Fiat 500 Cluster Change & KM Adjustment - Can Proxy Align Lower KM to Original?
Milos Kosanovic 2577 5
  • #1 19296438
    Milos Kosanovic
    Hi everyone
    I need to change my cluster and if I put cluster with lower km can I do proxy to put my km back?
    • Fiat 500 Cluster Change & KM Adjustment - Can Proxy Align Lower KM to Original? IMG_20210227_183655.jpg (2.44 MB) You must be logged in to download this attachment.
  • #2 19299548
    beryas
    Help: 152
    Rate: 414
    As soon as you turn on the ignition with a new top, the mileage (the larger one) will be rewritten to the rest of the drivers.
    Hang a new electronic meter for cleaning or buy a meter with a lower mileage, then the new meter will fit your mileage.
  • NQS EEPROM copy or proxy alignment options
    #3 19299765
    damdam
    Help: 274
    Rate: 950
    Will Fiacik really rewrite the mileage from NQS to NBC or NCM?
    There are several options ... you can reset the waveform in NQS, run PROXI alignment, and then set the correct odometer state, you can copy the EEPROM (or virtual EEPROM of the processor) between the old and new NQS - full freedom.
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #4 19299796
    melas
    Help: 138
    Rate: 690
    Multiecuscan will run you upwards, not the other way. If you have one, of course
  • Proxy alignment and EEPROM copy can preserve mileage
    #5 19299913
    beryas
    Help: 152
    Rate: 414
    I am not 100% sure, because I do not sit in the mileage on a daily basis, but some counters have been replaced and most cars after 2005 rewrite the mileage between the drivers, although in 500 it can be like a ducato that after such a mileage flashes non-stop.
  • #6 19300923
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 559
    What for? They are all the same, you can’t change it.
