Milight FUT036 and Alexa - how do I control each channel separately?
bhtom 825 0
  • #1 18977299
    bhtom
    Help: 446
    Rate: 604
    Welcome,
    I have lighting in my flat controlled by two Milight FUT036 controllers (two separate white LED strips). The control is via a four channel remote control FUT007 and a wall mounted B1. The control from the remotes works fine. For this I have a Miboxer WL-Box1 2.4GHz to be able to control the lighting from the app. From the app also everything works.
    The problem is during voice control from Alexa. I can't for anything decipher how to voice control each channel separately. All commands work in parallel on both channels (on/off, brighten/dim, etc.).
    Has anyone encountered this problem?
    Greetings.
