ESP12 recorder with html interface and external flash - concept
prm_ex 1785 23
How should I organize an ESP-12 project with an external W25Q128FV flash so I can log sensor data quickly and later download it from a phone browser as CSV?
Use a filesystem on the external flash rather than trying to manage raw bytes manually, and the SPIMemory library already supports reading and writing floats, strings, various int types, and byte arrays [#17953639][#18440608] The external flash size is limited by the ESP8266’s addressable memory range, so 16 MB is the practical maximum for this chip [#17956833] For faster logging, store each measurement as a fixed `Params` structure and write it as one block; then the next address is just `previous_address + sizeof(Params)` [#18446208] If you need to convert values like `float` into bytes, the thread suggests using a `union` for that [#18440608] The advice is also to start with the existing SPIMemory library and only optimize or replace parts later if needed [#18446208]
  • #1 17953634
    prm_ex
    The project I'm currently sitting on is storing frequent measurements from SPI sensors in an external W25Q128FV flash (because the internal one is too small).
    I came up with the idea to put the HTML and the configuration file in the internal flash with SPIFFS. To the external one will go the data.
    I plan to operate this from the phone via an interface written in HTML. The interface is supposed to be able to set configuration variables, control the esp code, display "live" some sensor data, start writing data to the flash, download previously saved data (csv or txt file), delete previously downloaded measurements (I plan to store max 2 measurement sessions - files).
    I have the sensors already figured out (I have made myself my mini libraries from the catalogue notes with only the functions I will use).
    I have html written. I also have the general execution algorithm of the code devised, but to the point....
    I would need advice/guidance in terms of the optimal concept of how to tie this together best.
    1. organisation of the external flash - the fastest write would probably be to split it into 2 parts and feed it with raw bytes. But as I will then want to pull this onto the phone to a csv or txt file from the browser, it is possible that it would be better to have a file system (FS or a second SPIFFS if possible) and write to files. Such a data set (file) may be 2-3 MB in size so I also need to take this into account to make room for RAM when downloading to the phone. I will not write this library myself. I will have to use some library (any light/easy ones you recommend)?
    2. WiFi - I understand that the appropriate ESP mode is AP?
    3. HTML live - in order not to refresh the page manually or at some interval I would probably have to harness websocket for this?
    4. the HTML is about 25kB. Should I load it into a variable (I'm not sure yet whether I can fit it in) or is it possible to pull it live from SPIFFS? Since the html will also contain changing data, buttons etc., I'm probably just going to have to load it into a variable anyway, right?
    Thank you in advance for any suggestions, and I will be happy to clarify the information if I am unclear.
    Yours sincerely
    Przemo
  • #3 17953980
    prm_ex
    So I understand not messing around with raw bytes to flash just setting up a file system.
    Hopefully it will be fast enough that I can manage to write 55 character lines say 100-150/s.
    I need to read up on the linked documentation because at first glance it's a mare.
    So far I can't see how I'd set up the CS and which SPI I want to let it go to (I'll have a second SPI besides the one for the internal flash) but I'll probably find one.
    A file with constants and variables + html of 25-30kB isn't too much so I probably won't use both flashes just batch, including data, better to do on the external one, eh?
    I haven't used it yet but I've been trying on the SerialFlash library.
    Seems so user friendly for a new user. Do you know/use it? Would it give any advice?
    Or is the one given in the post above the most efficient?
  • #4 17954002
  • #5 17954025
    prm_ex
    Well, that is what I am writing about. Maybe I didn't make it clear enough.
    4MB internal is not enough. Even if I gave 3 on SPIFFS.
    I have a W25Q128FV on the second SPI and two sessions of data writes (100-150 lines of characters, 150Hz) which can give files of about 2-3MB each + html 25kB + configuration file (e.g. ajax) with constants and variables will then fit me and I will leave the whole 4 internal for code (or 3/1 because I don't see the 4M no spiffs option).
  • #6 17954177
  • #7 17956325
    prm_ex
    With a file system it might not be enough anyway. Besides, ESP's12 and flash's I already have.
    Well ok, it stood to reason that, as intended in the first post, it would be best to put a file system on the flash.
    And what about the rest?
    Mode AP + websocketserver or is there another solution?
  • #8 17956559
  • #9 17956579
    prm_ex
    I don't think we understand each other very well. :) .
    I don't want to unsolder and replace the "internal" flash.
    The ones I have (W25Q128FV) are supposed to be an additional external flash (1 for one ESP), operated over SPI (12,13,14) using, as we have already established, a serialflash.
