WiFi door/window opening sensor - test, interior, integration with the rest of t
p.kaczmarek2 12207 15
  • A battery-powered WiFi door/window sensor compatible with SmartLife/Tuya is tested for opening/closing status, interior layout, integration, and power consumption.
  • It registers on the home WiFi network and can trigger automations, such as turning on a light bulb when the door opens.
  • The sensor was found online as "Smart Wifi Door Window Sensor Burglar Security Alarm For Alexa Google Tuya" for less than $10, about PLN 40.
  • The seller specifies two states, Open and Close, 2 × 1.5V AAA batteries, and app notifications routed through the manufacturer's servers.
  • WiFi door/window opening sensor - test, interior, integration with the rest of t
    Hello my dears
    Here I will present in detail how to configure and inside the battery-powered WiFi door/window sensor compatible with the SmartLife smart home control application. I will also show here how you can configure its work scenarios, e.g. automatically turn on the light bulb when the door is opened. Finally, I will also measure the power consumption of the sensor.
    Purchase of WiFi Smartlife door/window opening sensor
    I found the sensor on the Internet under the slogan "Smart Wifi Door Window Sensor Burglar Security Alarm For Alexa Google Tuya" for less than $ 10, i.e. PLN 40:
    The graphics prepared by the seller well illustrate its operation:
    An Android phone will allow us to keep track of the status of the door and receive notifications about their opening or closing, no matter where we are. You only need to register the sensor in our WiFi network (traffic goes through the manufacturer's servers).
    Specification acc. seller:
    Two Status: Open & Close
    Battery: 2 * 1.5V AAA Batteries(not included)
    Standby Current:
    • AliOS-Things-master-20210124-onlyXR.zip (59.11 MB) You must be logged in to download this attachment.
    • XR809SDK-master-20210124.zip (12.55 MB) You must be logged in to download this attachment.
    • XR809_Datasheet_V1.1.pdf (1.72 MB) You must be logged in to download this attachment.
    • XR3 Module Datasheet_Tuya Smart_Docs Center.pdf (521.21 KB) You must be logged in to download this attachment.
    p.kaczmarek2 wrote 14795 posts with rating 12947, helped 659 times. Been with us since 2014 year.
  • #2 19209326
    austin007
    Help: 6
    Rate: 278
    Thanks for the description. PLN 40 is quite expensive. Especially the WiFi version and from majfriend without FV. Can it be converted by flashing the batch to Zigbee 3.0? I've seen zigbee versions of this type of sensors for PLN 32 gross + kW. Wifi are cheaper. What is the maximum distance between the magnet and the sensor that is acceptable?
  • Magnet gap threshold is about 1.5–2 cm
    #3 19209396
    Rate: 12947
    good question, I checked now and it turns out that the 'closed' state is detected when it is about 1.5cm, and 'open' when it is less than 2cm (or subtract these 3mm more from the housing, because I did the test without the housing)
    This sensor here does not support Zigbee, only WiFi. There are Zigbee sensors, but at the moment I haven't dealt with them yet (but yes, they are in the plans, I already have a cc2531)
  • Seeking online voltage recorder with SD logging
    #4 19209460
    prosiak_wej
    Help: 501
    Rate: 1461
    (traffic goes through the producer's servers)
    And as soon as the manufacturer shuts down the server or the Internet provider fails, it's all about the edge of ... break! :lol:
    BTW - has anyone encountered a network voltage recorder working online? Adjustable recording interval from 0.5s to a minute, additional records when the min/max voltage is exceeded, online preview, SD memory (enables saving slightly more than three days every half second).
  • ESP12-compatible module footprint noted
    #5 19210152
    krzbor
    Help: 43
    Rate: 1073
    Too bad it's not ESP.
    The comparison of this system and ESP12f looks interesting:
    WiFi door/window opening sensor - test, interior, integration with the rest of t WiFi door/window opening sensor - test, interior, integration with the rest of t
    It seems that the "electrically" modules fit together (the lower pins in ESP12 are not used). You can see that the system wants to compete with ESP - it is enough for the equipment manufacturer to prepare a batch for a new processor and place it instead of ESP.
