Poor illumination of the sensors in the Sonoff Touch 2-channel wall switch - white bezels
Prezeslukasz 732 3
  • #1 18999953
    Prezeslukasz
    Rate: 15
    Hi. I have a problem with the sensor backlighting on the touch 2 channel wall switch which makes it difficult to see where to press to light the light. This is the case with the white bezels of the new switch model. (You can recognise the sensor points on the black bezels). Do you have the same problem or is there a remedy for this?
  • #2 19000747
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    I have a sonoff touch T2 with square fields and on all of them the backlighting is visible even when it is bright.
  • #3 19004183
    Prezeslukasz
    Rate: 15
    Or is there a brightness control?
  • #4 19004512
    xury
    Help: 878
    Rate: 1498
    There is no regulation.
