Tuya and Zigbee programming assistance
tonygold 12429 18
How do I add Tuya/Smart Life devices and create automations or scenes in the app?
First add each device in the Smart Life/Tuya app by putting it into pairing mode according to the manual and letting the app detect it [#19421477] After the devices are added, open the Automation tab and use the “+ / Add new” wizard to build a rule [#19421477] Start with a trigger, such as a time, weather event, or a device state change, then choose the action to perform, such as switching another light off [#19421678] You can also add multiple conditions, choose whether all conditions must be met or only one, and insert delays [#19421678] For simple scenes, use “Tap to Run,” where you add one device and then can include as many actions/devices as needed [#19421678]
  • Requesting Tuya and Smart Life setup help
    #1 19421164
    tonygold
    Rate: 122
    I have bought a whole set of home automation equipment: gates, door and window sensors, switches, etc. I am looking for someone who knows SMART LIFE or Tuya well and can help me programme it and, if necessary, program it.
    I am looking for someone who knows SMART LIFE or Tuya well and will help to program it all and, if necessary...
    All over the phone.
    Alternatively, I will pay for the service and learn to the extent that I am able to do it myself.
    Thank you in advance
    My telephone number is 512 009 248
    Best regards
    Tony
  • #2 19421477
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Start by adding devices - how: refer to the device manual. Generally you enter pairing mode and detect with the app.
    Once you have the devices in the app then go to the automation tab and at the top you have + - add new. The wizard will guide you.
    If you have any questions - write.
  • #3 19421653
    tonygold
    Rate: 122
    Thank you for your answer, but to this extent I understand it, it is about the moment when I have to write the scenario and this is already more difficult.
    That's why I would prefer if there was someone to help me by phone.
    Regards
    Explaining Smart Life wizard, conditions, and tap to run
    #4 19421678
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    I can't imagine explaining this over the phone.... Something else to show 'live'.
    The wizard itself in SMART LIFE is very intuitive - you start with a trigger - i.e. an event to trigger the automation - e.g. light on, weather, time. Then the actions to perform - e.g. turn off another light. When you get to the end of the wizard you can add other events and condition them - e.g. both must be met, or one is enough. You can also add actions and delays.
    "Tap to Run" - here you have something like scenes - do with one device and at the end you add as many devices as you want.
    Play around, you'll find it's easy :) .
  • Gateway works on another modem but not mine
    #5 19463528
    samedi
    sk1977 wrote:
    Start by adding devices - how: see the device manual. Generally, you enter pairing mode and detect with the app.
    Once you have the devices in the app then go to the automation tab and at the top you have - add new. The wizard will guide you.
    If you have questions - write.
    Hello I bought a Wireless ZigBee Gateway by Moes (Tuya) and I can not connect to it. I tried more than 10h in different ways restart the modem, factory settings, without access to the net, etc no application connects, I thought defective but I went to a neighbour has a modem of another company and with him the first time after 30 seconds connected. What can I do to get it working for me too apart from changing the modem?
    PS. The modem I have is new from the operator is 3 months old and is the latest product of this company.
  • #6 19463533
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Wireless ZigBee Gateway is not a modem. What do you actually want to do? For what purpose do you want to connect?
  • Neighbor’s modem works with the Zigbee gateway
    #7 19463540
    samedi
    Yes I know it's not a modem it's supposedly a gateway. (That ring that is supposed to rule others). But for it to do that it has to be connected to my modem my network.
    I bought a light switch on WiFi doesn't work because I don't have an N wire in the socket, I bought another one that doesn't use an N wire. It works but the control from the phone doesn't work because it's ZigBee.
    I bought a Wireless ZigBee Gateway - because supposedly it is needed to connect to this light switch and other devices. But it's not pretty here either. I can't connect to it with any app, on my neighbour's modem another modem works fine.