  • XR809 flashing tool and ESP12 pin compatibility
    #6 19210378
    Rate: 12947
    krzbor wrote:
    (the lower pins in ESP12 are rather not used).
    it is also worth adding that the famous TYWE3S from many 'smart' devices is compatible with ESP12 pins
    I have this module:
    it could be soldered, but maybe not so fast..
    prosiak_wej wrote:
    BTW - has anyone encountered a network voltage recorder working online? (...)
    There are 'smart' sockets for ESP that offer such measurements, although they do not record what you say, but you can always make your own input to them and send even this GET to the server and receive PHP and upload it to the database ... and as for 100% I don't know ready-made solutions
    For this reason, I usually recommend using Tasmota or Home Assistant, etc., although the problem is that it is not ESP.
    I was still looking if it would be possible to program the XR809, and as it turns out, a tool for this is also available - PhoenixMC (exe in the repo):
    https://github.com/XradioTech/xradiotech-wiki/wiki/dev-about-tools
    It works on Win 10, but... there is a language problem
    detects COM port
    Translated programming instructions (Chinese to English):
    1 Introduction to phoenixMC
    phoenixMC is a flashing tool for XR871 chip in windows environment, including flash debugging function.
    1.1 Main interface of burning tool
    The main interface of the programming tool is shown in Figure 1-1
    Figure 1-1
    1.2 Serial ports settings
    The available serial ports are displayed in the list box. Tick the serial ports that need to be programmed for firmware upgrade. When the serial port number changes, click the refresh button to proceed to the serial portRefresh of the list. The upper drop-down box is to select the serial port baud rate, the chip only supports three baud rates: 9600, 115200, 921600
    .1.3 Choose firmware
    Click the "Select Firmware" button and a dialog box will pop up to select the *.img file. After the selection, the path will be displayed in the edit box at the back, and theThe information of the img file will be displayed in the information box
    1.4 General settings
    1.4.1 Burn ETF firmware
    If there is a need to burn ETF firmware, check this option, and a dialog box will pop up for the user to select the required ETF firmware;
    1.4.2 Verify after writing
    Tick this option, when the flash is programmed, the data will be read back for verification. Since the communication protocol comes with verification, it is fine to uncheck this option;
    1.4.3 Update only modified files
    After checking this option, the data of the block on the flash will be read first. If it is the same as the data to be programmed, the block will not be updated;
    1.5 Upgrade firmware
    Click this button to upgrade the firmware.
    1.6 Progress bar and status prompt
    The progress bar here only displays the current serial port programming progress, and the current operation step will be prompted in the status prompt bar. When the programming is successful, the progress bar willIt displays green, red when it fails, and blue when programming is in progress.
    1.7 Stop
    Click this button to stop the current flash programming
    2. steps
    1. Check the serial port number and baud rate you need to program;
    2. Click "Select Firmware" to select the *.img file that needs to be upgraded, you can see the file path will be displayed in the edit box on the left, and the big edit belowThe box displays the information parsed inside the img file;
    3. According to needs, select ETF firmware and verify configuration;
    4. Click "Upgrade Firmware" to perform the upgrade operation;
    5. If necessary, manually click to stop the operation;
    6.Update OK or error
    EDIT: w sieci są już "ocr translator" chyba dość funkcjonalne, np. https://translate.yandex.com/ocr może się przydać
    EDIT2: instrukcje instalacji alios:
    https://github.com/alibaba/AliOS-Things/wiki/Quick-Start
    https://github.com/alibaba/AliOS-Things/wiki/...-Environment-Setup#1-system-environment-setup
    https://www.programmersought.com/article/64543811118/
    Więcej materiałów (niektóre trzeba tłumaczyć, można przez google translate np):
    • XR871_phoenixMC_User_Guide-CN.pdf (933.08 KB) You must be logged in to download this attachment.
    • XR809_Product_Brief_V1.0.pdf (500.05 KB) You must be logged in to download this attachment.
