DALI system voltage: circuits 1 and 2 with reduced voltage 8vDC and 12vDC, 50vAC between circuits
skaboi6977 546 2
  • #1 20178728
    skaboi6977
    Hi I have a problem with a DALI system, a couple of circuits are working fine, the other two - the DALI voltage drops to about 8vDC on circuit no 1, no 2 - 12 vDC, the voltage measured circuit no 1-2 = 48vAC and about 52 vAC to ground. Thanks in advance for any help
  • #3 20179221
    skaboi6977
    Dali LED luminaires, emergency luminaires, several transmitters for non-Dali lights