  • #10 19463551
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Check that you have 2.4 GHz WiFi and a phone connected to this WiFi. The security of this WiFi, for example, could also be a problem. A 2.4 and 5 GHz network with the same name could also be a problem.
  • Speedport Smart 3 likely blocks Zigbee hub pairing
    #11 19463553
    samedi
    Yes I know that on 2.4 the phone I am supposed to have in the modem has separate names for the given transmission 2.4GHz is Radio while 5GHz is Radio5 in total the Smart life program itself (this is given by the manufacturer) as well as Tuya Smart tells me to change the connection. I have several devices hooked up to 2.4GHz Led strips and light switches in the terrarium (they turn themselves on/off at given times, But this is after WiFi - Magic Home). Not as in this case ZigBee
    It just seems to me that the modem I have does not allow the connection of this Gateway - Hub because, as I wrote, I spent more than 10h on it changing names, factory settings of the modem, with and without access to the network, and at my neighbour's it worked immediately after entering the network password in the programs I previously connected to his network with my phone.
    My modem: Speedport Smart 3 neighbour's FRITZ!Box 7530
  • WPA2 security restored after connection test
    #13 19463728
    samedi
    I will check WEP.
    I've been to a friend's house they have a FRITZ!Box 7430 older than the previous one I tested at my neighbour's and they also connect after 20 secs with no problem and I think this Gateway of mine got an update but it didn't change anything for me. I didn't log out of her modem thinking I would connect to the light switch since the tel is paired but no because I don't have her modem without the modem nothing works.
    Added after 1 [hour] 5 [minutes]: .
    sk1977 wrote:
    Change to WEP on a trial basis and see if it works.
    Lord I did not think of that. I changed the connection to WPA because that's what I have and the connection already worked like others in 20.sec. I changed the security back to WPA 2 as it was from the manufacturer and it still works.
    Simple solution.
  • Clarifying Zigbee pairing for new devices
    #14 19813383
    samedi
    I will dig up the topic. I need some clarification help.
    I have this ZigBee 3.0 smart gateway Hub ()https://pl.aliexpress.com/item/4000504896650.html?spm=a2g0s.9042311.0.0.215d5c0fydS7VU
    to this I have purchased
    włącznik światła https://pl.aliexpress.com/item/1005002061590357.html?spm=a2g0s.9042311.0.0.215d5c0fydS7VU
    i pilot https://pl.aliexpress.com/item/10050023624968...tml?spm=a2g0o.detail.1000023.6.326627da4diQLV
    I set the whole thing up in the Smart Life application (I turn the light on and off on the wall switch as well as from the remote control) In the application I have added these 2 devices Gateway
    When I enter I click on Gateway I have these 2 devices as added.
    I have bought the Led bar controller https://pl.aliexpress.com/item/1005001918665476.html?spm=a2g0o.9042311.0.0.27425c0fjnHtke
    Dokupiłem sterownik oświetlenia https://pl.aliexpress.com/item/1005003093336697.html?spm=a2g0o.9042311.0.0.27425c0f5jvlFd
    everything works in the application and from the remote control but the 2 recently purchased devices are not in the application when I enter the Gateway I have these 2 devices as added light switch and remote control.
    These recently purchased devices occupy IP ports on the modem and do not connect through the Gateway but through the modem.
    What have I done wrong how to add them to the Gateway?
    I go into the Smart Life application, click on Gateway at the very bottom, click Add slave device and I do not find the Led bar (this I have at hand because the lighting controller is under the ceiling)
    I only find it in the Smart Life app when I click at the top of the program.
    How do I get these 2 devices to connect to the Gateway and not the modem?
  • #15 19813455
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    samedi wrote:
    What did I do wrong how to add them to the Gateway?
    - you won't add them to the gateway. They are on WiFi and you can add devices to the gateway on zigbee.
    You add to the app -
    samedi wrote:
    only finds it in the Smart Life app as I click the + at the top of the program.
    - that's how you add.
