Wemos D1 R2, DS18B20, 4 Relays - Strange behaviour of thermometers on 12V supply
fafer11 879 3
  • #1 19629116
    fafer11
    Good morning
    I have a strange problem.
    Plugged into wemos board 4 relays 2x thermometer.
    When powered by usb everything works fine but....
    After connecting to 12v and switching on any of the relays, the thermometers go berserk, one erases the 5c temperature and the other -5c
    Relays pinned to gpio pins 2,12,13,14 1-wire to gpio-0.
    Can someone enlighten me as to why this is happening?
    Greetings.
  • #2 19629419
  • #3 19629797
    fafer11
    1. 2A
    I did not plug in the relays loosely. This is an X4 relay card such a standard one from China. Power goes from the Wemos 5V.
    The bad measurements are all the time and are repeatable.
    I can add that ESPEasy is uploaded.
    I measured the power on the 1-wire at USB is less than 5V and drops when more coils are attached. At 12V there is a constant 5V. :) Paranoia.
  • Weak 5V regulator makes relay board unreliable
    #4 19629823
