Boosting gas boiler output - Bosch MU100, Arduino, Domoticz/Home Assistant
noname23 1269 4
  • #1 19291499
    noname23
    Rate: 8
    I recently came across a very cool Bosch mu100 module. This module is used to increase the output of a gas boiler by feeding a voltage in the 0-10v range. Now I have a question for you: with which module can I smoothly from domoticz/home assitant feed a voltage in the 0-10v range via arduino to the mu100 module? :) .
    Greetings
  • #3 19294583
  • #4 19297566
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    And which boiler is it for? Because it is unlikely to be a universal controller.
  • #5 19304842
    noname23
    Rate: 8
    xury wrote:
    And which boiler is this for? Because it is unlikely to be a universal controller.
    I'm not sure but I think it will work with condens 9000 boilers.
    I don't know how to solve the heating with the Home Assistant. Someone told me to give a bigger parameter on the heating curve (instead of the module I wrote about above) so that if I wanted to reheat a room I could do so.
