What cables to run to the external LTE antenna?
rafmik 22890 48
What cable should I pre-install between the router location and a future external LTE/5G antenna over a 15 m run?
Run Ethernet, not a 15 m passive LTE antenna coax: the suggested solution is to place the LTE router/CPE as close to the antennas as possible and bring the network inside over twisted pair, using external gel-filled Cat. 5e for the outside run and Cat. 6A U/UTP full-copper for the house wiring [#19595384] [#19595300] [#19595337] A 15 m RF coax run was considered too long; one reply said LTE antenna cables should ideally be up to 5 m and at most 10 m because cable loss can outweigh the antenna gain [#19595178] [#19595307] If you want future-proofing, lay an empty HDPE pipe or at least a 25–28 mm conduit so a different cable can be pulled later [#19595300] [#19595689] For the rest of the installation, use separate full-copper UTP Cat. 6A runs to each point, with keystone sockets/patch panel, and avoid cheap cables [#19595337] [#19595313]
  • #1 19595113
    rafmik
    Rate: 37
    Hi :)
    What cables are best to route to the external antenna for 4G and future 5G?
    I mean the cables from the place where the router will be located to the place where the antenna will be (barrier on the balcony). I am before renovation, so I can put everything without stress.
    What cables are best to pull? You will need about 15 meters of cable. I know it must be x2 antenna cable and 1x ethernet cable for sure. But what exactly do you recommend? It's about resistance, etc. I read that antenna cables with such a length and working with LTE require low resistance. Type LMR400 cables?
    And what about the Ethernet cable for power and data?
    At the moment I do not know which operator I will use, I do not know what the modem/router/antenna will be.
  • #2 19595178
    IC_Current
    Help: 1495
    Rate: 2499
    15m wires are definitely too much for an LTE antenna, optimally up to 5m, max 10m. The router needs to be placed in the attic and in the house, additional access points should be placed in the rooms to improve the range of the WIFI network. Dedicated cables must be led from the attic to stationary receivers.
    As a rule
    From the attic to each room you run two UTP cat. 6A cables and one RG6 cable for the TV. Four UTP cables to the living room, cat. 6A. You connect the cables in the attic to the switch, to which you also connect the router. In the rooms, you terminate the wires with sockets and connect the PC, TV, tuners, set-top boxes, PlayStation, etc. to the sockets. You also connect additional access points to the sockets, if necessary.
    Of course, from the attic you also need wires for the alarm, boiler room and empty fi 28 pipes to sensitive points in the house. Then in 10-20 years you will lead what wires will be needed then and what is not in use today without another forging of the walls.
    As for the antenna itself and the railing - if you don't know which operator, how do you know that there will be an antenna on the railing. Rather, it will have to be placed in the appropriate roof top or on the chimney directed to a specific broadcasting station.
  • #3 19595213
    tomi44
    Help: 21
    Rate: 54
    IC_Current wrote:
    From the attic to each room you run two UTP cat. 6A cables and one RG6 cable for the TV. Four UTP cat. 6A cables to the living room.
    Could you clarify why two UTP wires for each room and 4 UTP wires for the living room?
  • #4 19595232
    IC_Current
    Help: 1495
    Rate: 2499
    First of all, one can always be damaged, even a mouse in the attic will bite through, and such wires cannot be repaired without damaging the transmission. Only exchange is possible. In addition, you have, for example, one TV port, another AP, or one PC port, the other printer, or TV+printer, etc. without using additional switches. In the living room, on the other hand, four are not enough - TV, AP, set-top box, PlayStation, receiver, monitoring preview, NAS and many different gadgets that people have.
  • #5 19595289
    rafmik
    Rate: 37
    Just meters of cable will be about 15 and it is impossible to jump over. All wires in the house will meet in the utility room.
    And here is the question of which cable to jump over this problem.
    Because from what I know Ethernet with power works without any problems up to 30 meters? It is an antenna where the modem itself is part of the antenna.
    IC_Current wrote:
    As a rule
    And why cat 6a and not standard 5e?
    There are only two transmitters in the area (one is Play, T-Mobile and Orange, the other is Plus, T-Mobile and Orange), the antenna in the place where it will be screwed will be able to set to both transmitters.
