[Solved] ESP8266 UDP Communication for Audio Data to WS2812B LED Strips
Dawidixxx 1746 4
  • #1 18860880
    Dawidixxx
    Rate: 36
    Heyka :) .
    I made myself a project a long time ago on an esp8266
    2x D1 mini receive the analogue data from the microphone and based on that display the number of leds in 1m ws2812b 144led/m strips.
    The problem is that I did this on a cable at the extremities of the room :/ (about 2 meters each between microphone and esp) I was then unable to establish a permanent fast wifi connection between the devices, and I would like to use the master role with the microphone as the 3rd device.
    The solution to the problem could be UDP on the ip of the router
    https://circuits4you.com/2018/01/01/esp-to-esp-communication/ second example
    - UDP because I don't need a reply, I just transmit audio from 3 esp with microphone and receive on esp with leds, not very sensitive data
    - router as a wifi carrier, previously during failed attempts the master had to maintain the connection between the others which was cumbersome, while sending information at the same time
    Just won't this solution strain the wifi in the house during operation?
    I still have communication via RF 433mhz in the back of my mind, but there should be a way to efficiently connect via wifi at the speed of sound :D .
    Greetings
  • #5 18875525
    Dawidixxx
    Rate: 36
    application of ESP-NOW!
