[Solved] Tuya Zigbee gateway and Xiaomi temperature and pressure sensor
lexom 6225 5
  • #1 20358128
    lexom
    Rate: 9
    I want to buy a zigbee tuya gateway (like the one pictured).
    I have a sensor: Mi Temperature and Humidity Sensor (zigbee).
    Will this sensor work with this gateway or do I need a gateway from Xiaomi.
    Tuya Zigbee gateway and Xiaomi temperature and pressure sensor .
  • #2 20358273
    freebsd
    Help: 766
    Rate: 2034
    Xaomi sensors will not connect to the Tuya gateway.
  • #3 20513523
    wilkunek
    Rate: 15
    If you have purchased this kit then let us know if it works. I'll add from myself that my Xiaomi camera does the job of a BLE gateway and I didn't have to buy a gateway or what they call nowadays - Xiaomi Zigbee control panel
  • #4 20515195
    freebsd
    Help: 766
    Rate: 2034
    wilkunek wrote:
    If you have purchased this kit then let us know if it works. I'll add from myself that my xiaomi camera is doing the job as a ble gateway and I didn't have to buy a gateway or what they call nowadays - xiaomi zigbee control panel
    Can you confirm that you think the camera with Bluetooth works as a gateway for ZigBee, for this in the Tuya smart home?
  • #5 20515357
    wilkunek
    Rate: 15
    No no, we misunderstood each other. I have Xiaomi Bluetooth thermometers as in the topic and they connect both to the camera and to the gateway, I didn't have to have a gateway
  • #6 20926005
    lexom
    Rate: 9
    I connected the sensor to the Home Assistant using a USB gateway.