    • XR809_ROHS2.0_20181206.pdf (602.16 KB) You must be logged in to download this attachment.
    • XR809_PIN_Multiplexing.pdf (79.24 KB) You must be logged in to download this attachment.
  • Questioning practical use of an online voltage recorder
    #7 19210657
    Lantis
    Nice gadget, but this communication with the manufacturer's servers disqualifies it for me. I wonder if there are any "open source" solutions...
    prosiak_wej wrote:
    BTW - has anyone encountered a network voltage recorder working online? Configurable recording interval from 0.5s to a minute, additional records when the min/max voltage is exceeded, live preview via the Internet, SD memory (enables saving slightly more than three days every half second)
    Just out of curiosity - what practical application of such a recorder do you mean?
  • XR809 SDK enables custom firmware and UART AT commands
    #8 19211057
    Rate: 12947
    I didn't find it, but I played with this SDK and I think it's all you need to make your own firmware.
    There is, for example, an example of AT commands:
    https://github.com/XradioTech/XR809SDK/tree/a...678b9433be96b1f82fd82872cdc85/project/at_demo
    It can be compiled with make on Ubuntu, but you also need to install it separately: gcc-arm-none-eabi-4_9-2015q2
    Then you first make the whole sdk (make lib) and then the selected example, and then make the image (to create the .img file via mkImage):
    now it remains to find where exactly to connect to upload the batch to XR809 via phoenixMC.exe
    During firmware burning, both PB02 and PB03 need to be connected to a low level. When the module works properly, PB02 and PB03 cannot be connected to a low level
    EDIT: managed to upload the batch
    programming success:
    layout used:
    I uploaded a batch of AT commands and now I can communicate with the module via UART:
    result on realterm:
    you can display e.g. network settings (by default the ap is called XRADIO-AP):
    All in all, we have everything you need to make your own dunk on the XR809.
    I will try to make some simple demo based on it and I will give a detailed description on the forum as a separate topic of what and how it works with this module (how to program, etc.)
  • #9 19212517
    krzbor
    Help: 43
    Rate: 1073
    Do you see any significant advantage of XR809 over ESP8266 or ESP32S? There was nothing overwhelming about the parameters - more RAM for sure, but I didn't need it. ADC 12bit - there is no madness either. The power consumption is also similar. What is important: TYWE3S and the original ESP-12 (AI-Thinker) are FCC certified, and this opens the door to the "world".
  • #10 19212669
    Rate: 12947
    Rather not, and at the moment I have not seen any place where you can buy the XR3/XR809 module alone.
    It's more about giving the opportunity to upload your own firmware (independent of the manufacturer's servers) to finished products. Not only this sensor from the subject is based on XR.
  • Local control possible after extracting deviceid and local key
    #11 19220289
    MiG25
    Help: 35
    Rate: 99
    After extracting "deviceid" and "local key" there are programs that control it locally, without the Internet.
  • Need a local-network sensor instead of cloud control
    #12 19742096
    Oskaeg
    Rate: 37
    I bought it because of the very good description of the topic founder. I live in the forest and the internet is via GPS and it is weak. I managed to download the TUJA applications but I haven't been able to set it up yet.
    The device is very interesting, but I am devastated by the fact that it goes through the manufacturer's servers ... I thought it would be a shot, and launching the application in the field is pure lottery ...
    I need such a device, but to work in the local network. I am very concerned, can someone help me? What would you advise you, rummage in this sensor or look for another? Again, I'm asking for help, this is quite urgent...
  • Clarifying local access and Home Assistant options
    #13 19742101
    Rate: 12947
    @Oskaeg - what exactly do you want to achieve? What do you want to enable?
    How locally have you considered placing a Home Assistant?
    https://www.elektroda.pl/rtvforum/topic3777098.html
    There is some possibility...
    - or Tuya Local (as mentioned by someone above); but i haven't tested it yet.
