Searching for WiFi sensor for septic tank fill signalling in Home Assistant
unky 2640 4
  • #1 19071386
    unky
    Rate: 61
    I have a septic tank fill sensor which has a NO signalling output and when filled the contact is shorted.
    I would like to connect this to the Home Assistant home automation. Unfortunately, I can't find anywhere to find a WiFi sensor that detects a shorted line and transmits this information to Home Assistant.
    Has anyone ever come across this type of WiFi sensor?
  • #2 19071417
  • #3 19071552
    unky
    Rate: 61
    I am looking for a module that sends a signal to the HomeAssistant.
  • #4 19071565
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    There was some time ago this topic raised in the forum - search, there were various ideas there.
    For such tasks, you can use ESPHome for example and create your own module.
    You could also use a door/window closing sensor - plug in instead of a reed switch.
  • #5 19115517
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Practically any esp8266 based device with one free gpio will take care of this. With software to send an MQTT message e.g. Tasmota, Espeasy, supla etc.
