Nie, dziękuję Przekieruj mnie tamberserker1 wrote:I wrote an email to Tauron regarding the lack of meter range (no data and no information in the elicznik) and even an automatic response came with the application number, but I doubt that it will do anything. Who will be bothered - unless something is blocked on the meter, that it does not transmit data to the meter.
migod wrote:Returning to the original question - is it possible to get information about the energy consumed and sent from this meter and HOW? P1 serial port blanked and sealed. Optical output (apparently) blocked ?? The LED pulse output is kwh (constant 1000 imp / kWh) and kvarh (constant 1000 imp / kvarh).
wojciechmalkiewicz9 wrote:I have 480kWp on the application and 248kWp on the meter
wojciechmalkiewicz9 wrote:downloaded from the 1060 network
wojciechmalkiewicz9 wrote:Hello, I have a question from November 19, I have a 9.9 kWp bifacial installation and a Huawei hybrid inverter and the S34u18 meter on the application I have a yield of 480kWp and 248kWp on the meter, so who is cheating here?
migod wrote:
It would be best, however, if the ZE meter itself would enable such integration .. and hence my questions .. some of you checked the IR port? Maybe there is an Installer among us who knows the topic?
murzynslawek wrote:One hundred percent can display the voltage value from this meter. The question is how to dig into it. The information needed to put too much voltage on the tauron. Which results in shutting down the inverter.
=Grzegorz= wrote:murzynslawek wrote:One hundred percent can display the voltage value from this meter. The question is how to dig into it. The information needed to put too much voltage on the Tauron. Which results in shutting down the inverter.
of course you can, but it is not loaded into the display list by default
murzynslawek wrote:=Grzegorz= wrote:murzynslawek wrote:One hundred percent can display the voltage value from this meter. The question is how to dig into it. The information needed to put too much voltage on the tauron. Which results in shutting down the inverter.
Can any adapter be chosen, however to extract this data?
bert73 wrote:wojciechmalkiewicz9 wrote:Hello, I have a question from November 19, I have a 9.9 kWp bifacial installation and a Huawei hybrid inverter and the S34u18 meter on the application I have a yield of 480kWp and 248kWp on the meter, so who is cheating here?
Sza Cun, when I have a micro-installation, I want ... what I produced (data from the inverter) to be put into the grid (shown on 2.8.0), and all consumption in the apartment, no matter ... because I have photovoltaics. .. Hands drop ...
Added after 22 [minutes]:
If you were a supplier, you would like someone to "fumble" in the meter without his permission and without knowing what you are doing there ... so that you could possibly win some pirated software ... (knowing life, there would be 100% of such people who would still like to earn on such pirate software by pressing a kit that thanks to it, you will be able to, for example, change parameters, stop charging energy etc. only to be used by the supplier and only he can possibly read or reprogram the parameters, if you have a meter for micro-installation and the meter has no range, make sure that your meter has the range of the given operator, which is physically installed in the meter, you will ask how ... after all, it is the property of the supplier, and only so that if there is no coverage in the place where the meter is installed, then in a situation where the supplier wants to improve the coverage, by e.g. installing an additional antenna (probably it is not possible in all meters installed on the network, I am not 100% sure), then you should show willingness to solve this problem together with the supplier's representative (installer) and not approach the topic, it is not my problem that you do not have communication with the meter modem. Because if the meter has a range, you will have the data in the e-meter, thank you for your attention.![]()
TL;DR: In 100 % of user reports, data appeared within 3 hours once signal returned; “No bars means no transmission” [Elektroda, keysim1986, post #19660605] Cellular range and correct registration solve most S34U18 data issues.
Why it matters: Simple checks can prevent week-long blind spots in PV monitoring.
• Pulse output: 1000 imp / kWh and 1000 imp / kvarh [Elektroda, migod, post #19674511] • P1 serial port: RJ12, often factory-sealed [Elektroda, JACEK111, post #19626505] • eLicznik online service: 0 PLN, self-registration open since 13-10-2021 [Elektroda, rokbok, post #19760876] • Typical cellular module: 2G/3G, internal antenna; external SMA optional via installer [Elektroda, keysim1986, post #19660445] • Display signal icon: triangle + up to 4 bars; triangle alone = 0 dB coverage [Elektroda, berserker1 & keysim1986, post #19660581]