  • #6 19595300
    IC_Current
    Help: 1495
    Rate: 2499
    Ethernet works without problems, not up to 30 only up to 100m. However, if for some reason you ran the antenna cable, then unfortunately after 10m it is already worse than what you gained on the antenna. In addition, it's better to let go of an empty fi 28 pipe and in the future pull in the antenna wires. Of course, lay the UTP cable as much as possible now. The cable to the "antenna" is external, gel-coated (in a black sheath).
    Because the difference in price is practically non-existent and the possibilities are much greater. On 5e it is standard 1000Mbps per 100m. In cat 6A it is already 10Gbps per 100m and even 40Gbps on shorter sections. This gives you more possibilities in the future, e.g. copying files to a NAS, PC backup or connecting an unlimited fiber optic link above 1Gbps (and such offers are already appearing). Slowly, computers with 2.5Gbps and even 10Gbps cards are already falling under the common thatch.
    You do installations for 30 years, not for now, and you have to think ahead.
    One more note to the wires - only branded products, no junk from supermarkets, because they have nothing to do with the category given on the print.
  • #7 19595303
    rafmik
    Rate: 37
    Thanks for the info :)
    I will tell the electrician about better cables.
    So, for example, you suggest that with an external antenna, you should not go to antenna cables at all, but only ethernet?
    And tune in to the antenna with the modem?
  • #8 19595307
    IC_Current
    Help: 1495
    Rate: 2499
    How good an electrician is, you don't need to tell him. If it's average, and there are many, it can really mess up your computer network. You have to keep an eye on it, because, for example, the antenna wires are very poor and only the TV works, but there are huge attenuations on SAT and then surprise that it breaks the picture in winter. Also, keep an eye on it so that it doesn't bend computer cables too much, step on it or cut it too short. There should be about 20 cm of spare in the socket on the wall, and in the crossover cabinet, the reserve after making all the keystons should be about 1 m (i.e. before mounting the cabinet, the wires should protrude from the wall by about 2.5 m. Electricians often leave a reserve as for electrical wires. Then they piece and add these network cables are completely destructive for transmission parameters.
    Good cables are Draka, Bitner, Telefonika, or those offered by the Dipol store.
    Antenna wires are also to be copper and at least A++ class and make sure that the electrician buys such wires and confirms it with a certificate. Of course, the certificate can be substituted from another cable, so it's best to buy antenna and network cables yourself, and let the electrician just lay them.
    The SAT antenna itself, if you install it, is optimally 80 or 90 cm in diameter, then in winter and during a storm there are no image loss.
  • #10 19595316
    KOCUREK1970
    Help: 3805
    Rate: 5354
    You, this electrician, better control what he does, because electricians and teletechnical installations are not the best combination.
  • #11 19595321
    rafmik
    Rate: 37
    I'm guessing, but this is a detached house, not a server room ;)
    There will be 2 network sockets in each room, 4 sockets in the living room behind the TV, and a cable to the access point will be led out on the ceiling at the bottom, more or less in the middle of the house. Plus, cable routing to the LTE antenna, which will be at the railing or on the rafter (semi-passive house, no chimneys). The SAT antenna itself will be standing on the ground. All cables will come together in the utility room.
    I wonder what about DVB-T.
    IC_Current wrote:
    Also, keep an eye on it so that it doesn't bend computer cables too much, step on it or cut it too short. There should be about 20 cm of spare in the socket on the wall, and in the crossover cabinet, the reserve after making all the keystons should be about 1 m (i.e. before mounting the cabinet). these network cables are completely destructive for transmission parameters.
    Thank you very much for the useful information :)
  • #12 19595328
    adwlodar
    Help: 111
    Rate: 245
    It doesn't matter. And if your electrician said so, I would thank him. Because then you come to the job and you see a twisted pair from socket to socket ...
    It's sad that this opinion is sometimes still true.
    Added after 52 [seconds]:
    rafmik wrote:
    in addition, on the ceiling at the bottom, more or less in the middle of the house, there will be a cable to the access point
    What about the upper floor?
  • #13 19595334
    rafmik
    Rate: 37
    I'll ask again. Twisted pair 6A UTP or FTP?
    House 120m2
    One such AP will not cover the house? Do you need upstairs too?
    KOCUREK1970
    Help: 3805
    Rate: 5354
    This is not the point - for 90% of electricians, teletechnical wires are treated as current wires, because a wire is a wire ...
    Coaxial cable: TriSet PROFI.
