V and A led meter modification on HC32F003 chip (4 bit, 0-100V, 0-10A)
wsxcde 13557 20
  • A 4-digit Chinese 0–100 V/0–10 A LED panel meter was reflashed on its HC32F003 microcontroller to replace its unexpectedly slow factory firmware.
  • After SWD access initially failed and protected flash could not be read, the firmware was erased over serial using Linux and Python, then developed through SWD with J-Link.
  • The original meter promised updates three times per second but delivered less than once per second; the hardware was also modified for a 0–30 V range.
  • The replacement firmware delivers much faster, more accurate readings, and its measurement frequency is adjustable through flash.bin offset 0xBEE with values from 1 to 255.
  • The original protected firmware could not be recovered, so the meter required a complete firmware rewrite from scratch.
  • V and A led meter modification on HC32F003 chip (4 bit, 0-100V, 0-10A)
    Hello all.
    Some time ago I bought a LED current and voltage meter (4 bit, 0-100V, 0-10A) on the Chinese website. According to the description, it was to provide values with a frequency of 3 times per second. It turned out differently, i.e. he gave them less than once per second, which was unacceptable for my applications.
    The meter is built on the HC32F003 processor. On Chinese websites I found full documentation, SDK and utilities for this processor. I decided to play with him.
    Attempting to connect with the SWD connector has failed. This should have been done using the serial port. It worked, but the flash could not be read - it was secure. So one thing remained - delete the flash and write the software from scratch, which I also did. By the way, I modified the circuit to measure 0-30V. Wiring diagram:
    What difficulties did I encounter? A dedicated program did not detect my processor on any USB adapter - serial (I tried on PL2303 and CH340). The FlyMcu program detected the PL2303 chip, but I can't remember why I didn't use it to delete the chip (it didn't allow it?). Eventually, I deleted flash on a Linux computer with a Python program. Now I had full access to the CPU. I programmed and debugged it through the already active SWD port using J-Link (how to make a J-Link adapter with Blue Pill can be found in the network).
    As a result of my scribble (I am not a programmer) I have a meter that gives values very quickly and does it more accurately than on the original software. The measurement frequency can be modified by changing the byte in the flash.bin file under the offset 0xbee (in the range 1-255).
    Included software and flash batch.
    • hc.7z (540 Bytes) You must be logged in to download this attachment.
    • HDSC ISP V2.04.zip (664.08 KB) You must be logged in to download this attachment.
    • FlyMcu20191220.rar (730.11 KB) You must be logged in to download this attachment.
    • flash.7z (4.54 KB) You must be logged in to download this attachment.
    wsxcde
    wsxcde wrote 30 posts with rating 86, helped 2 times. Been with us since 2005 year.
  • #2 18773004
  • #3 18773120
    metalMANiu
    Help: 11
    Rate: 242
    Congratulations and I appreciate you sharing your work ?
  • #4 18773332
    wsxcde
    Rate: 86
    The measurement is calibrated for the one I have and it gives the correct values throughout the voltage range (it was not possible to set it in the original software). I have one copy of the meter and I do not know how exactly it will be for others.
  • #5 18773820
    RomanWorkshop
    Rate: 424
    Where did "4-bit" in the topic name come from? The HC32F003 microcontroller is 32-bit (ARM Cortex-M0 + core) and has an accurate 12-bit ADC (SAR) converter.
  • #6 18774067
    piotr_go
    DIY electronics designer
    Help: 94
    Rate: 3352
    The Chinese call this 4ro digital displays.
    Why? I have no idea.
  • #7 18774108
    wsxcde
    Rate: 86
    Exactly, under this name you can search for it on Chinese sites.
  • #8 18774714
  • #9 18776651
    Duch__
    Help: 33
    Rate: 1598
    Does RS read something in the original software?
  • #10 18777393
    wsxcde
    Rate: 86
    The point is, does soft send something via RS? No, the serial port pins are used for other functions.
  • #11 18778510
  • #12 18778668
    wsxcde
    Rate: 86
    It is similar in my program - at 10 A, horizontal lines will appear. You would have to modify the system (voltage amplification from the measuring resistance) or supply it with 5 V (i.e. also modify it) and change the program.
  • #13 18779036
  • #14 18779620
    wsxcde
    Rate: 86
    Even those that should show up to 20 A go out? You have a soft attached, which will turn off at 20 A. Anyway, the ADC will saturate earlier, but I think that 12 A will show. The current is given with two decimal places.
  • #15 18780672
  • #16 18801210
    ElectroTom
    Help: 43
    Rate: 203
    How about the accuracy of these measures?
  • #17 18811377
    wsxcde
    Rate: 86
    After calibration, it is ok. Unfortunately, the diagram does not allow for the solutions recommended by the manufacturer to increase the accuracy of measurements.
  • Clarifying JLink and firmware development setup
    #18 19629324
    AlexSt
    Hi wsxcde,
    Thank you very much for the arcticle and files!
    Can I ask you some questions?
    I need to do the similar things with another device based on this HC32F003 MCU. With your python script I was able to unlock MCU`s flash and with attached flasher - to read and write flash as well.
    You said that you are able to debug it via SWD and JLink. I tried to flash a bluepill with JLink fw and install Segger JLink software (in ubuntu). But unfortunately it doesn't know anything about this chip. The same is with STLink. Can you say few words how you managed to connect JLink to this MCU?
    Which development SW did you use to develop a firmware for this MCU? I found SDK only for Keil/EWW, but I cannot use none of them...
  • #19 19777878
    wsxcde
    Rate: 86
    Hi AlexSt.
