[Solved] ESP8266: How to write/read string to/from EEPROM? Data type error
samolot123456747 1527 8
  • #1 18792822
    samolot123456747
    Rate: 14
    Good day, I wanted to write and read myself a string value to the eeprom in esp8266, but reading:
    const char * mqtt_ip_server;
    mqtt_ip_server = EEPROM.read(5);
    It only shows an error (a write would probably cause one too, which is why I haven't added it here)
    nie można przypisać wartości typu "uint8_t" do jednostki typu "const char *"
    Not quite sure how to deal with this.
    Please help, thank you in advance
    viayner
    Help: 1563
    Rate: 2052
    Regardless of the platform the EEPROM like any other memory "accepts" Byte values, if the compiler does not automatically change char to byte then do it manually and when reading restore char.
    Greetings
  • #3 18792842
    samolot123456747
    Rate: 14
    Thanks, but how to do it?(this is my first script on an arduino so some legalese would be useful :) )
  • #5 18792886
    samolot123456747
    Rate: 14
    What I want to do is to read e.g. 192.168.1.1 or e.g. login, and to write these two elements (to separate variables of course). It seems to me that this link will be ok.
    Added after 57 [minutes]: .
    I have one more question, how to convert string to "const char * ", because I need to use const char *, not string. (It is not possible to use string). It's about conversions when reading, because when writing everything works ok.
  • #7 18793008
    samolot123456747
    Rate: 14
    Thank you very much. Additionally, after uploading the code from the website: https://mindeon.com/posts/coding-journal/read-write-eeprom/ in the writestring function line 4 is the identifier _size. My editor was showing an error, so I changed it to Stringsize and there was no error. Does this now have the right to work(I mean writeestring)?
  • #9 18793027
    samolot123456747
    Rate: 14
    Thank you very much for your help.
The discussion revolves around writing and reading string values to/from EEPROM on the ESP8266. The user encountered a type error when attempting to assign a value read from EEPROM (uint8_t) to a const char* pointer. Responses clarified that EEPROM stores byte values and suggested converting the byte to a string format. A link to an example for reading text strings from EEPROM was provided. The user also inquired about converting a string to const char* and received guidance on using the c_str() method. Additionally, a code error related to an identifier in a provided example was resolved by renaming it, confirming the code's functionality.