    Twisted pair in the walls: Madex, Bitner, NETSET, NEKU, Ultralink, BitLAN, full copper, wire (in walls), stranded (other applications), preferably cat6a, UTP.
    Optical fiber: G652D fiber, G.657A2 can also be used.
    To each point where you want a socket: 2 coaxial cables (I would give 2, you will use one and the other in the case of W), 2 twisted pairs and 1 optical fiber, living room even 4 twisted pairs, 4 antenna wires and 1 optical fiber.
    It is also worth spreading the twisted pair on the ceiling in each room, so that you can possibly hang the AP there.
    Instead of expensive RJ45 network sockets, much cheaper and giving the same effect: frames and keystones.
    In addition (if there are plans) appropriate cables for all devices such as: alarm, monitoring, central heating stove, intercom, photovoltaics / panels, intelligent home control, etc.
    Coaxial, network, optical fiber cables must not be bent at an angle of 90 degrees, must not be broken at an even smaller angle, bent, pushed into the corners of the room.
    If possible, we arrange gentle arcs or a straight line.
    To the SAT antenna - 6 gelled wires lead outside.
  • #15 19595340
    adwlodar
    Help: 111
    Rate: 245
    UTP
    rafmik wrote:
    House 120m2
    Coverage and expected link parameters are two different things.
    No, it's not enough.
    Especially with 10 walls, reinforced concrete or teriva ceiling.
  • #16 19595349
  • #17 19595366
    IC_Current
    Help: 1495
    Rate: 2499
    The range of the high-speed WiFi network is up to one wall. The range of the latest AX solutions is practically one room. The rest of the range is old and overloaded 2.4GHz networks, and there you will get at most a dozen or so Mbps.
    UTP, because you do not need to ground, and at home there are no interferences like in an industrial plant or an office building.
    adwlodar wrote:
    and you see a twisted pair from socket to socket...
    Rather, electricians already know it, but you can still meet a bungler. Make sure that each cord from each outlet is routed separately to a closet in the utility room. This applies to both network and antenna cables.
    If you put a separate cable for each socket, it doesn't matter whether it will be SAT or DVB-T. You simply connect the cable from the socket to the appropriate antenna in the cabinet in the utility room. I now do it so that I run three wires from the SAT antenna to the patch cabinet and one wire from the terrestrial one. Mounts the 1xSCR+2xFB converter. Then I only send the SCR signal to the main decoder and the FB signal to the multiroom decoders, and if there is no multiroom or SAT at all, I just give the splitter and connect the signal from the terrestrial antenna. All on one wiring.
  • #19 19595400
    rafmik
    Rate: 37
    To each point where you want a socket: 2 coaxial cables (I would give 2, you will use one and the other in case of W), 2 twisted pairs and 1 optical fiber, even 4 twisted pairs, 4 antenna wires and 1 optical fiber in the living room.
    UTP cables will definitely be better, the decision was made after reading this topic - I was 5e, but changed to 6a.
    I planned the optical fiber between the boiler room and outside the house (there is no optical fiber on the plot yet, I'm doing it so as not to drill later). But actually, I think I will still run the fiber optic boiler room-living room. Thanks for the info on the type of fiber.
    As for the sockets, I plan to have 2xSAT, 4xethernet in the living room, now fiber optic cable has also been added. In the rooms 1xSAT, 2xethernet. In addition, on the ceiling in the central part of the house, an Ethernet cable is used to connect the Access Point.
    The SAT antenna will be on the ground, in front of the house. 6 cables in a blue conduit are supposed to go to it.
    As for Smart Home, the boxes are to be deeper (e.g. at roller blinds, light switches) - to add drivers someday. This is currently not possible due to cost reasons. It will be done gradually.
    In addition, a twisted pair cable will be laid from the power switchboard to the boiler room (where cables from the entire house will converge).
    There will be an ethernet cable for intercom and gate control.
    The installation will be prepared for photovoltaics (if there are panels, then on the ground, not on the roof)
    Alarm: there will be motion detectors, a reed switch at the garage door and one large opening window (HST), 2 fire detectors, 2 service keyboards (at the entrance and the garage, I'm thinking about one in the bedroom upstairs - to activate the alarm only downstairs at night ), the alarm control panel is to have such a function that it closes the water solenoid valve when the alarm is armed.
