[Solved] Title: Huawei B818 on Play Network: Best Antenna for 2600 LTE & 1.9 km BTS Distance
lalek63 14436 42
What external antenna should I buy for a Huawei B818 to improve Play LTE 2600 reception at 1.9 km from the BTS?
You probably do not need a new antenna yet; the B818 already shows very good LTE2600/LTE2100 signal, so the limitation is more likely BTS load and aggregation behavior than antenna gain [#18622885][#18686937] If you still want an external antenna, the thread recommends a dual-polarized MIMO antenna for 1800-2600 MHz, such as the Cybertech LTE-A 4G 17 dBi or a similar model, with the correct Huawei B818 TS9 adapters [#18645290][#18622905] Use a good low-loss 5 m cable such as LMR400, because connectors and RF cable losses on high bands can easily cost 1-3 dB or more [#18645756][#18644683] Test it in the evening hours and compare single-band results with LTEInspecteur or HManager; force LTE2600, LTE2100 and LTE1800 aggregation, and skip LTE800 because it is usually congested [#18645077][#18622885][#18645290] The thread’s conclusion was that the window-sill/no-antenna setup may already be close to optimal, so the best improvement may come from band testing and placement rather than changing antennas [#18686937]
  • #31 18646480
    lalek63
    Rate: 25
    Above are the photos, it follows from the same BTS
  • #32 18656356
    lalek63
    Rate: 25
    I ordered the antenna, cybertech 1800-2600, greetings and thanks.
  • #33 18684271
    lalek63
    Rate: 25
    I go back to the topic, I set up a cybertech 1800-2600 antenna and the speed was much worse than without the antenna and even with soresen. I aimed as best I could. What could be wrong?
    • Title: Huawei B818 on Play Network: Best Antenna for 2600 LTE & 1.9 km BTS Distance 2020-05-11_09h57_40.png (109.8 KB) You must be logged in to download this attachment.
    • Title: Huawei B818 on Play Network: Best Antenna for 2600 LTE & 1.9 km BTS Distance 2020-05-10_19h05_24.png (126.81 KB) You must be logged in to download this attachment.
  • #34 18686635
    lalek63
    Rate: 25
    and such a measurement in the morning. Take a look at the parameters and tell me what could be wrong with the antenna in terms of download speed. Upload speed has improved significantly,
    • Title: Huawei B818 on Play Network: Best Antenna for 2600 LTE & 1.9 km BTS Distance 2020-05-12_07h39_11.png (75.47 KB) You must be logged in to download this attachment.
  • #36 18695098
    lalek63
    Rate: 25
    okay gentlemen, I take the ladder off the roof, it stays as it is, but I still can't understand how the modem on the windowsill achieves higher speeds than the antenna. Pictures below at the same time.
    1. window sill, ground floor
    2nd antenna
    I thought that with the antenna it would raise to 150 maybe :(
    3. old antenna
    4. new antenna
    5. the tree that grows centrally in front of the mast, maybe it's because of it heheh :D
    I exhausted the topic, I thought it would be faster internet with an antenna than without.
    Added after 47 [seconds]:
    I will only check the last thing, but not today, I will go with the laptop to the attic, connect the cable to the router and check the speed, because from the router with the cable I have the net to the modem and from it in the chat and I found that with the modem about 20 mega faster than directly from the router, because the signal is weaker.
  • #37 18695159
  • #38 18695167
    lalek63
    Rate: 25
    TP-Link WR-841N
    _cheetah_ wrote:
    BTS trims you on DL on external antennas as a heavy-caliber heavy user, knowing how great you got on the antennas and how much you could pull off of them.
    You've been calling me from Play for a week now, and you'll hear it :)
    And how do they know what parameters I have, some habits from the previous years, they need to know everything heheh
    in the internet contract I have 300gb, which I am not even approaching, why are they cutting me?
  • #39 18695189
  • #40 18695193
    lalek63
    Rate: 25
    yes, with a router for wifi.
    but with this router it is so that now when you connect to it via wifi it is 20 less than after the modem, the wifi signal strength is 3/4 dash because it is on the ceiling
  • #41 18695200
  • #42 18695205
    lalek63
    Rate: 25
    ok, thanks, although I already know that I did the right thing mechanically, I just wanted to make sure that I did the best I could, I take the ladder off and let go of this topic from my construction site.
    Added after 36 [minutes]:
    buddy, you were very right, I connected the router to my laptop and measured the speed, and this is what I would like to have around the apartment
    will you tell me what can I improve?
