Maximizing Huawei B818 Router Speeds: Band Aggregation Worth or Not?
Piotr562 22953 4
  • #1 18873919
    Piotr562
    Rate: 27
    I have a router as in the title, it achieves quite decent speeds for me at the level of 100 to 145 MB / s off-peak and in the peak to about 50 MB / s, of course, about the download speed, but recently I downloaded the update and in the Task Manager the card showed sometimes and 220 MB / s so I don't know which is more reliable. The question is whether it is worth playing with band aggregation and what program is the best to do it? I have about 790 m to the Play transmitter that the router connects to, I can see it from the window.
    matek451
    Help: 4360
    Rate: 5823
    The router in the auto setting uses LTE band aggregation, band management, aggregation and signal diagnostics using the HManager application, HuaCTRL for Android or https://ltehmonitor.github.io/ for Windows. The speed of 220 Mb / s in Play is possible only in the aggregation of LTE bands.
  • #4 18877220
    Piotr562
    Rate: 27
    I just guessed that the internet speeds are not bad, you can even play via streaming. As for aggregation, the question arose from the fact that I heard about LTE 800, 1800, 2600 bands, etc., however, as I read on various forums, LTE 800 MHz is the most crowded and the slowest, while when combining two bands, e.g. LTE 1800 and 2600, speeds can drastically increase . However, on some forum I read that someone, after rummaging in the bands with the HMeneger program, the router stopped detecting SIM cards, apparently it was created by a former Huawei employee. As you think my fears are right, I would not like to damage the equipment. I know that the speeds are not constant and they will fluctuate, on warm weekends there are a lot of people on the plots and the internet is clearly slower then. I will check the Speedtest you sent in the link and share the information on how it came out. Thanks for a lot of information.
    HManager app recommended for forcing band aggregation
    #5 19127027
    Wojtas_81_
    I recommend using the HManager app. It is worth forcing the aggregation of additional bands, the more so because you have a modem with the possibility of aggregating 3 bands, especially in the period of high intensity on a specific transmitter. Personally, I have been using it for 3 years on the Huawei B525 router. I check the speed from a given band, then connect the best frequencies. I have never had any problems with the SIM card, let alone the router.