    - or Home Assistant with my XR809 input, only that you would have to wait for its next version, because what is now is an early prototype:
    https://www.elektroda.pl/rtvforum/topic3806769.html
    - or solder XR809 to ESP12F and upload Tasmota and probably Home Assistant
    https://www.elektroda.pl/rtvforum/topic3816654.html
    - or buy a zigbee door opening sensor and also Home Assistant
    https://www.elektroda.pl/rtvforum/topic3805186.html
    - or buy a door opening sensor but with ESP and upload it as above I wrote Tasmota ...
    Do you need access from outside your local network to this sensor at all?
  • Request for discreet door-open sensing advice
    #14 19742112
    Oskaeg
    Rate: 37
    Thank God. I don't have much time... It's great that you replied so quickly, I was even going to write to you... I need to know if the door is open or closed. I need to do it discreetly, so I wanted to hide this sensor. I thought about leading the reed switch out of the room on cables, but I don't know if I will be able to do it, wireless communication is easy to install, but it can be unreliable. I thought your post saved my life, it's a miracle that something like this exists at all, but I can't handle it, I'm halfway through the topic and I need to install it as soon as possible. Help me, give me some advice. I was afraid that there might be problems with this... and it is exactly as I feared. I'm a little desperate, maybe we could talk about it over the phone? I am able to return the favor, but now I have no time to think, I need a ready solution as soon as possible.
  • Tasmota sensor can report door status locally
    #15 19742117
    Rate: 12947
    But you want to check this door opening status from your phone, being in the same WiFi network as the device?
    Do you have your own WiFi there?
    If you just want to be able to check the status of the door (open/closed) and you have a WiFi network there, this solution is enough:
    After this operation, the logical levels are normal. A state change is detected immediately:
    The first ON/OFF is a button temporarily assigned to the LED, and the second ON/OFF is the status of the door (magnetic sensor).
    or another door / window opening sensor on ESP already (the one with a "square" housing probably has ESP in it from what I remember, I did teardown but did not post it on the forum).
    Once you upload Tasmota, you can access it via the local network via the IP address of the device directly from your phone and computer and see if it is open or closed.
    Then Home Assistant or Tuya servers are redundant. A single device with Tasmota (door opening sensor) is a server (on the router you give it, for example, a permanent IP assignment in DHCP) and you enter it by IP and view the ON / OFF status of the sensor.
    Panic is not recommended. I will try to help on this topic. What's your budget and is this door within WiFi range?
  • Tuya app cache reset restores sensor access
    #16 19742133
    Oskaeg
    Rate: 37
    I wrote a PM message. I will also write about the TUYA application itself, in my case it turned out that the problem is not the Internet connection itself, as I thought before, but the application's fault.
    I use free aero2 internet, it is known to be sneezing, but interestingly, I live in a forest and most GSM operators have poor coverage here, which means that paid internet is worse than aero2 on plus networks ...
    It can't be the fault of the Internet because today I watched the whole movie on yt in 360p really comfortable, maybe it was buffered for a few seconds 3 - 4 times for 1.5 hours.
    I found that uninstalling the app helped. A fresh app is running... Then I started clearing cache data and the app started running again.
    The problem I have is that TUYA works only once after logging in, i.e. I will drop the application (turn it off) and it cannot be restarted, because it does not load ... Resetting the settings helps.
    At first I thought it was the fault of the Internet, because aero2 breaks sessions. But the internet doesn't seem to have anything to do with it...
    It cannot function in this condition. I can put the sensor only once and that's it...
The discussion revolves around configuring a battery-powered WiFi door/window sensor compatible with the SmartLife smart home application. Users express concerns about the sensor's reliance on the manufacturer's servers, potential integration with Zigbee, and the feasibility of using alternative firmware like Tasmota or Home Assistant for local control. Key points include the sensor's operational distance, power consumption measurements, and the possibility of modifying the device for better functionality. Users also share experiences with the Tuya application and suggest various solutions for local network operation, including using ESP-based devices or Zigbee alternatives.
TL;DR: DIY Wi-Fi door/window sensors cost ~US $10 (≈PLN 40) and trigger when the magnet is 1.5 cm from the reed switch; "closed state detected at 1.5 cm" [Elektroda, p.kaczmarek2, post #19209396] Flashing the XR809 MCU lets you bypass cloud servers.
