Device AT4P HD Color screen digital display smart rail meter -problem
zak12 2592 5
  • #1 20529408
    zak12
    Help: 16
    Rate: 17
    I have a problem with this device. I cannot configure with my wifi network and smartphone. Could someone help by showing step by step how to pair it ?
  • #2 20530855
    Rate: 12914
    Was a manual included in the kit? Where was it purchased, did you try the seller's website to look for instructions?
    Maybe this will help:
    (manual from the vendor's listing AT4PW 100A Tuya WIFI bus Din smart remote control switch AC 220V 110V digital power Volt Amp Kwh frequency factor meter )
  • #3 20557144
    zak12
    Help: 16
    Rate: 17
    Thank you for your response and help . Everything went ok, thank you again.
  • #4 20817935
    Wiesiuch
    Hi. I have a slightly different problem with this meter. After a power failure my billing resets. Is this normal?
  • #5 21799900
    konradkusztelak
    Hi. I have a different problem. I can't reboot it to factory settings. I have changed the network and want to configure it again.
  • #6 21838433
    borciuch2525
    Rate: 12
    >>21799900
    Enter the meter settings by long-pressing OK/Menu and enter the Wi-Fi reset item. In the app, remove the device and add it again with the new Wi-Fi network data.
    Added after 2 minutes:
    I should add that I wanted to connect it to a Wi-Fi network with WPA2/WPA3 security, but failed.