  • Zigbee Tuya buying advice and gateway range issue
    #16 19813746
    samedi
    Zzzzz then when buying what should I look at?
    When searching I typed in zigbee tuya what phrase correct and what to look at before making another wrong purchase?
    Because this lighting controller https://pl.aliexpress.com/item/1005003093336697.html?spm=a2g0o.9042311.0.0.27425c0f5jvlFd
    annoys me it is 3-4m from the Gateway / modem and there is no range I already wanted to buy another Gateway to put it in the kitchen where that controller is and today when I was making locks on the modem for devices using my WiFi I caught that these 2 devices do not connect to the Gateway.
  • Zigbee devices extend mesh range for powered nodes
    #17 19813809
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    samedi wrote:
    Seeking I typed in zigbee tuya
    - and the mechanism also showed results for just one phrase: "tuya".
    - read the description. e.g. this controller does not have in the description zigbee "Tuya WiFi switch smart switch module 4 Gang switch module lighting APP remotes control conversion module for Alexa Google" and is clearly WiFi.
    The advantage of zigbee is that almost all (from what I remember I think there were some exceptions) powered (not battery powered) devices extend the range of zigbee.
  • Tuya flood valve may fail without Wi‑Fi
    #18 20197543
    pdusp
    Rate: 15
    I would like to build such a simple system for my bathroom to detect flooding, water sensor + ball valve.
    You can get all this from Tuya, but according to me and here I am not sure that the valve closes and the sensors and the valve must be online via wifi connected to a server?
    and I often turn off the wifi at home, and always at night, and when I go away
    so this system will not protect me....
    Am I right?
    Thank you and best regards
    Peter
  • Power-loss state cannot trigger Tuya scene off
    #19 21027842
    fazy2
    I am asking for help in setting up a scene which is to look as follows. A Tuya switch which, when no power is given (off), is supposed to override the second one to which the bathroom fan is connected and is supposed to switch off. The first one, which I have called the controller, goes "on" when power is applied and turns on the fan controller. However, I am unable to set the stage to switch off. The said controller is connected to the lighting, which is the power supply of this controller. By setting in the scene that when the controller is "off" or "no power" it is supposed to switch the fan controller off does not work. Conversely when the controller is off due to no power after setting the scene when it is "on" it turns the fan on.
The discussion revolves around programming and troubleshooting issues related to home automation devices using the Tuya and Smart Life applications. Users seek assistance in setting up devices such as ZigBee gateways, light switches, and sensors. Key points include the process of adding devices through the app, creating automation scenarios, and resolving connectivity issues with ZigBee gateways. Users also share experiences with different modems affecting device connectivity and discuss the importance of WiFi settings. Additionally, there are inquiries about specific device compatibility and setup for home automation systems, including flood detection and control mechanisms.
TL;DR: Zigbee runs at 250 kbps on 2.4 GHz and is a "wireless mesh"; connect your hub, build Smart Life automations, and remember Wi‑Fi devices don’t join Zigbee hubs. [What Is Zigbee?]
Why it matters: This FAQ helps Smart Life/Tuya users fix pairing issues, choose the right devices, and create reliable automations for homes with Zigbee and Wi‑Fi.
How do I add devices and build automations in Smart Life?
Add devices using each product’s pairing mode, then open Automation and tap +. Pick a trigger (time, sensor, switch), add actions, and set conditions or delays. Use Tap‑to‑Run for one‑tap scenes that control many devices. “The wizard is very intuitive.” [Elektroda, sk1977, post #19421678]
My Tuya/Moes Zigbee Gateway won’t connect to Wi‑Fi. How do I fix pairing?
Ensure your phone and hub use 2.4 GHz, not 5 GHz. Give 2.4 and 5 GHz different SSIDs to avoid confusion. Confirm you’re entering the correct password and disable band steering during onboarding. Reboot the router and try again. Some routers struggle to add devices when both bands share one name. [Elektroda, sk1977, post #19463551]
Pairing only worked on a neighbor’s router. What finally fixed it?
