ESP8266/ESP32: DOUBLE to INT conversion - how to write the first number after the decimal point?
powerT 1041 3
  • Floating-point rounding causes off-by-one digit extraction
    #1 19501334
    powerT
    how to solve this problem?
    suppose
    DOUBLE number = 23.4;
    int digit1 = int(t) / 10; // takes the value 2 (it is OK)
    int digit2 = int(t) % 10; // assumes value 3 (it is OK)
    double temp = int(number) - number; // temp takes the value -0.4 (it is OK)
    temp = abs(temp); // temp takes the value 0.4 (it is OK)
    int W = temp * 10; // 0.4 * 10
    Serial.println(W); is 5 !!! (why is it always 1 more) ????
    How to get around this, in total it needs to write the first number after the decimal point to the INT variable. Any other solution ?
  • #2 19501917
  • Floating-point rounding causes wrong decimal digit extraction
    #3 19506446
    powerT
    khoam wrote:
    What is the result of the following command?
    Code: C / C++
    if temp is 0.4 then the result is 3.0000 at Serial.println(temp * 10, 5)
    it still rounds strangely.
    even so
    double t = 23.4;
    double partTotal;
    int digit3 = modf(t, & integer part)*10; // result 3 !!! should be 4
    int digit1 = int(partCalculus) / 10; // result 2 (OK)
    int digit2 = int(integer part) % 10; // result 3 (OK)
    ---- ROZWIAZANE --------------------------------------------------------------------------------
    This is how I finally managed to get the correct value, only that overall the method of
    calculations almost the same - it's a conundrum yet....
    double t = 23.4;
    int digit3 = (t*10); // gets 234
    Serial.println(digit3); // gets 4
  • #4 19506613
