#1 19759150 12 Dec 2021 15:22 kartmos kartmos Level 10 Posts: 29 Rate: 21 » | Topic author Post #1 19759150 12 Dec 2021 15:22 I have a flood switch and a modular contactor for a water pump. Is there any way to interface this with Home Assistant or Domoticz or Supla.
#2 19759157 12 Dec 2021 15:24 gulson gulson System Administrator Posts: 29525 Help: 150 Rate: 6122 » | Helpful post? (0) Post #2 19759157 12 Dec 2021 15:24 What are the flood switch and contactor? What are you getting at the output of these sensors? As soon as you have a short/short circuit then this can be shorted using the GPIO port on the Raspberry Pi, if that's what your home assistant is on.
#3 19759351 12 Dec 2021 16:55 kartmos kartmos Level 10 Posts: 29 Rate: 21 » | Topic author Helpful post? (0) Post #3 19759351 12 Dec 2021 16:55 I am operating on home assistant after gip ok but what between contactor and e.g. wemos ? .
#4 19763466 14 Dec 2021 21:12 kartmos kartmos Level 10 Posts: 29 Rate: 21 » | Topic author Helpful post? (0) Post #4 19763466 14 Dec 2021 21:12 I've made myself a project