    Monitoring: Ethernet cables for 4 cameras, the whole thing converges in the utility room where the recorder will be, I want the cameras to have a "virtual border" function
    In addition, wiring for recuperation and heat pump control.
    If anyone has any suggestions on what else to add, please let me know. I will definitely consider. They will be laying the cables after the weekend.
    Erbit wrote:
    I don't understand the argument. Do you mean to say that at home you can practice bungling (and this is what we usually deal with here on the forum)?
    That's not the point. Unfortunately, within 6 months, the cost of building materials has increased so much that I have to keep costs in check.
    That's why now I care about getting the best wiring possible.
    Erbit wrote:
    We only warn by observing how it is made by others, e.g. copper-plated cables (because market and cheap) - but you can do as you want because "I won't live there".
    Here I already know that I will use better cables of the brands you mentioned.
  • #20 19595439
    IC_Current
    Help: 1495
    Rate: 2499
    Do not lead the optical fiber outside, because in the future the operator will rather not connect to this fiber. Firstly, it is not known what he will be laying himself (and different fibers are not welded), secondly, he will not take responsibility for his section. From the patch cabinet to the plot boundary, lay the HDPE pipe and the operator will blow what he needs there. Put the same pipe in the attic if the connection is overhead.
    As for the monitoring - only the cables from the cameras connected to the switch in the garage, but the recorder itself in the living room, then you have a direct view via HDMI on the TV. It is also good to give an additional recorder hidden somewhere in the attic with a UPS power supply (this power supply is also for cameras). Then if a thief steals or destroys the recorder in the living room, you have a second one with a copy of the painting in the attic.
  • #21 19595440
    rafmik
    Rate: 37
    The house will have 60m2 per level, 12cm ytong partition walls, 16cm reinforced concrete ceiling.
    One AP not enough? Now in my apartment I have a Mikrotik RBD52G hAP ac2 router with internal antennas and it covers the whole apartment without any problems in 5Ghz. It's more or less in the center of the apartment.
    And so he plans to connect the main devices (PC, TV) via Ethernet.
    Wifi is basically just phones, Smart Home.
    The SAT antenna will be on the ground, 6x antenna cables will go from it to the utility room. In the utility room there will be cables to individual rooms (2x living room, 1x in each room). In general, I do SAT only because there is no fiber on the plot. If it was, I would go to IPTV. And IPTV and access to the LTE network are a known failure.
    Now I'm at the cable stage. Converters etc. will be a topic in about 6-8 months. There are plans for a SAT decoder in the living room, a second decoder (multiroom) in one of the rooms, and only terrestrial on other sockets - if you manage to get it.
    As for DVB-T / DVB-T2, this is a big problem with coverage and I don't know what to do :(
    The emitter map shows this:
    For the location:
    MUX1: Possibly no coverage with a typical TV antenna
    MUX2: Possibly no coverage with a typical TV antenna
    MUX3: Crested
    MUX8: Crested
    DVB-T2 TVP test: Grzywacz
    DVB-T2 TVN test: Possibly no coverage with a typical TV antenna
    _cheetah_ wrote:
    On the other hand, if an external LTE modem integrated with antennas, i.e. the so-called CPE, is used, it is connected to the router / internal LAN network with a twisted pair cable and there is generally no problem here. It is only worth using an external twisted pair with gel (water protection). Cat. 5e.
    Here, due to the length of the cables (15m), I will go for the CPE solution.
    Here's a question - do you have to look at these antennas often? It will be at a height of about 6-7m with access only from a ladder :(
    Unless it will be installed at about 4-4.5 m on the railing next to the window, then access would be after opening the window. The distance to the transmitters is about 2.5-3 km. Nothing blocks the view.
    _cheetah_ wrote:
    From SAT, it is good to run at least two coaxial cables (black, if from Al, then with gel), from DVB-T one cable is usually enough (the same as for SAT). The installation location of the DVB-T antenna is subject to similar restrictions as in the case of LTE. How good it is, it can be anywhere, how bad it is with signals, not necessarily.
    With both LTE and DVB-T, the general rule should be that the higher the antenna, the better the signals. But unfortunately, that's not always the case. Remember that a mast over 3m is subject to notification.
    SAT and the DVB-T problem I described above
  • #22 19595454
    adwlodar
    Help: 111
    Rate: 245
    Damn, and a year ago I also pulled the Quatro + TV system :( Time to think about retirement...