  • #43 20143859
    lalek63
    Rate: 25
    I set up a cybertech LTE-A/LTE/4G/3G antenna in the 1800-2600 MHz band plus an Archer TX3000E and speeds of 300Mbs with a ping of 4-9.
✨ The discussion revolves around optimizing the internet connection using a Huawei B818 router with a Play Network LTE service, specifically at a distance of 1.9 km from the nearest BTS. The user initially experienced poor speeds with a chimney antenna and sought advice on a suitable antenna for LTE 2600. Various responses suggested using a dual antenna with oblique polarization for the 1800-2600 MHz range, along with necessary connectors for the B818's TS9 ports. The user reported mixed results after installing a new Cybertech antenna, experiencing lower speeds compared to the router placed on a windowsill. The conversation highlighted the importance of signal parameters, potential bandwidth limitations from the BTS, and the impact of environmental factors on signal quality.
TL;DR: At 1.9 km you already see ~100 Mbps download on the Huawei B818 stock antennas [Elektroda, Raycoreti, post #18622925] “Don’t buy a new antenna for now” [Elektroda, matek451, post #18622885] Add a dual-MIMO 17 dBi 1800-2600 MHz panel only for uplink boosts.
Why it matters: Correct kit selection stops you wasting €100-€150 on unnecessary hardware.
• Huawei B818-263: LTE Cat 19, 4×4 MIMO on band 7 (2 600 MHz), peak 1.6 Gbps [Huawei, 2020] • External ports: 2× TS9; pair of TS9-to-SMA pigtails ≈ 15 PLN [Elektroda, matek451, post #18622912] • Cybertech dual-17 dBi panel: 1800-2600 MHz, gain 12-17 dBi, price ≈ 249 PLN [Cybertech, 2023] • 5 m LMR400 coax attenuates ~0.6 dB at 2.6 GHz [Times Microwave, 2021] • Evening (19-22 h) Play LTE throughput can fall by 40-60 % versus morning [Elektroda, Range1, post #18645290]
1. Which antenna gives the best results for Play’s 2600 MHz band at ~2 km?
A dual-polarised 17 dBi panel covering 1800–2600 MHz (e.g., Cybertech) pairs well with the B818 and supports 2×2 MIMO aggregation of 2600 + 1800 + 2100 MHz [Elektroda, Range1, post #18645290]
2. Do I really need an external antenna at 1.9 km?
Probably not for download: internal antennas already deliver ~100 Mbps [Elektroda, Raycoreti, post #18622925] Add an outdoor panel only when you need a stronger, more stable uplink or roof-level installation.
3. What adapters and cable should I order?
Buy two TS9-to-SMA pigtails plus 5 m of low-loss LMR400; total link loss stays under 1 dB @ 2.6 GHz [Times Microwave, 2021; Elektroda, matek451, #18622912].
5. How do I test individual LTE bands on a Huawei B818?
Use LTEInspecteur or HManager.
  1. Select the router IP, click “Bands”.
  2. Tick only band 7, 3 or 1 and apply.
  3. Run a speed-test, record DL/UL, then repeat for each band. [Elektroda, matek451, post #18622885]
7. Could my TP-Link WR-841N be the bottleneck?
Yes. Its 100 Mbps LAN/WAN limits wired or Wi-Fi throughput to ~95 Mbps; bypass it when measuring >100 Mbps links [Elektroda, cheetah, post #18695189]
8. How should I aim a MIMO panel quickly?
Point the front face toward the BTS, then rotate ±10° while watching RSRP in LTEInspecteur; stop at the highest SINR. Tighten brackets once both polarised leads read within 2 dB of each other.
9. How can I verify if my self-crimped coax is still good?
Check DC continuity and short-to-shield with a multimeter [Elektroda, cheetah, post #18644683] If speeds fluctuate >20 %, inspect for kinks; even a 1 mm nick can raise loss by 0.5 dB on 2600 MHz.
10. What edge case gives perfect signal but slow speed?
Heavy evening congestion: RSRP −65 dBm and SINR 20 dB looked ideal, yet speed dropped below 40 Mbps because the BTS was saturated [Elektroda, Range1, post #18645290]
11. How much data can I burn on Play LTE plans?
Current Play contracts offer 300 GB base with +100 GB for 20 PLN; users rarely exhaust it when phones contribute 80 GB more [Elektroda, lalek63, post #18622929]
12. Will this 1800-2600 MHz antenna work for 5G?
It covers LTE bands 3/7 but misses 5G n78 (3.5 GHz). You’ll need a 3300-3800 MHz panel for full 5G later [“3GPP NR bands”].
