Connect Electricity Meter to Domoticz System: S0 Pulse & M-BUS Output, Raspberry Pi GPIO Pins
boris82 7731 7
  • #1 17083931
    boris82
    How can I connect the electricity meter to the "Domoticz" system? The meter I want to plug in has an S0 pulse output and an M-BUS output.
    Is it possible to connect the pulse output directly to GPIO pins in Raspberry Pi?
    We don't write text in block letters on the forum.
    Moderator Krzysztof Reszka.
  • #2 17084098
    robkry
    Help: 11
    Or maybe via WiFi? Take an interest in the ESPEasy project.
    https://www.letscontrolit.com/wiki/index.php/ESPEasy
    It allows you to remotely connect multiple sensors and actuators.
    The project is still developing. I use it at home for over two years :)
    Here is an example of integration with a domoticz electricity meter:
    https://www.letscontrolit.com/wiki/index.php/TCR5000
  • #3 17084532
    boris82
    I have a meter and a rpi in one switchboard so it is obvious that it would be better to do it in a cable.
  • #4 17095660
    boris82
    I found a device that should be perfectly suitable for connecting the S0 pulse output from an energy meter to the Domoticz system
    S0 Pulse Counter Module
    http://www.smartmeterdashboard.nl/webshop
    did anyone have to do this interface and can you buy it in Poland ????
  • #5 17207213
    DJ MHz
    Help: 40
    Rate: 253
    take interest in the modbus, what is the counter? Energy suppliers? If so, modbus is blocked :(
  • Request for LE-01MR Domoticz integration manual
    #6 18033273
    hanskie
    Rate: 10
    I don't want to start a new thread, and this one seemed similar to my question.
    I have a F&F counter from Pabianice model LE-01MR. Has a modbus
    Have any of you remade his raspberry and domoticz connections?
    I found only a plugin for the SDM120 / 360 counter on the network.
    could somebody direct me to some manual how to integrate this meter and read it in domoticz?
    I will be grateful for your help.
  • #8 18035008
    hanskie
    Rate: 10
    Nice, I already knew the links before. The only problem is that I am not a specialist in automation, BMS etc. ;-( it is a pity that there is no ready plugin for domoticz as it is the case with SDM counters.
The discussion revolves around connecting an electricity meter with S0 pulse output and M-BUS output to the Domoticz system using a Raspberry Pi. Users suggest various methods, including direct wiring to GPIO pins and utilizing WiFi through the ESPEasy project for remote sensor integration. A specific S0 Pulse Counter Module is recommended for interfacing with the meter. Additionally, there are inquiries about integrating a specific F&F counter model LE-01MR with Modbus capabilities into the Domoticz system, highlighting the lack of ready-made plugins for certain meters. Users share links to resources and manuals for further assistance.