    Can you expand on that? Is it something related to Unicable?
  • #23 19595466
    IC_Current
    Help: 1495
    Rate: 2499
    It's hard to predict here. no test in a specific place. Currently, however, the ceilings are heavily reinforced, which can greatly drown out the signal. For example, at my house (old building, without strong reinforcement - I just checked it now, the WiFi 5GHz signal has a level of -90dBm, i.e. not usable after going through the ceiling.
    As for the range of terrestrial TV. No real-world tests. You need to take the in-phase antenna, go to the roof with it and see the signal parameters on the meter (not on the TV, because there is no reference to the actual state). You probably need to hire someone to measure the signals. Except that with DVB-T2 it will only be worse than it is, so you also need to correct it.
    Added after 11 [minutes]:
    SCR is a technical name and Unicable is a marketing name for the non-technical.
    SCR has the advantage over multiswitches that, as a standard, you have four carriers on cheap equipment (that is, you record and watch as many as four channels simultaneously on a set-top box) on one cable. On the multiswitch, you need to lead two wires to the decoder (you watch and record only two programs). In addition, such converters often have two full band outputs for connecting standard decoders (in practice, just right for multiroom).
    On the SCR you can also have multiswitches if necessary in really large facilities. Then you connect the SCR converter with 16 or 32 carriers to the multiswitch with one cable and then distribute it to another SCR with four carriers or to a full band.
    You can also use Wide Band converters instead of SCR. Then you have an unlimited number of simultaneous channels on two wires.
  • #24 19595689
  • #25 19595861
    adwlodar
    Help: 111
    Rate: 245
    _cheetah_ wrote:
    But why retire immediately - you replace the multiswitch with a universal FullBand / unicable, and then you calmly replace subsequent set-top boxes with uni and you are "up to date" ... And what fun new set-top boxes ...
    Just nothing bought yet, just a midwife installation.
    So I will have to think and read carefully when buying what to choose.
    Thanks!
  • #26 19596803
    KOCUREK1970
    Help: 3805
    Rate: 5354
    @rafmik
    _cheetah_ wrote:
    LTE stands for "Here and Now". What may be lux today, in six months or a year may be mediocre or even tragic. C'est la vie...
    I don't know about my colleague, but I get here more and more often on topics that people from LTE inform that they are currently either being kicked out of the brazen BTS, or band aggregation stops working - but neither the client has changed the position of the antenna, modem or just the location in relation to mast and such flowers are starting to come out.
    Do not buy any antennas, nothing at this stage except the cable to the antenna itself, do not install the mast from the BTS side - when starting the LTE net at home, only check the signal from the BTS, what and how it aggregates and only then buy antennas, if any.
  • #27 19596914
    rafmik
    Rate: 37
    KOCUREK1970 wrote:
    @rafmik
    I'm talking about cables right now. Everything else is a topic for March-May 2022
  • #28 19879285
    rafmik
    Rate: 37
    For information:
    Delay after delay :/
    Virtually all of the cable suggestions in this thread have been done.
    Only the installation under the antenna from the Internet I changed due to the distance - there are no coaxial cables, there are only 2xUTP 6kat. So the antenna will have to be with a built-in modem. But that's a topic for April if all goes well...
    I am currently in the monitoring phase. 4 cameras, twisted pair connection, recorder. It would be nice if the solution was slightly intelligent - it would notify the phone when someone appears in the designated zone or crosses the virtual line. And it would be great if it was smart enough to distinguish a person from, for example, a dog or a bird flying by the camera.
    Anyone can recommend something? I start looking around.
  • #29 19880527
    Mxer123
    I'm thinking, once a long time ago I used H1000 wires for radios .... will they not work with such 15m?
  • #30 19880591
    matek451
    Help: 4328
    Rate: 5745
    The main obstacle with the H1000 is their price and the thickness and difficulty in routing such cables, of course, if someone knows how to do it, earn connectors and can afford 30m of cable, then why not.
✨ The discussion revolves around the optimal cabling solutions for connecting an external LTE antenna to a router, particularly focusing on the necessary lengths and types of cables. Users recommend using low-resistance antenna cables, such as LMR400, for distances up to 15 meters, while emphasizing that longer runs can lead to signal loss. Ethernet cables, specifically Cat 6A, are suggested for data and power, as they support higher speeds and future-proofing. The importance of proper installation practices, including grounding and avoiding damage to cables, is highlighted. Users also discuss the need for multiple Ethernet and coaxial connections in various rooms to accommodate devices like TVs, access points, and cameras. The conversation includes considerations for lightning protection and the use of patch panels for organizing connections.