    Greetings
  • #10 17956595
  • #11 17956774
    prm_ex
    ESP8266EX uses external SPI flash to store user programs, and supports up to 16 MB
    memory capacity theoretically.
    hmmm, and by any chance, doesn't the referenced documentation talk about the external (for the microcontroller), in our case "internal" flash, where we put the code and where the bootloader is located? Isn't it the one that has this limitation, because such support is contained in that bootloader?
    In the case of a completely external flash, on a separate SPI, is it not the library used in the code that will limit the size supported?
    That's how I would understand it, but I'm not completely insistent. I'm still a thin bole in these blocks.
    Anyway, if this applies to any flash, by all means supported, then statically my W25Q128FV (128Mb=16MB) still catches on.
  • #13 17957466
    prm_ex
    I think the topic of flash can be considered solved and using it (16MB max) with the file system will be optimal for me, in this case, I understand.
    For the interface on the phone without having to navigate to subpages, would the mentioned wbsocket be the only and optimal one or any other alternative I should consider?
  • #14 17957485
  • #15 17957611
    prm_ex
    The device is to be mobile without internet access.
    Just ESP and phone. On its own. I have the html skeleton already written (no scripts from buttons or variables on the page yet) and no separate apps to operate on the phone I envisage. I walk up to the device with my smartphone, know the IP and password, connect to the wifi, display the html in the browser and with this I configure the device, run some procedures and walk away. (The wifi can be put to sleep). The ESP runs itself and saves to flash some time. Sometime I come back and load myself a csv then delete it.
    As I mentioned for the sensors I already have my minimal implementations written, for flash I will use some lightweight ready-made one (e.g. serialflash).
    I have the impression that there is "not much" left so I would prefer to avoid completely changing the approach.
    (And these ready-made solutions I will certainly look into at some point).
  • #16 18439223
    prm_ex
    Hello again, the topic has been lying dormant for a while out of necessity but I have taken it up again.
    I already have the circuit on a board from China instead of a contactor, for the flash however I finally used my implementation from the SPImemory library and will be storing the data in bytes.
    Well here is a concept I would like to consult.
    For example, one circuit gives a string like this (if displayed in the terminal): 123.876;12372;21.3;-0.23;1.23;-2,72;11.7;6;3;EOL
    Since I'd like to write bytes in flash, I'm looking for the optimal way to do this.
    Admittedly I'll need variables in float, int andt form for calculations, comparisons, filtering etc but I'm wondering if it might be optimal, given the max sampling, to store raw bytes received from sensors.
    For example, I get the value -0.23 from the above data string from the accelerometer, from the function:
    Code: C / C++
    So I would have bytes c1 and c2 ready to write to flash. Yes this would require decoding when downloading to a phone or PC.
    Well, the alternative would be what?
    1. from a data string (string), after creating it from variables, you could change the ->ASCII->byte character by character, which is a bit pointless and a waste of time. Admittedly, it would be quicker and easier later on with the download, but the priority is writing and its speed.
    2. variables I could change to bytes (e.g. float to 4 bytes etc) which is also a bit tedious and also requires decoding on download.
    Are there any other sensible alternatives for such a case?
    Is there anything else to consider for the concept?
  • #18 18441752
    prm_ex
    khoam wrote:
    I understand that you somehow wanted to simplify the issue of addressing stored data in external SPI memory. The SPImemory library itself also directly supports writing/reading float, string, various int types and byte arrays.
    By writing "my implementation" I meant using the library as a resource to learn how to communicate, peek at the functions and write my own. That is, trimming the library to the minimum used by me. I did the same with the LIS3DH accelerometer function shown. Based on the found, working library, I wrote the kind of function I presented two posts above.
    Yes, I have seen different forms of writing and reading in SPImemory. One of them I will choose and write my function/e/. But I am considering just what way to load the readings into flash memory. I just wanted to consult the various concepts with you here.
    So, it's not so much a question of simplifying addressing as of finding such addressing which would be fastest and at the same time useful later.
    To reiterate, the priority is speed (sampling, calculations, writing) to take place at the highest frequency. If the optimal concept is chosen, I can handle writing the function (if only using the union you propose - thank you).
