Sonoff TH10 - temperature sensor does not work when connected to 5x1.5mm2 cable
mosmati88 1404 1
  • #1 18959688
    mosmati88
    Help: 28
    Rate: 152
    Hi. I have fitted a sonoff to monitor the temperature in the house and switch on the exchanger circulation pump. The sensor itself briefly connected to the sonoff works. In order not to forge the walls, I connected the sensor to the free wires in a 5x1.5mm2 cable. This cable runs from the exchanger to the kitchen for about 7 metres. I have 2 wires used for L and N and the other 3 wires for the sensor. It is not working. I thought the interference from the phase was transferring to the sensor but nothing. Even though I disconnect the 230v from this cable the app still does not see the sensor. Do you have any ideas?
  • #2 18959748
    bubu1769
    Help: 1177
    Rate: 2368
    Do you want to use a sensor with onewire communication on a 7m antenna?
