Does the ESP32-PICO-V3 require different JTAG settings than the classic ESP32?
TvWidget 897 5
  • External JTAG wiring still gives incorrect reads
    #1 19707612
    TvWidget
    Help: 472
    Rate: 699
    I have an ESP-WROVER-KIT board. In it, the JTAG works properly. The connection to the ESP32 is via jumpers. I disconnected them and connected outside the ESP32-PICO-V3-02 (4 JTAG lines + ground). Without changing anything in the Eclipse settings I tried to connect via JTAG. The processor is seen, but the environment reports that incorrect values have been read. Is the problem more of a hardware or software nature?
    I also did a JTAG test with an adapter on FT232. Here, of course, the settings already had to be modified. However, the effect was identical to the first case.
  • #2 19708126
  • #3 19708401
    TvWidget
    Help: 472
    Rate: 699
    khoam wrote:
    And what is the version of tool-openocd-esp32?
    I won't check this until Tuesday. The question you asked may indicate a software problem. From a JTAG point of view, are the ESP32 and ESP32-PICO-V3 chips distinguishable?
  • #4 19708533
  • #5 19713901
    TvWidget
    Help: 472
    Rate: 699
    V0.10.0-ESP32-20210401
  • #6 19714164
