How to integrate ESP32 with WS2812b controlling via WIFI, BT and touch + DS18b20?
qwerty411 1563 5
  • #1 17821576
    qwerty411
    Hello Friends!
    I've made myself some balcony lights based on WS2812b (300 pcs), controlled by Arduino nano, coding for FASTLED, and everything is working fine. However, I would like to expand on this a little, namely:
    1. control via ESP32
    2. Bluetoth with a smartphone for changing effects and switching
    3) WIFI from a desktop computer for the same functions.
    4. if ESP32, I would like to use the possibility of touch "keys" for manual control
    5. temperature measurement (DS18b20 ?) (why!!!)
    What I am asking you and what doubts I have ? ( my knowledge rather poor):
    I mean a kind of "roadmap" and determination of feasibility.
    1 . Will the use of the above functionalities not block the transmission to the leds (interrupts!), because this must be very fast (SPI?)?
    2 . can I configure WIFI access via Bluetoth?
    3. so technically: do I have to "extinguish" the touch keys with capacitors.
    I am very much counting on your help . At the same time please take my little knowledge :) ))
    Greetings
    The code I am using:
    #include "FastLED.h"
    #define LED_COUNT 300
    #define LED_PIN 11
    struct CRGB leds[LED_COUNT];
    uint8_t hue = 32;
    byte idex = 255;
    byte meteorLength = 47;
    void setup() {
    delay(2000);
    LEDS.addLeds<WS2812, LED_PIN, GBR>(leds, LED_COUNT);
    LEDS.setBrightness(250);
    void loop(){
    meteorShower();
    void meteorShower(){
    memmove8( &leds[1], &leds[0], (LED_COUNT - 1) * 3 );
    idex++;
    if ( idex > meteorLength ) {
    idex = 0;
    hue += 34;
    switch ( idex ) {
    case 0:
    leds[0] = CRGB(200,200,200);
    break;
    case 1:
    leds[0] = CHSV((hue - 15), 255,180);
    break;
    case 2:
    leds[0] = CHSV((hue - 18), 255, 170);
    break;
    case 3:
    leds[0] = CHSV((hue - 20), 255, 160);
    break;
    case 4:
    leds[0] = CHSV((hue - 22), 255, 150);
    break;
    case 5:
    leds[0] = CHSV((hue - 24), 255, 140);
    break;
    case 6:
    leds[0] = CHSV((hue - 29), 160, 130);
    break;
    case 7:
    leds[0] = CHSV((hue - 30), 140, 120);
    break;
    case 8:
    leds[0] = CHSV((hue - 31), 120, 110);
    break;
    case 9:
    leds[0] = CHSV((hue - 32), 100, 100);
    break;
    case 10:
    leds[0] = CHSV((hue - 33), 90, 90);
    break;
    case 11:
    leds[0] = CHSV((hue - 34), 80, 80);
    break;
    case 12:
    leds[0] = CHSV((hue - 35), 70, 70);
    break;
    case 13:
    leds[0] = CHSV((hue - 36), 60, 60);
    break;
    case 14:
    leds[0] = CHSV((hue - 34), 50, 50);
    break;
    case 15:
    leds[0] = CHSV((hue - 35), 40, 40);
    break;
    default:
    leds[0] = CRGB::Black;
    FastLED.show();
    delay(60);
  • #2 17821668
    piterek-23
    Help: 162
    Rate: 427
    When inserting the code, use the tags "SYNTAX"
  • #3 17821680
    qwerty411
    I actually put the code in the wrong way . I will correct myself :) ))))
  • #4 17821691
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    1. the ESP32 has two cores. You can flip some of the tasks to the second core. I haven't done this myself yet, but I've seen that it can be done.
    2. if you write for yourself. You'll have that.
    3) I don't know, I haven't done it.
  • #5 17822169
  • #6 17822254
    LChucki
    Help: 104
    Rate: 379
    a55f488888ba Wouldn't the use of the above functionalities result in blocking the transmission to the leds (interrupts!), as this must be very fast (SPI?)?
    Use DMA.
