[Solved] Troubleshooting TWS F9 Earbuds: Pairing Left and Right Earphones Simultaneously
Katwol00 86178 9
How do I reset and pair TWS F9 earbuds so the left and right earbuds work together instead of appearing as two separate Bluetooth devices?
Forget the earbuds on all phones and laptops first, and preferably turn Bluetooth off on devices that were already connected to them [#19145899] Put both earbuds back into the charging case, take them out again so both start blinking, then quickly double-press one earbud’s button; one reply says to press the right earbud marked R [#19145899] [#19889702] Wait a moment until one earbud stops blinking, which means the two earbuds have linked into one device [#19145899] Then search for the single headset on your phone and connect it [#19145899] Several users confirmed this simpler method worked for them after the manual pairing method failed [#19326716] [#19604230]
  • #1 18959264
    Katwol00
    the headphones won't pair with each other. After turning on bluetooth, two devices that can be paired (left and right earphones separately) appear, they do not want to work at the same time. How to fix it? Do a reset? But how?
  • #4 19117858
    koprywa
    Rate: 19
    Did you find the solution? Were you able to pair your headphones?
  • #5 19125980
    hallmar
    Hello! Has anyone managed to pair these headphones with each other?
  • #6 19129315
    Katwol00
    Unfortunately not
  • Simpler TWS F9 pairing method with double-click
    #7 19145899
    wati89
    Rate: 115
    The way in the manual is quite difficult to do because everything has to be done perfectly. I am offering you a second easier way to pair your headphones :)
    1. Forget the device on phones, laptops (preferably turn off Bluetooth on all connected devices)
    2. Place the headphones in the charging case
    3. Taking out the headphones - both should be flashing
    4. One of the headphones, no matter which click twice quickly
    5. Wait a moment - one of them should stop blinking - it means that the headphones have joined into one device
    6. Find the device on the phone and connect
    FINISHED :)
    Added after 35 [seconds]:
    it helped me and I was able to put them together
  • #8 19326716
    Evva1212
    Rate: 14
    Thanks for the simple advice, I was tired for two days, it worked.
  • #9 19604230
    AleksanderJurek
    Rate: 12
    It's great, just put in, take out one, knock 2 times and already and I was tired from the morning ... Thanks a lot because they were supposed to go to the basket
  • #10 19889702
    8804
    Rate: 8
    Hello. Turn off the phone in the phone, unpair the headphones from the phone, then take the headphones out of the back-bank, both headphones are blinking blue, then press the button on the right receiver marked (R)
    Two times after a while the headphones are paired, the blue LED blinks only in the right earpiece and it's ready. You can finish the headphones with the phone.
The discussion revolves around troubleshooting the TWS F9 earbuds, specifically the issue of pairing the left and right earphones simultaneously. Users report difficulties in connecting the earbuds as they appear as separate devices. A suggested solution involves resetting the connection: first, unpair the earbuds from all devices and turn off Bluetooth. Then, place the earbuds in the charging case, take them out to ensure both are flashing, and quickly double-click one of the earbuds to initiate pairing. Successful pairing is indicated when one earbud stops blinking. This method has been confirmed to work by multiple users, alleviating their frustration with the pairing process.
