Stabilizing ADC Readings on ESP32 with LiFePo4 Power Supply for Soil Sensor
piotrgl1983 1260 3
  • Clarifying ADC stability with direct LiFePo4 supply
    #1 19044767
    piotrgl1983
    I need to build a soil moisture sensor for the garden esp32 + micropython, wifi communication - mqtt, >> homeassistant .
    Currently working on the power supply, some problems have arisen.
    I already have the components, while I don't know how to deal with the effect of the variable power supply from the LiFePo4 (2.5 to 3.65v) on the readings from the adc.
    I need to read the voltage of the battery and the soil moisture sensor with the adc.
    With variable voltage from the battery, how do I get stable readings from the adc?
    The esp32 is directly connected to the LiFePo4!
  • #2 19044937
  • #3 19045626
    piotrgl1983
    Ok, that's my next question, what type will be the most energy efficient, especially as esp32 will be in Deepsleep ?
  • #4 19045930
