Why do I get an error when trying to use GPIO20 in the NodeMCU?
TvWidget 1062 2
  • #1 19655513
    TvWidget
    Help: 472
    Rate: 697
    On the ESP32-PICO-V3, the GPIO20 pin is brought out.
    When trying to use it in the NodeMCU, the message "GPIO_PIN mask error" appears.
    I found advice to modify the /sdk/esp-idf/components/soc/soc/esp32/gpio_periph.c file.
    I have replaced '0,'on the appropriate position with 'IO_MUX_GPIO20_REG,'. The error still appears. Does anyone have an idea what needs to be done to make it possible to use GPIO20 ?
  • #3 19655601
    TvWidget
    Help: 472
    Rate: 697
    I am using the "master" version.
    The advice solved the problem. Thank you very much.
