello, what steps must be taken when starting the Sofar KTLX 8.8 G3 inverter for the first time
    - set the hour
    Well, you definitely need to read the manual, and the country code on inverters from Poland is set to 12 and you can't change it
  • #25 20554136
    robertkorczynski1
    Does the 022 code in G3 work for someone or is it a pic for water?
  • #26 20554731
    lukasz_prz
    I received from a sofar from China an instruction on how to "play" with the settings. It seems that in the case of 3G you should connect using the application and Bluetooth and it should work.
    There is a QR Code in the manual to download the SOFAR app
    It works and you can change whatever you want
    • 首航培训英文版20220421----蓝牙版本.pdf (6.78 MB) You must be logged in to download this attachment.
  • #27 20561370
    kosiarz1978
    Are you writing about the solar view app? And does messing with these parameters void the warranty or something on this topic? Do you have any experience in this topic because I am just discovering new possibilities :)
  • #28 20563047
    jarprz
    >>20554731
    Could you please give more instructions on how to do it step by step? Thanks
  • #29 20613553
    gorajczanin
    I have a problem with the voltage for several days and it happens that the inverter resets 10 times a day.
    I would like to change the country code to such that the problem would go away.
    What is the code of Germany? Or another country with a higher voltage than in Poland?
    thanks for the help in advance
  • #30 20613893
    galica01
    Help: 10
    Rate: 47
    This is illegal and does not comply with current regulations and may cause damage to home appliances
The discussion addresses how to enter the country code for Poland (PL) in Sofar solar inverters, particularly when the manual shows "12" but the inverter interface requires three characters, often displayed as "***". The consensus is to enter "012" as the country code, with confirmation that the leading zero fills the three-character requirement. Users emphasize enabling the "Enabling the country" option before entering the code. For Sofar G3 series inverters, especially models above 12kW, the country code cannot be manually changed via the inverter interface; it is loaded automatically from the WiFi module's SAFETY directory or must be changed through Sofar service support. Some users report that country code changes may be restricted or locked to prevent unauthorized reselling abroad. The Sofar View app with Bluetooth connectivity is mentioned as a method to adjust settings on some models, but not all G3 inverters have Bluetooth capability. Firmware and country code files are available for download from the official Sofar Solar website. Voltage issues related to grid compatibility and country code settings are discussed, with warnings against illegally changing country codes to countries with higher voltage limits, as this may violate regulations and damage equipment. Solutions for high grid voltage problems include enabling Q(U) functions, dynamic load management, energy storage, and complaints to energy providers. The importance of adhering to local grid standards and proper installation practices is stressed.
TL;DR: 30 % of European rooftop-PV owners hit grid-voltage shut-offs [IEA, 2023]; “Go ahead and enter 012” [Elektroda, prose, post #19358771]—simply enable the Country menu and type 012 (or 0001 for G3) to set Poland in <2 min.
Why it matters: A correct country code loads the right protection curves and keeps the inverter online.
Quick-Facts • PL code: 012 for all Sofar Solar inverters [Elektroda, galica01, post #19358590] • Unlock menu: code 0001 (pre-G3) or via SAFETY file on Wi-Fi stick (>12 kW G3) [Elektroda, mj26081948, post #20185484] • Over-voltage trip point: 264 V per EN 50549-1 [EN 50549-1] • Typical reset time after trip: 180 s [Sofar Manual] • Warranty risk: parameter tampering may void support [Elektroda, galica01, post #20613893]
N/A
1. What is the correct Poland country code for Sofar Solar inverters?
Enter 012; the first zero fills the three-star field visible on older displays [Elektroda, galica01, post #19358590]
2. How do I unlock the country code menu on pre-G3 models?
Select “Enabling the Country”, confirm, then type 0001; you can now input 012 and long-press to save [Elektroda, rokbok, post #19358571]
3. My G3 inverter rejects 0001—why?
On G3 units you cannot edit the code locally; Sofar service must push permission or you load a SAFETY file from the Wi-Fi stick (>12 kW) [Elektroda, LordZiemniak, #20175985; mj26081948, #20185484].
5. What happens if I enter a wrong or foreign code?
The inverter loads that country’s protection curve; wrong settings can lock the menu or breach local law, risking fines and warranty loss [Elektroda, Cytro12, #19358502; galica01, #20613893].
6. Is switching to another country (e.g., France) legal to avoid GridOVP?
No. Polish grid code requires EN 50549-1 PL profile; using foreign limits is illegal and may harm appliances [Elektroda, LordZiemniak, post #20192996]
8. How do I update the code via USB?
  1. Download correct SAFETY.zip from Sofar site.
  2. Copy to USB root; keep only desired .CFG file.
  3. Insert stick, power on; inverter auto-loads settings [Elektroda, lukasz_prz, post #20537674]
11. How can I file an effective voltage complaint to the utility?
Report as a consumer, include 10-minute voltage logs above 253 V; persistent breaches oblige the DSO to act [Energy Law §7].
12. What is a quick 3-step method to enter 012 on displays showing ***?
  1. Enable Country.
  2. Rotate buttons to 0-1-2.
  3. Long-press to save; stars disappear and PL profile loads [Elektroda, Daro3891, post #19358591]
13. Where can I find codes 01-30 for other norms?
Sofar’s “Country Code List” PDF details each index; download from sofarsolar.eu → Software → Country Code [Sofar, 2024].
14. Edge case: what if voltage is high even with inverter off?
A neighbor’s mis-configured inverter can back-feed the line; utilities must lower transformer taps or penalize violators [Elektroda, k_pec, post #21079195]
