ESP32 - Writing temperature sensor data to non-volatile memory: EEPROM vs memory card
RometFan;p 1842 4
  • External EEPROM vs memory card for 744 readings
    #1 19600163
    RometFan;p
    Help: 92
    Rate: 26
    I have temperature sensor data to save - 24 records per day.
    The data history needs to be available for a month which gives me 744 int's.
    Obviously with such a long period, the power may disappear, you would need to save this data somewhere to non-volatile memory. Which is better to use? The ESP doesn't have its own EEPROM only an emulated one, and this is too small anyway.
    1. external EEPROM, e.g. 32k?
    2. memory card?
    3. something else?
  • #2 19600227
  • #3 19600250
    TvWidget
    Help: 472
    Rate: 699
    There is probably a non-volatile flash memory connected to the ESP32 processor into which you write the program. Is it all occupied ?
  • #4 19600564
  • #5 19637943
    powerTGS
    Save to SPIFFS memory (you have 1, 2, 3 MB available) depending on your configuration when you win the software. Add an FTP server, then you will have access from the FTP software to the SPIFFS memory in the ESP - you can view, download, delete this data.