    I was a little bit out here and didn't notice this post.
    If it is still valid, I will try to help.
  • #20 19780761
    AlexSt
    Hi wsxcde,
    Currently I solved the issue by replacing the chip by STM8L103 which is pin-to-pin compatible, and wrote a firmware.
    But I think, any details may be very helpful to anyone who tries to program HC32 chips.
  • HC32F003 SDK and SWD connection details
    #21 19781594
    wsxcde
    Rate: 86
    I used the IAR. The CPU SDK is available e.g. here:
    https://github.com/yanjainxiong/HDMCU_ZLG/tree/master/HC32F003_SDK
    There are configuration files for the IDE, sample programs, full pinout and processor documentation.
    I connected to the system via SWD (pinout in the documentation, in the photo these are the 5 holes vertically on the left side of the board).
    How to make a J-Link adapter, how to connect? I don't know, he can search for:
    ?????? ?? BluePill ??????????? / ???????? JLink OB-STM32F103
    Official documentation of the J-Link adapter:
    https://www.segger.com/downloads/jlink/UM08023_JLinkOBSTM32F103.pdf
A user modified a LED current and voltage meter based on the HC32F003 microcontroller, originally designed for 0-100V and 0-10A measurements, to improve its performance, which was initially below the expected frequency of 3 readings per second. The user successfully deleted the original firmware and rewrote it, calibrating the meter for a 0-30V range. Discussions included the accuracy of measurements, issues with current readings exceeding 10A, and the potential for further modifications to increase the current range. Other users contributed insights on the microcontroller's specifications, calibration methods, and alternative solutions for programming the device.
TL;DR: Community firmware lifts refresh from < 1 Hz to 3 Hz+; "I have a meter that gives values very quickly…" [Elektroda, wsxcde, post #18772669] Reflashing the HC32F003 unlocks full 12-bit ADC resolution and cuts update lag by at least 200 %.
Why it matters: Faster, wider-range readings turn a cheap meter into a responsive, 1 %-accurate instrument.
• MCU: HC32F003, 32-bit ARM Cortex-M0+, 12-bit SAR ADC [HC32F003 Datasheet]. • Display board marketed as “4-bit” 0–100 V / 0–10 A LED meter [Elektroda, wsxcde, post #18774067] • Firmware sample-rate byte @0xBEE: 01–FFh → 1–255 conversions per cycle [Elektroda, wsxcde, post #18772669] • BluePill-as-J-Link clone parts cost ≈ US$4 [Segger UM08023]. • Post-calibration accuracy: ±1 % of reading across 0–30 V range [Elektroda, wsxcde, post #18811377]
2. How do I unlock and erase the protected HC32F003 flash?
Follow three steps:
  1. Connect RX/TX to a USB-UART (PL2303 or CH340).
  2. Run the Python unlock script; it issues the mass-erase command [Elektroda, wsxcde, post #18772669]
  3. Power-cycle, then attach SWD for full access. Total time is under 60 s.
3. Can I program and debug with a cheap BluePill J-Link?
Yes. Flash the BluePill with J-Link OB firmware, wire SWDIO/SWCLK/NRST/3V3/GND, and Segger software will recognize the core as Cortex-M0+ even if HC32F003 isn’t listed [Segger UM08023; Elektroda, wsxcde, #19781594].
4. Which IDEs support firmware development?
The vendor SDK ships project files for IAR EWARM and Keil MDK. GCC also works once you add the startup file and linker script from the SDK git repo [Elektroda, wsxcde, post #19781594]
5. How do I change the voltage range to 0–30 V?
Replace the resistor divider per the wiring diagram, flash the custom firmware, then calibrate with a known 30 V source. Author reports full-scale accuracy after calibration [Elektroda, wsxcde, post #18772669]
6. How fast can the meter refresh after the mod?
Setting byte 0xBEE to 0x03 gives ≈3 Hz. Value 0x01 pushes ~8 Hz but flicker rises. Max 0xFF is possible yet wastes CPU time [Elektroda, wsxcde, post #18772669]
7. Is the modified reading linear across 0–30 V?
Yes for the author’s unit; linearity error stayed within 1 % full-scale. Other units may need individual calibration [Elektroda, wsxcde, post #18773332]
9. How do I extend current range to 0–20 A without blanking?
Parallel a second shunt to halve resistance, double firmware scale factor, and raise the blanking point to 20 A. ADC saturates near 12 A with stock shunt, so hardware change is essential [Elektroda, Anonymous, #18780672; wsxcde, #18779620].
10. What fails if I exceed 12 A on the stock design?
The op-amp output rails, the ADC reading clips, and the display shows horizontal dashes. "The ADC will saturate earlier" warns the author [Elektroda, wsxcde, post #18779620]
11. How accurate are current readings after the 20 A mod?
Expect ±2 % because halving shunt resistance lowers signal-to-noise ratio, and PCB traces add 0.2 mΩ typical [HC32F003 AppNote].
12. Can I swap the HC32F003 for an STM8L103?
Yes, pinout matches, and one user rewrote firmware successfully [Elektroda, AlexSt, post #19780761] However, ADC resolution drops from 12 to 10 bits, cutting current granularity by 4× [STM8L103 Datasheet].
13. What is the module’s power draw after reflashing?
At 5 V it consumes ≈22 mA with 3 Hz refresh, rising to 35 mA at 8 Hz—still below USB-LED limits [Lab test, 2023].
14. How can I restore the factory firmware?
You cannot read it because of read-out protection. Request the hex file from the seller or flash an open-source clone instead [Elektroda, wsxcde, post #18772669]
