[Solved] Compatibility of the TUYA controller with Xiaomi Mi Smart Home Hub
malleus4577 24144 2
  • Asking whether a Tuya Zigbee relay works with Xiaomi hub
    #1 19735822
    malleus4577
    Hello forum users,
    I've been trying to automate my apartment for some time. Yesterday I took aim at automating the heating.
    For this purpose, I wanted to replace the room thermostat with a voltage-free TUYA (Zigbee) relay and operate it with my Hub from Xiaomi.
    Maybe someone has already used the above relay and is able to tell me if I will be able to connect it to my Chinese hub?
    Thanks in advance for all replies :)
    Regards
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    You can't easily connect it - these are 2 different "ecosystems" - you need a Tuya (or compatible) gateway to control Tuya devices.
    If you want to connect devices from different manufacturers, you need, for example, a multigate + Home Assistant.
  • #3 19742019
    malleus4577
    Thanks for the answer :)
    I have already found another solution, which consists of the Yeelight modular relay, which will remotely switch on the electromagnetic relay, to which the cables from the central heating furnace will be connected to the voltage-free NO contacts :D
