LoPy ESP32 with LoRa 868MHz: Can the APD-200 and other 868MHz sensors be connected?
Michal8883 708 3
  • #2 20148931
    skyguy
    Help: 19
    Rate: 185
    No, Satel has a closed communication protocol and you can't get to the detectors with other devices like Satel.
    You can connect the detectors to the ACU-220, configure the ACU outputs to violate the wireless detector and then use the physical ACU outputs to violate the ports in the ESP.
    https://www.satel.pl/produkty/sswin/system-be...y-abax-2/urzadzenia-systemowe-abax-2/acu-220/
  • #3 20149244
    Michal8883
    Rate: 11
    ACU-220 I will connect and program on ESP32
  • #4 20158026
    skyguy
    Help: 19
    Rate: 185
    The ACU-220 has modbus on board, so you can easily send everything via 2 cables and control the outputs.