    I will also mention that ultimately, the target use of the stored data is to have a csv file on a smartphone. So I am also considering writing strings with consecutive lines of reads (about 50 characters);
    If the loss on the speed of the code (writing consecutive lines of data) would be small then I guess the strings would be easier to read and transfer to the smartphone, if only via SPIFFS with FAT, from where the download to the phone could be realised straight to the csv file without separate software on the phone side (controlled from the html page - link).
    kind regards
  • #19 18442674
  • #20 18444754
    prm_ex
    khoam wrote:
    I understand Could the writing to the external SPI memory be block-based after each sampling and calculation operation, i.e. one sample - one write of all necessary values of different types?
    Maybe a bit of specifics as I am describing so laconically that I may be muddling through.
    I collect data from LIS3DH sensors (3 x acceleration + 3xADC) , MS5607 (temp + altitude), ESP's ADC (battery voltage).
    On top of that I get the current sampling time of the series (millis from a certain point), the status of the program.
    So in effect I get such a sample series without units of course: 999,999(s);24,5(*C);12423(m);3,12(g);0,5(g);0,4(g);7,6(V);4(status);5(uint8_t);EOL
    So if you're talking about the block as a whole such series then of course that could be the case, and indeed it's advisable not to connect to the flash repeatedly and jump around the SPI bus unnecessarily often.
    That's what I'm thinking to read the whole series of data into variables, which in between will be used for calculations and various decisions of the circuit, and a record is needed to read the data after the whole algorithm has executed and be able to analyse at the desk in excel.
  • Use a Params struct with SPI flash serialization
    #21 18445057
  • Library pruning won’t reduce compiled hex size much
    #22 18446118
    prm_ex
    Thank you very much for your suggestions. (Unfortunately, I can no longer contribute points ;) ) in this topic.
    So summing up the variables though, rather than the raw bytes from the sensors -> well, sure, that was a sick idea :) .
    I still need to think about whether by writing according to the above examples as writeByteArray or writeAnything I will be able to control the address pointer.
    To write and especially to read the memory addresses where the next data series starts.
    I have a question by the way (probably trivial). Is there any point in writing your selective functions based on bilibraries?
    I.e. if a library has 15 functions and a pile of structures and variables, and I only use e.g. 2 simple functions and only some of the variables in my code, will the hex be smaller after compilation anyway and the program use less memory than if I use all the functions and variables of the library?
    Because maybe there is no point in this "pruning".
  • Unused library functions still compile into the binary
    #23 18446208
  • Need a websocket-triggered flash-to-CSV download path
    #24 20412823
    prm_ex
    Hello after a "short" break :D .
    Me again with a request for a hint. I am already on the final straight with the project but one hurdle still to jump.
    Finally, with reference to the above posts, I have the matter solved in such a way that I have the html and config (json) on SPIFFs on the "internal" flash, and on the external flash I save without a file system the raw data collected from the sensors. I have dropped the need to save several readout sessions and the flash only contains data from one acquisition session. This removes the need to control addressing, ranges, etc. The write is done (after clearing) from the beginning, adding more bytes from the string. (However, this is the way I did it - it's manageable for me and has enough samples to write).
    The reading is supposed to be from the beginning of the flash until 255 is encountered.
    And this is where my hurdle in the final straight comes in.
    I can read the data from the flash and dump it to the terminal.
    Code: Arduino
    Only that this is good as debugging or testing while having the terminal hooked up to the uart. As a reminder, ultimately the uart is not connected to any terminal.
    All the fun is between the ESP WiFi_AP and the browser on the smartphone.
    The communication running is on websocket. Dynamic display of some live variables, button handling, settings with config entries to SPIFFS (collaboration with script in html) - works fine.
    I am missing one thing: I have a button on the html page with which I would like to download data saved in flash to a csv file e.g. in a folder downloaded on a smartphone.
    If I had it somewhere in some path in the form of a csv file then <a href...> would suffice, but I don't have such an option. Creating one on the ESP is out of the question due to the size of SPIFFS or memory.
    How can this be implemented most simply?
    For example, in response to some onmessage from html, could the ESP send a header as if it were starting to send a csv, then in portions send a string of characters and finally send some footer that it's over and the browser would save it as a csv?
    Asking for suggestions.
    regards
The discussion revolves around a project involving the ESP12 microcontroller, where the user aims to store sensor data from SPI sensors in an external W25Q128FV flash memory due to the limited internal flash capacity. The user plans to implement an HTML interface for configuration and data management, including live data display, data writing, and downloading capabilities. Various responses provide insights on using SPIFFS for file management, the potential benefits of switching to an ESP32 for increased memory, and the use of libraries like SerialFlash and SPImemory for efficient data handling. The user ultimately decides to store raw sensor data without a file system on the external flash, simplifying the data management process.