TL;DR: Running 15 m of LTE coax can drop signal by ~6 dB—“15 m wires are definitely too much” [Elektroda, IC_Current, post #19595178] Place the modem/CPE outside and pull Cat 6A U/UTP (10 Gb s up to 100 m) [Elektroda, IC_Current, post #19595300]
Why it matters: Right-sized cabling saves every decibel of signal and every future gigabit.
• Cat 6A U/UTP supports 10 Gb s up to 100 m, yet costs only ≈5 % more than Cat 5e [Elektroda, IC_Current, post #19595300] • LMR-400 loss: 0.21 dB / m @ 2 GHz; 15 m ≈ 3.2 dB one-way [Times Microwave Data, 2024]. • 802.3af/at PoE delivers 48–57 V up to 100 m on 24 AWG copper [IEEE 802.3-2018]. • Cat cable bend radius: ≥4×OD; kinking cuts NEXT margin by ~40 % [TIA-568.2-D]. • CCA (copper-clad aluminium) adds 70 % resistance and voids PoE warranty [Fluke Networks, 2023].
1. What is the longest coax I should run between LTE modem and passive antenna?
Keep it below 10 m; at 15 m even low-loss LMR-400 drops ~3 dB each way, erasing antenna gain [Elektroda, IC_Current, #19595178; Times Microwave, 2024].
2. I must span 15 m—what’s the alternative?
Mount an outdoor CPE with integrated modem beside the antenna and feed a single Cat 6A to the router; Ethernet stays solid to 100 m [Elektroda, Anonymous, post #19595307]
3. Is Cat 6A really worth the upgrade over Cat 5e at home?
Yes. Cat 6A gives 10 Gb s for the life of the house, versus 1 Gb s on Cat 5e, with negligible price difference [Elektroda, IC_Current, post #19595300]
4. Should I use UTP or FTP inside walls?
Use U/UTP. Home environments lack the EMI that justifies shielded FTP, and unshielded cable avoids grounding headaches [Elektroda, adwlodar, post #19595340]
5. Why run two Ethernet lines per room and four behind the TV?
Redundancy plus device growth. A spare saves you if one line fails and covers TVs, APs, consoles, printers, NAS, etc. [Elektroda, IC_Current, post #19595232]
6. Will PoE still work after 30 m?
Yes. 802.3af powers 15.4 W and 802.3at 30 W over 100 m of 24 AWG copper with <3 V drop [IEEE 802.3-2018].
7. How do I protect outdoor Cat cables from lightning?
Bond shielded runs to the building’s grounding bar and add an in-line Ethernet surge protector before the switch; without it, adjacent strikes can fry ports [Elektroda, cheetah, post #19888707]
9. How do I terminate gel-filled outdoor UTP?
  1. Strip and wipe gel. 2. Feed conductors into a guided Cat 6 FTP modular plug. 3. Crimp with a front-feed tool; keystones are cleaner if space allows [Elektroda, IC_Current, post #19899908]
10. Will one Wi-Fi 5 GHz AP cover a 120 m², two-storey house?
Unlikely. Reinforced concrete ceilings cut 5 GHz by 20–30 dB; plan at least one AP per floor for >300 Mb s links [Elektroda, IC_Current, #19595366; Cisco Design, 2022].
11. Do I need fibre today?
Pre-run a spare micro-duct; operators prefer blowing their own fibre. Inside, a duplex OM3 patch from utility room to living room costs <€20 and future-proofs 40 Gb s [Elektroda, IC_Current, post #19595439]
12. What happens if I use copper-clad aluminium cable?
CCA’s 70 % higher resistance overheats PoE and often fails within two years, especially outdoors [Fluke Networks, 2023]. "Full copper or expect callbacks," warns an installer [Elektroda, Anonymous, post #19595349]
13. How to decide the best antenna spot in three steps?
  1. Attach LTE modem to test antenna on a 5 m pole. 2. Log RSRP/RSRQ in several positions. 3. Secure mount where SINR peaks; adjust later if speeds drop [How-To based on forum workflow].
