[Solved] Does any of you have an OSS TEAM T12-X soldering station and would like to give
mtbchn 14877 9
Is the OSS TEAM T12-X soldering station a good choice, and is it as successful as the KSGER T12 station?
It seems to be a decent T12 station, but not a breakthrough over KSGER. One user who used it at work for 3–4 months said it heats up very quickly, the handle is comfortable and the tip sits firmly, so overall it is pleasant to work with and worth recommending at around 300 PLN [#19485030] The reported downsides were a thin stock cable that may not last long, a sleep function that sometimes fails to wake properly, and a pulse generator that occasionally loses steps [#19485030] Another reply called it basically an older T12 design with an added PE cable, ESD Safe marking, and accessories, but concluded there is “no revelation” [#19484653] It was also noted that OSS firmware is open source and that the TEAM version is on STM32, which is why stock was unavailable at the time [#19484695]
  • #2 19409836
    dasej
    Level 32  
    Help: 165
    Rate: 267
    Why not a transformer?
    All leading manufacturers of soldering stations use transformers in their designs
    not converters.
    Personally, he has a soldering station at home with a transformer inside and I think it's a better solution than
    converter station. More reliable separation of the flask from the 230V mains.
  • #3 19481404
    elktr_infrm
    Help: 35
    Rate: 25
    Is the price of ~3k PLN a normal price for this soldering iron or is it a speculative pandemic price?
    How much did this model (specifically TEAM T12-X) cost in the past?
    For my taste, it is a soldering iron for ~ several hundred zlotys, which would be confirmed by the following link:
    [url=]https://katemedia.pl/pl/strona-glowna/1094-stacja-lutownicza-oss-t12-x-lutownica-cyfrowa-72w.html[/url]
  • Transformer-based station seen as more reliable than converter type
    #4 19481704
    tzok
    Help: 3176
    Rate: 6549
    This is not a "pandemic" price, but a temporary lack of goods ... and due to Allegro's policy, it does not pay to remove the offer and then restore it, it is better to set a prohibitive price.
    A station with a transformer power supply and a transformer soldering iron are two different things...
    After all, the converter also has a transformer and there is no galvanic connection between the secondary and the primary side. It may be more emergency, but it is much smaller, lighter and cheaper.
  • #5 19481738
    elktr_infrm
    Help: 35
    Rate: 25
    And what is the standard price?
  • #6 19481804
    tzok
    Help: 3176
    Rate: 6549
    Around PLN 240-270.
  • #7 19484653
    spy
    Help: 86
    Rate: 261
    This beauty looks like an older version of the T12 on the STC chip. They soldered the PE cable (I don't know why), added ESD Safe, added accessories, increased the price... In my opinion, no revelation.
  • #8 19484695
    tzok
    Help: 3176
    Rate: 6549
    The OSS firmware is Open Source unlike other Chinese T12's. OSS TEAM is currently on STM32 and therefore no one has them in stock at the moment.
  • OSS TEAM T12-X review: fast heat, weak cable, sleep bug
    #9 19485030
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    I've been using it at work for about 3-4 months, with the same stock as in the photo in the auction. It heats up very quickly, the stock is comfortable, handy, the tip sits rigidly, it does not fly sideways (which I was afraid of). Overall, it's pretty fun to work with. As for the disadvantages, I would replace the poor cross-section of the stock cable - I do not predict a long life for it. In addition, the station has a "sleep" function, i.e. if the stock is not moved for some time, the temperature of the tip is automatically lowered. After picking up/moving the soldering iron, the soldering iron should exit this mode, unfortunately sometimes it does not want to surprise and you have to "reset" it with the switch on the back. One could still find fault with the pulse generator, which does not sin with quality and "loses" steps, but there is no tragedy (at least for now). I haven't noticed any other problems. Overall, for the price at which it was available at the time (around PLN 300), I highly recommend it.
  • #10 19616832
    mtbchn
    In the blink of an eye, based on my own deduction.
The discussion revolves around the OSS TEAM T12-X soldering station, with users sharing their opinions and experiences. Some participants compare it to the KSGER model, questioning its price and design. Concerns are raised about the price being inflated due to market conditions, with estimates suggesting a standard price range of PLN 240-270. Users note that the OSS TEAM T12-X features open-source firmware and a quick heating capability, but some report issues with the stock cable's durability and the soldering iron's sleep function. Overall, while some users find it enjoyable to work with, there are suggestions for improvements in design and functionality.
