NodeMCU v3 ESP8266 and DS18B20: D0/D8 pin compatibility and pull-up resistor selection
Travisek 2364 1
  • D0 and D8 likely unsuitable for DS18B20 bus
    #1 19187815
    Travisek
    Rate: 12
    Hi, I have a NodeMCU v3 ESP8266 (attachment) and a DS18B20 temperature sensor.
    If I plug the data pin of the temperature sensor under e.g. D1 or D7, there are no problems. On the other hand, if I plug in D0 or D8, it does not detect the device.
    On the other hand, with pin D0 I can normally control the diode via digitalWrite, etc.
    So why could this not work?
    And I have a second question if anyone knows: if VCC is 5 V, should I connect 4.7 kOhm pull-up or 10k?
    NodeMCU v3 ESP8266 and DS18B20: D0/D8 pin compatibility and pull-up resistor selection .
  • #2 19187937
