Spc Gear Viro Plus Mic Issues: Microphone Not Working with Headphones & AGC Noise
xBelus 15954 5
  • #1 19328641
    xBelus
    Hello, I have spc gear viro plus headphones, with a sound card from the set. Overnight, without turning off the computer, the microphone stopped working. Namely, the microphone does not work at all when it is connected to the headphones, but when I connect the microphone itself to the computer, it works. When I turn on AGC in the microphone sound settings, there is noise. Please help me quickly
  • #2 19330757
    artbi881
    Level 30  
    Help: 130
    Rate: 264
    I read it twice and didn't understand much of it, according to the initial diagnosis, you have it set wrong, sometimes it happens when the game is online :)
  • #3 19726652
    lisekd22
    If someone had a similar problem, let him try to attach Jack to the sound card or headphones
  • #4 19831014
    Elderok
    I have the same thing, do you know how to fix it?
  • #5 19832538
    19acid88
    Level 4  
    I also have so much that I do not have the plus version with the card. The mic doesn't work and the headphones do. There is clearly something wrong with this series
  • #6 20421219
    wankiewiczkuba
    ] After a year, I'm tapping into the subject. I also have these headphones without a plus and the mic does not work for me. Have you found any solution?
