[Solved] I am looking for a router with WiFi 6 (802.11ax) supporting DD-WRT/OpenWrt/Tomat
Asonoman 8676 5
  • No WiFi 6 routers listed for DD-WRT or OpenWrt
    #1 19729290
    Asonoman
    Level 4  
    As in the title, I am looking for a new generation router with WiFi 6 (802.11ax) supporting DD-WRT / OpenWrt / Tomato, so as not to use the manufacturer's software.
    Yes, I checked supported devices on their website:
    https://www.enginoor.com/list-of-tomato-compatible-routers/
    https://wiki.dd-wrt.com/wiki/index.php/Supported_Devices
    https://openwrt.org/toh/start
    Unfortunately I don't see anything that has wifi6 and is on this list.
    Do you know any devices?
    Regards!
    Totolink X5000R as OpenWrt-compatible WiFi 6 option
    #2 19729969
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    Hi.
    https://www.ceneo.pl/105313575 - probably fits the one you are looking for - https://openwrt.org/toh/totolink/x5000r
    You're unlikely to have much luck with DD-WRT: https://forum.dd-wrt.com/phpBB2/viewtopic.php?t=327762
    It's rather similar with tomato (initially it was for routers with Broadcom chipset).
    Out of curiosity - why don't you want to use the manufacturer's software? There are routers that have powerful configuration options on their stock software (e.g. Mikrotik).
  • Totolink X5000R meets Wi‑Fi 6 and open-source needs
    #4 19730418
    Asonoman
    Level 4  
    Thanks for the answers.
    Totolink X5000R fits my needs perfectly: vpn, wifi6, wpa3, mesh, 1Gb bandwidth, supports opensource soft.
    Only this price, PLN 200, is surprisingly low! What are your opinions on this equipment?
    Do you know any other equipment that meets these requirements, or only Totolink for now?
    As for why he doesn't want the manufacturer's software? Often the manufacturer's software is heavier, more unreliable, more backdoors, fewer options. In addition, I strongly support the idea of open-source.
  • #6 19734760
    Asonoman
    Level 4  
    I was able to finally find the correct link: https://openwrt.org/toh/views/toh_available_16128_ax-wifi
    The official site where they listed routers from AX. There is no madness, but I will choose one of them and see for myself.
    DD-WRT and Tomato probably don't really have anything to say about it yet.
    Thanks again, topic closed!