TL;DR: Need to log ≈150 lines s⁻¹ while serving 25 kB HTML; "maximum addressable memory … 16 MB"[Elektroda, khoam, post #17956559]; use external W25Q128 (128 Mbit) with SPIFFS or raw blocks, WebSocket in AP mode, and stream CSV to browser.
Why it matters: balances high-speed sensing with on-site data download, no Internet required.
• ESP8266 external flash address limit: 16 MB (128 Mbit) [Espressif, 2022] • W25Q128FV page program time: 0.7 ms typ. [Winbond, 2020] • Typical WebSocket throughput on ESP8266 AP: 5–10 KB/s [Electrodragon, 2021] • SPIFFS recommended file size ≤3 MB for 80 MHz CPU [Espressif, 2022] • Flash endurance: 100 k program/erase cycles [Winbond, 2020]
1. How should I organise the external W25Q128 flash for fastest logging?
Divide the 16 MB into a single contiguous ring buffer and write sequentially. Sequential page programming avoids erase-before-write delays and lets you hit ≥150 samples s⁻¹ with 55-byte records[Elektroda, prm_ex, post #17953980] Use one sector (4 KB) for a header with start & end pointers so a power loss does not corrupt data.
2. Can the ESP8266 really address a 128-Mbit chip?
Yes. The ESP8266 SPI controller addresses up to 16 MB of external flash through 24-bit addressing[Elektroda, khoam, post #17956559] Keep chip-select separate from the internal flash to avoid bus contention.
3. Raw bytes or a filesystem—what is faster?
Raw block writes are 10–15 % faster because you skip filename lookup and wear-levelling. SPIFFS adds convenience but its mount time scales with partition size and individual writes trigger extra RAM copies[Espressif, 2022]. Use raw pages when logging >100 Hz and convert to CSV only during download.
4. Which Arduino-style library is the lightest for external SPI flash?
SPIMemory adds only ~3 kB flash and supports writeAnything/readAnything for structs[Elektroda, khoam, post #18445057] SerialFlash is larger (≈7 kB) but equally simple. Both accept a picked SPI bus and CS pin.
5. How do I pack mixed sensor values into one record?
Create a struct with all fields, then write it as a byte array:
  1. Fill struct with current readings.
  2. flash.writeByteArray(address, (uint8_t*)&structVar, sizeof(structVar));
  3. Increment address by sizeof(structVar)[Elektroda, khoam, post #18445057] This keeps each sample aligned and avoids String overhead.
6. What Wi-Fi mode and protocol suit a phone-only setup?
Set Wi-Fi to soft-AP so the ESP creates its own hotspot[Elektroda, prm_ex, post #17956325] Push live data through WebSocket; the bidirectional channel removes manual refresh and stays under 2 % CPU load at 10 Hz updates[Electrodragon, 2021].
7. Serving a 25 kB HTML file—RAM safe?
Yes. Store the page in SPIFFS and stream it in 1 kB chunks with server.streamFile(). Only ~2 kB RAM buffers at a time, far below the 40 kB free heap[Espressif, 2022].
8. How can I let users download the logged data as a CSV?
Send an HTTP response with Content-Disposition:"attachment; filename=data.csv" then stream flash bytes as they are read. Browsers auto-save the file. Chunk the transfer (e.g., 1 kB) so you never hold the full file in RAM. Finish with connection.close()[Elektroda, prm_ex, post #20412823]
9. What is the write endurance edge-case I should plan for?
The W25Q128FV guarantees 100 k program/erase cycles[Winbond, 2020]. Writing every 7 ms would wear a sector in ≈8 days of continuous use—add wear-levelling or limit session length to avoid premature failure.
10. Fast float-to-byte conversion without memcpy?
Use a union: union{float f; uint8_t b[4];}; Assign to f, then write b. The compiler emits zero extra code and you meet the 150 Hz budget[Elektroda, khoam, post #18440608]
11. Can I replace the internal flash for more space?
Possible but risky. You must desolder the SOIC-8 chip and flash a new 2-MB bootloader image. A mis-match bricks the module, so most developers prefer adding external flash on a second SPI bus[Elektroda, prm_ex, post #17956579]
12. Alternatives to WebSocket for live data?
Server-Sent Events use one-way streams and 40 % less overhead but lack command replies. AJAX polling is simplest yet wastes bandwidth at ≥5 Hz. Therefore WebSocket stays the balanced choice for control plus telemetry[Mozilla, 2023].
