Mi-light FUT035S+ integration with Google Smart Home - problem with LED controllers
Arkadiusz14 579 1
  • Google Smart Home sees only last Tuya zone
    #1 21158645
    Arkadiusz14
    I am using the Mi-light FUT035S+ LED controllers and have two small issues to resolve after installation:
    1. in the Tuya app, after pairing the bridge (WL-Box2), the controllers (and at the same time each LED) are added as separate zones, and everything works fine there, but after integrating with Google Smart Home, in the Google app, I can only manage the last opened controller in the Tuya app, can't see the rest, can this be solved somehow?
    2. one of the LEDs has a touch switch (kitchen, under the cabinets), the controller has connected correctly, the control is also ok, but unfortunately there is a problem with turning on the light from the app (turning off works), turning on only causes the switch light (backlight) to come on, but not the LED strip itself, how to deal with this?
    I warn you that I am a total amateur trying to learn something :) .
    Tuya scenes mapped to Google Home automations
    #2 21696948
    sygitmasionissejny
    First, in the Tuya app, set up as many scenes as you have zones. All triggered by a button. Assign one zone to each. Always give scene selection as the first effect, then on, then e.g. brightness or something. Then set up as many automations in the Google Home app as you have scenes. Assign one scene to each. E.g. automation title: "Light on the staircase", voice trigger with the same name - choose a zone with LEDs on the stairs and save.
