Using an IR remote control receiver as an interrupter in a light with WS2812 LEDs on ESP32 and Ardui
Juni[]r 942 3
  • Use a dedicated core or interrupt-driven IR handling
    #1 19941009
    Juni[]r
    Rate: 25
    I have a question how can I use the receiver for the IR remote control as an interrupt ? I mean exactly that I built a lamp for the children's room. And during the animation on the WS2812 LEDs (16x16), the remote control is obviously not working because the controller is busy with another part of the program. Or is there any other way to make the remote control "active" all the time during program execution ? I tried to set the interrupt as IR leg in the setup but it doesn't work at all. I hope there is some way. Or maybe I run one core only as IR support ?
    I am using ESP32 and Arduino.
  • #2 19941810
    JacekCz
    Help: 760
    Rate: 1464
    You have said more than you have said.
    You can guess the code you have with delay()
    Code?
  • #3 19942650
  • IR remote codes mapped to LED control actions
    #4 19944348
    Juni[]r
    Rate: 25
    JacekCz is about whether it is possible - as for the code, I will write it quickly
    Code: C / C++
    There in the loop there are many animations depending on the variable "check" but I did not paste because it would clutter the screen