A user solved this by temporarily changing the Wi‑Fi security mode (e.g., toggling WPA setting), pairing the hub in about 20 seconds, then switching back to WPA2. After that, the gateway operated normally on WPA2. This quick change often clears onboarding blocks on some routers. [Elektroda, samedi, post #19463728]
Why doesn’t my LED controller show under my Zigbee gateway?
It’s a Wi‑Fi device. Only Zigbee sub‑devices join a Zigbee hub. Add Wi‑Fi controllers with the app’s + button (not via the gateway’s “Add sub‑device”). The gateway will only list devices that speak Zigbee and joined its network. [Elektroda, sk1977, post #19813455]
How do I avoid buying Wi‑Fi when I want Zigbee?
Read the listing carefully. Look for “Zigbee 3.0,” “Tuya Zigbee,” or “Zigbee hub required.” If the title or specs say “WiFi,” it’s not Zigbee. When in doubt, check the “Protocol” or “Wireless” field, and the app compatibility notes. [Elektroda, sk1977, post #19813809]
Will a Tuya water leak sensor and valve work without Internet?
Yes, if both are Zigbee and bound to your Zigbee hub, the sensor can command the valve locally. Zigbee is a local 2.4 GHz mesh, so device‑to‑hub control does not require the cloud. You’ll still need Internet for remote phone notifications outside your LAN. Choose Zigbee versions of both devices. [What Is Zigbee?]
Can using the same SSID for 2.4 and 5 GHz break onboarding?
Yes. Some gateways and phones fail to complete pairing when both bands share one SSID. Give 2.4 and 5 GHz unique names, connect your phone to 2.4 GHz during onboarding, then pair the hub again. This avoids band‑steering traps. [Elektroda, sk1977, post #19463551]
What frequency and data rate does Zigbee use, and can Wi‑Fi interfere?
Zigbee operates in the 2.4 GHz band at 250 kbps, the same spectrum Wi‑Fi often uses. Keep your Zigbee hub some distance from the router, avoid co‑located antennas, and minimize overlap by moving the hub away from dense Wi‑Fi areas. This reduces packet loss and latency. [What Is Zigbee?]
How do I create a scene so the light switch also turns the bathroom fan off?
Use Smart Life Automation. 1) Automation > + > select the light switch’s Off as trigger. 2) Add action: set the fan controller to Off. 3) Optionally add a delay or extra conditions. You can mirror this for On if needed. “The wizard is very intuitive.” [Elektroda, sk1977, post #19421678]
Why doesn’t my fan‑off scene trigger when the controller loses power?
If the controller loses power, it can’t report an Off event, so the automation won’t run. Automations need a live trigger to fire. Keep the controller powered, use hardware wiring that keeps its supply independent, or use a module that senses mains presence and reports state. [What Is Zigbee?]
Do Zigbee mains‑powered devices extend network range?
Yes. Most mains‑powered Zigbee devices act as routers that relay messages, expanding coverage and improving reliability. Battery devices usually don’t route traffic. Strategically place powered nodes between your hub and remote sensors to strengthen the mesh. [Elektroda, sk1977, post #19813809]
Do I need a Wi‑Fi or LAN Zigbee gateway?
Both versions exist. A Wi‑Fi gateway joins your 2.4 GHz Wi‑Fi, while a LAN gateway uses Ethernet. Choose based on where you can place the hub for best coverage and stability. Match the version you bought when following pairing steps. [Elektroda, sk1977, post #19463543]
I don’t have a neutral wire. Which Tuya switch should I use?
Pick a “no‑neutral” model. These switches are designed for installations without an N conductor and can still control lighting. Confirm compatibility with your bulb type and follow the manufacturer’s wiring guide. If needed, add the recommended bypass to prevent flicker. [Elektroda, samedi, post #19463540]