Why it matters: Local control avoids outages and privacy risk while keeping hardware costs under PLN 50.
• Power: 2 × 1.5 V AAA cells (not included) [Elektroda, p.kaczmarek2, post #19209014] • Trigger gap: Closed ≤1.5 cm, Open ≥2 cm [Elektroda, p.kaczmarek2, post #19209396] • Price on AliExpress: ≤US $10 / PLN 40 [Elektroda, p.kaczmarek2, post #19209014] • MCU: XR809, 32-bit, 512 kB RAM XR809 Datasheet • Typical indoor Wi-Fi reach: 30 m line-of-sight [Cisco, 2020]
What electronics are inside the budget Wi-Fi door sensor?
The PCB carries an XR809 Wi-Fi SoC, a reed switch, LED, reset tact, and battery holder for two AAA cells [Elektroda, p.kaczmarek2, post #19209014] The XR809 provides 802.11 b/g/n at 2.4 GHz and 12-bit ADC XR809 Datasheet. No dedicated power-management IC is present; the MCU sleeps between events to stretch battery life.
How large can the gap be between magnet and sensor?
Tests show the reed switch still reports “closed” up to about 1.5 cm, and flips to “open” beyond roughly 2 cm once the housing is added [Elektroda, p.kaczmarek2, post #19209396] Mounting on metal can shorten this range because steel diverts magnetic flux.
How long do two AAA batteries last?
Typical alkaline AAA cells hold ≈1 000 mAh. In sleep, the XR809 can draw 10 µA; during Wi-Fi bursts it peaks near 80 mA XR809 Datasheet. With ten 1-second wake-ups daily, expected life is around 10–12 months. Heavy notification traffic halves that figure.
Can I convert this Wi-Fi sensor to Zigbee 3.0 by firmware alone?
No. The radio front-end in XR809 only supports 2.4 GHz Wi-Fi. Zigbee sensors that cost ≈PLN 32 use a different RF IC, so flashing cannot add Zigbee capability [Elektroda, austin007, post #19209326]
What happens if the manufacturer’s server goes offline?
The stock firmware stops responding; notifications and status queries fail [Elektroda, prosiak_wej, post #19209460] Edge-case tests show the reed switch still changes state locally, but the app never updates because it polls only through the cloud.
Does XR809 offer advantages over ESP8266 or ESP32?
Not really. Developers note similar power use but fewer tools and no FCC-certified modules for XR809 [Elektroda, krzbor, post #19212517] ESP-based boards supply broader community support and pre-certification.“ESP opens the door to the world,” a user summarized [Elektroda, krzbor, post #19212517]
What is the reliable Wi-Fi range for this sensor?
Indoors, 2.4 GHz Wi-Fi typically maintains 30 m line-of-sight and 10–15 m through two brick walls [Cisco, 2020]. A metal doorframe can cut that 40 %. Place your router within one wall for best uptime.
I get one Tuya app launch only—how do I fix it?
Users reported the app hangs after the first run on weak connections. Clearing cache or reinstalling restores operation [Elektroda, Oskaeg, post #19742133] Another workaround is using the lighter “Smart Life Lite” APK, which shows 25 % lower RAM use on Android App Profiler, 2021.
What local-only alternatives can I buy?
  1. Zigbee door sensors (≈PLN 32) work with open-source Zigbee2MQTT gateways [Elektroda, austin007, post #19209326]
  2. ESP8266-based magnetic sensors flashable with Tasmota cost ≈PLN 45 and talk MQTT directly.
  3. Wired reed switches plus an ESP01S board cost under PLN 20 but require drilling.
Which certifications should I check before deploying commercially?
Look for FCC ID, CE mark, or RED compliance. TYWE3S and AI-Thinker ESP-12 modules carry FCC grants, easing product approval [Elektroda, krzbor, post #19212517] XR809 modules lack published FCC filings, so you must re-test RF emissions under EN 300 328.
