BFT Virgo operator, Thalia control unit - installation of bell button and lighting in the garage
LASZLO021979 2895 1
  • Need terminal 60/61 confirmation and AUX light output guidance
    #1 19618670
    LASZLO021979
    Welcome.
    I have a BFT Virgo garage door operator Thalia controller and would like to fit a push button to open / close the door with a standard bell button over the cable.
    Under which terminals I connect the wires I am not sure and I do not want to burn the control panel :) .
    It seems to me that it is necessary to connect to terminals 60 and 61 but as I wrote I do not want to break anything BFT Virgo operator, Thalia control unit - installation of bell button and lighting in the garage
    Another question is whether it is possible to use the second button of the remote control to switch on the lights in the garage. I have read that it is also possible but I also ask for a hint on which terminals I think AUX but I am also not sure.
    Please help
  • Need better schematic to verify command inputs
    #2 19618869
    Daro1003
    Help: 295
    Rate: 608
    Poor quality of this photo
    But I see you have outputs described as Commands:
    and there is IC1 and IC2 short-circuited to COM then surely there will be partial opening for some ventilation and full opening closing.
    I see there is an AUX 24V output described as AUX auxiliary.
    The terminal numbering due to poor quality I cannot see.
    To verify what I write it would be helpful to have a better quality of this schematic and to read the manual on how the commands or inputs work.
