Micropython in ESP32 - efficient event waiting in the main program
TvWidget 606 2
  • #1 19781165
    TvWidget
    Help: 472
    Rate: 697
    I want to test Micropython in practice on the ESP32. However, I have not had any contact with this language so far. Let's assume that there is a procedure called when an event occurs, e.g:
    Code: Python
    How in the main program to effectively wait for an event to occur?
    Is the simplest solution, i.e. a while loop, a good one ?
    Code: Python
  • #2 19781521
    tzok
    Help: 3174
    Rate: 6529
    If we operate on events then we do not actively wait for them.... the occurrence of an event triggers an interrupt, i.e. interrupts the execution of the main program loop and goes to the interrupt handler routine.
    https://docs.micropython.org/en/latest/reference/isr_rules.html
    https://randomnerdtutorials.com/micropython-interrupts-esp32-esp8266/
  • #3 19781558
    TvWidget
    Help: 472
    Rate: 697
    Sometimes it can be difficult to write a program that only operates on events and the code itself becomes unreadable.
    Let's assume that I need to implement communication via some interface. Establishing a connection, sending and receiving etc. generate the corresponding events.
    So I can handle all the events in this way:
    Code: Python
    The main program could look like this:
    Code: Python
    Of course, what I have called the main program can also be placed in an interrupt. The whole thing will work as an automaton. In real
    cases, however, such an automaton can be very complicated. It is much simpler to write a linear program like the one above.
    Is it effective to wait in a while loop for successive events? Perhaps some other special mechanism has been created for this.
