Electric Desk Only Lowers After Rewiring, Raise Button Unresponsive
Serkownik 13923 6
Treść zostaÅ‚a przetÅ‚umaczona polish » english Zobacz oryginalnÄ… wersjÄ™ tematu
  • Raise switch likely not receiving power after rewiring
    #1 20273357
    Serkownik
    Welcome.
    I have two strips for my computer, printer, desk etc. stuff.
    I decided to sort it out somehow and rewire it so that the cables don't bother me.
    After rewiring, my electric desk doesn't respond to pressing the raise button, only the button to lower the desk works.
    When I click down I can hear something switch on there, there is a snap and when I click up nothing happens and nothing is heard.
    Electric Desk Only Lowers After Rewiring, Raise Button Unresponsive Electric Desk Only Lowers After Rewiring, Raise Button Unresponsive Electric Desk Only Lowers After Rewiring, Raise Button Unresponsive .
    Anybody got anything?
  • #2 20317190
    Baniak15
    I bought such a desk today and have the same problem. It was supposed to be in perfect condition, but I forgot to add that it doesn't lift. Have you perhaps solved the problem? Is there a part to be replaced?
  • #3 20317229
    kkknc
    Help: 1916
    Rate: 6721
    You bought from what he wrote this post that's why he sold. :) .
  • Manual reset may be required after transport
    #4 20317233
    Baniak15
    I was assuming this option as well, but the color of the frame and top is different. Well, unless it's for the sake of deception 🙂
    Added after 10 [hours] 11 [minutes]:
    Cheesecake, all is not lost. Try it with a "manual reset" it worked for me.
    https://mechatronika.tech/wp-content/uploads/...kcja-obsługi-zasilacza-Compact-Logic-Data.pdf
    Page 20
    Perhaps after transporting, or reconnecting cables sometimes such a reset is required.
    Regards
  • #5 20905093
    dorotako123
    It worked! Thanks a lot!
  • #6 21209318
    noozlej
    It worked! This post saved me. Bravo
  • #7 21367246
    sweepersky
    I created an account here just to confirm that a manual reset helped me too :) It was a different driver and desktop model, but it went without a problem. Thanks!
An electric desk stopped responding to the raise button after rewiring, while the lower button remained functional with audible relay activation. The issue was resolved by performing a manual reset of the desk's control system, as detailed in the Compact Logic Data power supply manual (page 20). This reset procedure is recommended after cable reconnection or transport to restore proper operation. Multiple users confirmed the effectiveness of the manual reset across different desk models and drivers, indicating it as a common solution for similar electric desk control failures.
